Old May 17, 2012, 12:53 AM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
It would also be neet if you trim up a three blader.
Limited flyer is offline Find More Posts by Limited flyer
Old May 17, 2012, 07:09 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by divemasterphil View Post
Just finished a quieter Sky Surfer using a 9" Trojan prop (trimmed 1/4" per side), Turnigy Park480 1100kv motor, Hobbywing 40a ESC (overkill) and four MG90s servo. About one third the noise of a 6" 2200kv setup. Needs more nose weight. I'm going to pull the ESC and put it closer to the nose or get a heavier battery.
How many amps are you drawings at WOT and what type battery are you using?
Eagle202 is offline Find More Posts by Eagle202
Old May 17, 2012, 08:00 AM
divemasterphil is offline
Find More Posts by divemasterphil
Soon to be CrashMasterPhil
Rochester MN
Joined Dec 2007
Using a 3s 2200mah Turnigy Nano 45-90c (more overkill). Pulled a max off 22a on a fresh charger.
I think I'll try the 3 blade next.
divemasterphil is offline Find More Posts by divemasterphil
Old May 17, 2012, 10:08 AM
mozzartusm is offline
Find More Posts by mozzartusm
Joined May 2011
My motor started cutting out so I pulled it and the wires. The black wire was melted in 3 places. I turn it on for about 3 seconds and it wouldn't open up all the way and the wires got extremely hot. Motor shot?
mozzartusm is offline Find More Posts by mozzartusm
Old May 17, 2012, 10:58 AM
pavn is offline
Find More Posts by pavn
pavn's Avatar
Czech Republic, Olomouc
Joined Sep 2010
See whole thread about version #16 of the camera and external power.
Going to try it myself soon.
Both of those options look interesting.
Are there any issues with either over charging the camera battery or draining the Lipo. I would hate to lose control of my plane due to the camera.
pavn is offline Find More Posts by pavn
Old May 17, 2012, 12:02 PM
Limited flyer
Joined Dec 2011
Aerial shot of my new club field, can't wait to get out there.
No i did not take the pic.
Old May 17, 2012, 12:22 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I checked both the USB cable and camera connection and all 5 pins are present.
I also looked at the cables and camera pin out for my # 3 and # 14. Again all the cables and cameras had 5 pins showing.
Although I did remember reading in the #16 manual to only use the cable that came with it.
Old May 17, 2012, 02:34 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Originally Posted by Grazer View Post
Here is a test flight I did with my customised Bixler carrying a GoPro Hero.
The longer term plan is to fly FPV, however I just want to be sure this will be a good platform. It actually does really well and will continue with this plane.
Enjoy!
http://www.youtube.com/watch?v=64Sq7gXQNNw
The Bixler is a great plane for FPV, not necessarilly the most exciting but it can carry a lot of weight.
epyonxero is offline Find More Posts by epyonxero
Old May 17, 2012, 03:25 PM
Scooch is offline
Find More Posts by Scooch
Scooch's Avatar
United States, NJ, Jackson
Joined Nov 2011
Here is what I came up with to hold the wings in place. I put 2 of those small 3m hooks on the wings and ran some rubberbands across the fuse. I cut a small piece of plastic from a 32 oz gatorade bottle to slip under the rubberband to protect the foam. It has held just fine through the first several flights. The hooks are held on with the supplied adhesive strips which seems to be holding just fine.
Scooch is offline Find More Posts by Scooch
Old May 17, 2012, 04:35 PM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
Nice idea Scooch. I will try that when I build mine.
JoshB is offline Find More Posts by JoshB
Old May 17, 2012, 05:42 PM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Has anyone tried just to use magnets at the root of the wing.
Eternalflight is offline Find More Posts by Eternalflight
Old May 17, 2012, 05:56 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I use 4 magnets to hold my wings together. This was fine until the opening started to enlarge after a few crashes. The wings stayed together but slipped back and forth.
Using the Duralock or rubber bands will anchor the wings to the fuse and keep them from sliding around. I also put a small piece of packing tape along the wing and fuse on both sides. It does the job but has to be replaced every time I remove the wings for storage or work.
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
My concern with the magnets is: the hold is strong while they are in contact, but as they separate, the force holding them together weakens by a 1/4 for X distance.
Point being....if they start to separate, they likely will.
Compare to the rubber bands, as they separate, the force increases to keep them together (as the rubber bands stretch, much more force is needed.) so they can snap back together.
Magnets are cleaner (if you can match the size / strength needed) but rubber bands are more secure... abet messy looking.
idletime is offline Find More Posts by idletime
Old May 17, 2012, 06:01 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Get the rare earth magnets. They are very strong. Use the rubber bands or dual lock or tape or or or as a secondary device to secure the wings. Your choice.
Check out page #1 of this thread. AJ has collected and posted a lot of good ideas about modifications including keeping the wings in place.
Old May 17, 2012, 06:08 PM
fabric8 is offline
Find More Posts by fabric8
Fixed and rotary wing flyer
United States, NV, Las Vegas
Joined Sep 2011
Originally Posted by TheSelf View Post
Hi all- I'm trying to help my dad get into the hobby with a bixler- I already helped add most of the main mods- can anyone please confirm the correct way to glue the stock arf wooden motor mount in and what the correct thrust angle needs to be (eg. Slightly down and to the right as you look from the tail towards the nose or anything else)? the wooden block has a specific shape and yet it doesn't seem so obvious as to how it fits into the foam mounting area as the shape in the foam that it needs gluing to isn't a particular snug fit with the shape of the block..- any pointers/pictures to the correct way to mount would be appreciated Also not sure how to glue the block in whilst preventing the metal 'drum' of the motor from touching the foam (to allow free movement of the motor fully).. sorry if this has already been answered but this is the only thing holding my dad back from flying and quite honestly cannot read the 1000+ pages here to find this out- thank for any understanding person out there who has any advice for this and can answer- cheers!
I bought 2 ARF kits (one for my dad and one for me) and with both, the motor mounts were already glued to one half of the fuselage through a gluegun. Here are some pics of the motor mount (which I had to remove - long story) and how it should be positioned on the foam. The notch on the right is where you'd run the motor wires.
When it was glued on my plane, the angle was about 3-4 degrees to the left of center when viewed from the tail towards the nose. It was the same on my dad's and when we flew his plane, there was VERY strong roll to the right. So we used a shim to set it straight. It helped a bit, but it still rolls to the right. We haven't had a chance to correct it further, but I would guess that it needs to be about 3-4 degrees to the right of center when viewed from the tail towards the nose. There are some other posts on this thread that mentioned the same thing. As far as down/up thrust angle, I don't know what it should be, but I'm leaving it parallel to the angle of the motor mount for now.
fabric8 is offline Find More Posts by fabric8
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
