As you indicated the wood spreads the pressure which is key to not creating point impacts from the clamps. Thanks for the pix. |
United States, TN, Memphis
Joined Jun 2011
On those shafts that are slightly over 2.3 could you not use a little sand paper and spin up the motor to reduce size? Being careful not to use too much pressure of course. The shafts may be too hard but it's an idea. Don't know if you could lay a file to it or not.
United States, CA, Newark
Joined Sep 2011
Good idea! I'll try that on my dad's plane since I have a few TGS 6x4E props from HobbyKing. |
Joined Sep 2011
Joined May 2011
Turns out that it must have been the motor thrust angle. Mine was the opposite of what ive seen in this forum. Looking from front to back mine was pointing right. I changed it so that it now points left if viewing from front to back. As soon as I released the plane, I could tell that I wasn't fighting it for the first time. Just when I was going to begin coming around for a landing something happened and it turned straight down at mach 3 into a nice pine tree. I wonder if the motor mount popped loose? Maybe I didn't get enough glue in after changing the motor thrust angle? |
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
