I have a bridge for sale
![]() ![]() That is highway robbery. $11.34 ($35MYR) for about 3 feet of wire is robbery. I am sure that no one is dumb enough to pay that much for wire.![]() HK is $1 ($3.09MYR) for twice as much. AJ |
Setting up an airplane
Long answer - It helps you get the airframe setup correctly. Once you are about 4-5 mistakes high (around 200 ft.), shut off the motor, set the plane in about a 30-40 degree dive. Then, release all sticks and see how (if the plane recovers). Once it dives (and subsequently) glides correctly, we can start on the power setup. If we start moving the motor around, we can never be sure if the airplane is flying properly. AJ |
![]() Taz you are correct. Too many conversations for me to juggle at once. I thought I was answering CPMBOY first question concerning a watt meter and then elcid79 thinking he was getting one at Radio Shack. Thanks for setting me straight.
United States, NY, Victor
Joined Apr 2005
I think I would like to purchase this Sky Surfer as my first plane and my trainer. Can you recommend a vendor and whether the stock RTF radio and parts are OK, or better to go with ARF and a separate radio and receiver? I would like to be able to upgrade and use my first radio and plane for a while to learn basic flight and then some simple aerobatics.
Thanks! Bryan |
AJ |
Joined Apr 2005
I'm in Victor, NY. I sent an email to Tim at http://www.readymaderc.com to ask about what he has available for/with the Sky Surfer. I'm thinking maybe a kit would be better than RTF if I want to get some better quality components?
Thanks! |
Kit: Foam parts and hardware, all needing to be assembled yourself
ARF: Servos and motor pre-installed, some assembly of the foam needed RTF: All electronics installed, still need to install some of the foam pieces The stock electronics are OK, I ran stock equipment for hundreds of flights, and I still use the stock servos, and I just replaced the motor a few weeks ago. |
Latest blog entry: Flying in the Neighborhood
Suggestion
![]() AJ P.S. I see you were flirting with an EZ* about 7 years ago. Have you thought about it long enough yet?
Get a kit and put your own good stuff in it. . Not only is that a good idea, it allows me to disagree with aj.
![]() AJ |
Joined Apr 2005
![]() Yeah, you know I was seriously looking, back in 2005, at the EasyStar because it was recommended... then I got into some discussion about what radio to get with it... then it started getting too complicated and so I found other uses for the money I had. ![]() But someone just gave me $350 specifically for a RC plane (he's an ex-commercial pilot to boot), so I am now seriouser. ha So I have one vote for RTF and then see how it goes, and another for ARF and get my own parts. Seems like I could at least upgrade the motor to brushless, a better radio, and get a few battery packs and props with the money. Also, ReadyMadeRC only sells the V1 version of this plane, since he's all about FPV and V1 has the most interior space. Is that OK? Thanks for the help! Bryan |
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
