Old May 08, 2012, 06:37 PM
ccsj is offline
Find More Posts by ccsj
snokefpv
United States, CA, San Jose
Joined Mar 2012
Originally Posted by shunyata View Post
That motor looks to have the identical specs as the Turnigy. Try an 8x6E APC.
Exact flight time is hard to compare because with the stock motor, I was using a 1300mah bat and with the new motor, it needed the weight of a 2200mah up front. It flew for what seemed like forever on the 2200, including doing the WOT climbs. lol. Will have to see exactly where the battery finishes on its next flight.
Yeah.. I read somewhere that some EMP/Turnigy motors are just rebranded.
ccsj is offline Find More Posts by ccsj
Old May 08, 2012, 06:39 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
emm...COG....some say 60mm (V2) , some say 75mm (V1)....
CPMBOY is offline Find More Posts by CPMBOY
Old May 08, 2012, 07:19 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
It's definitely 60mm, 75mm is a long way back.
To be extra precise, I like 61-62mm
Main difference I find between good and bad cg, is throttle changing planes attitude, whether it will stay level at all throttle settings, or dive/climb at different throttle.
sammyc is offline Find More Posts by sammyc
Old May 09, 2012, 01:08 PM
pavn is offline
Find More Posts by pavn
pavn's Avatar
Czech Republic, Olomouc
Joined Sep 2010
Help with FPV airplane selection
I would like to buy an new FPV airplane. Could you help me with decision?
I was thinking about.
Sirius 1500
http://www.bevrc.com/sirius-the-best...ters_p281.html
or
Bixler EPO 1400 Kit
http://www.hobbyking.com/hobbyking/s...00mm_KIT_.html
Which of them is better?
Thanks in advance for your opinions.
Pavel
pavn is offline Find More Posts by pavn
Old May 09, 2012, 01:24 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Sirius 1500
or
Bixler EPO 1400 Kit
Pavel
I couldn't get to the website for the Sirius to compare the two planes.
The Bixler is certainly a great plane for FPV or if you are just starting out in the RC hobby. I own a V2 SkySurfer which is easy to fly and mod out for FPV.
If you are looking for a true FPV platform with a bigger cargo hold, Hobby King has a model called the FPV UAV composite. It is fiberglass instead of the foam and in the pictures they show the number 168. I don't know a lot about this model but it or something like it might be what you want.
Eagle202 is offline Find More Posts by Eagle202
Old May 09, 2012, 01:37 PM
pavn is offline
pavn's Avatar
Joined Sep 2010
Here is also Skywalker Sirius 1500 to look at:
http://www.foxtechfpv.com/sirius-150...der-p-497.html
I am not already or completely new to RC flying yet. I already have Art-Tech Diamond 2500 2.6 meter glider. And had HobbyKing one meter Flying Wing. And I used that Flying Wing also for my start to FPV. I had only 10 FPV flights with it and I lost it. It was great flying wing since it was easy to transfer. A lot of fun. Nearly not destructible. But for FPV start it was not ideal since it was not so much stable airplane.
So now I am looking into something more stable for my FPV start. Which also could be easy to fix and possibly crash resistant.
I always had either EPO or EPP airplane. Which was not so difficult to fix. Would not be HobyKing FPV UAV composite fiberglass very difficult to fix if needed? Is composite fiberglass crash resistant?
Old May 09, 2012, 01:45 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Foam is most certainly easyer to fix then balsa / composite plane :P
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 09, 2012, 02:07 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I agree foam is better than fiberglass and sticks.
Here is another foam FPV plane called the Skywalker.
http://www.fpvflying.com/products/Sk...otor-prop.html
It was made for FPV flying.
Old May 09, 2012, 03:26 PM
pavn is offline
pavn's Avatar
Joined Sep 2010
Yes, looks great. Thanks.
However I would like something cheaper for my FPV starts maybe. I had only 10 FPV flights with my flying wing. And would like to avoid big investment to what I do not know much yet. That it is why maybe Bixler or Sirius could be ideal choice for now.
Old May 09, 2012, 03:46 PM
Joined Oct 2011
There is no such thing as FPV without the word investment :P
Old May 09, 2012, 03:49 PM
pavn is offline
pavn's Avatar
Joined Sep 2010
Yes, but I want just cheaper airplane for now. And then when I will have some reliable FPV system, then I can upgrade/buy another airplane if needed.
Old May 09, 2012, 04:31 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
IFlyRCs is offline Find More Posts by IFlyRCs
fabric8 is offline
Find More Posts by fabric8
Fixed and rotary wing flyer
United States, NV, Las Vegas
Joined Sep 2011
Help with Bixler motor trouble.
I received my Bixler and finished assembling the fuselage. One thing I noticed was that the stock prop adapter had marring on it, like someone had used a pair of pliers on it. I spun the motor and could see that the shaft has a slight bend I'm wondering if I got a return.
I tried to remove the motor, but the motor wires are stuck with the hotglue on the motor mount. So I gave up on that. I went ahead and cut off the stock prop adapter right where it ends on the shaft.
Now that I spin the motor with the rest of the shaft cut off, I can still see that the shaft is bent very slightly. I'm thinking about trying to straighten it with a pair of pliers by hand, but I'm worried I might break off the motor mount. Should I even bother?
Here's another problem I'm running into. I tried to mount a 2.3mm prop adapter onto the shaft, but it doesn't fit. I tried another one and same thing. I took the plane today to a hobby store to buy another 2.3mm prop adapter (thinking that the ones I had weren't machined properly. The guy measured the shaft and it turns out its 2.36mm. He couldn't get the prop adapters to fit onto the shaft even by trying to pry the prop adapter apart.
Should I drill out the hole on the prop adapter to fit the shaft?
This is really annoying. 1st, the shaft is slightly bent, 2nd, the shaft is larger than 2.3mm.
What are my options?
fabric8 is offline Find More Posts by fabric8
Old May 09, 2012, 04:36 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Just a reminder before "thread boss" AJ Baker appears. This thread is NOT a FPV thread.
Prof100 is offline Find More Posts by Prof100
Old May 09, 2012, 06:52 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Originally Posted by Prof100 View Post
Just a reminder for "thread boss" AJ Baker appears. This thread is NOT a FPV thread.
We digress. Thanks for the sanity check Prof100
To keep on the thread I will say the best choice for a low cost foam plane is either the Sky Surfer or Bixler. They can be flown almost right out of the box or modified to whatever you desire (like FPV)
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
