Old Jul 21, 2010, 05:51 AM
IanJ is offline
Find More Posts by IanJ
Aberdeen, Scotland, UK
Joined Dec 2007
Originally Posted by sonicj View Post
werd! got it working! ended up with a 100k on one side and 47k + 10k trimmer on the other. the 5k i had seemed to do a little better, but it was like a 20 turn monstrosity. i think you have your voltage padded down a lot lower than mine... im pushing 4.5v or so at the a5 pin with 12.9v going in at the screw terminals. i had to add a lot of offset in the software to get the voltage reading back into range of the trimmer pot. i was thinking, the higher input voltage should give me a little better resolution when i run on 2s packs...?
it seems like it updates the screen kinda fast... 3 or 4 times per seconds maybe??? the top line has a bit of flicker thats in sync with the flashing yellow led on the arduino. gonna go do some more research on driving these lcds... cheers!
-sj
3 or 4 times per sec should be fine. I normally drive those types of LCDs at around 200mS, which isn't far off the 242mS of serial LCD refresh in my code......assuming you've placed your code similarly.
However, more likely is that you are seeing some jitter due to the interrupts. Are you using a library for yor new LCD?........it's own interrupts may be conflicting with the interrupts in my code. I think that's one of the reasons I went for a serial LCD thus avoiding the use of any library code.
If you are getting jitter due to this then make sure the PPM output isn't jittering now also. I remember that was a BIG issue before I changed to serial LCDs. If you get stuck I'm sure there are 16*2 serial LCDs out there somewhere.
Ian.
IanJ is offline Find More Posts by IanJ
Old Jul 21, 2010, 06:03 AM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
ahh.... that makes sense. i think i can drive this lcd via the serial output. i'll swap it around and see what happens. if not, i'll check the ppm to make sure its still good. thanx!
-sj
sonicj is offline Find More Posts by sonicj
Old Jul 26, 2010, 08:56 AM
wskisoft is offline
Find More Posts by wskisoft
Joined Jun 2010
same code, different job
Hi Ian,
I have a need to remotely control the pan of a camera, and was thinking that i could use the code for the throtle. Looking at the pics, it looks like you have a Pot for the throtle is that correct?
Ian..
wskisoft is offline Find More Posts by wskisoft
Old Jul 26, 2010, 01:14 PM
sonicj is offline
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
Originally Posted by wskisoft View Post
Hi Ian,
Ian..
wskisoft,
the throttle is actually the same as the x, y or z controls, just in a different form factor. all consist of a potentiometer setup as a voltage divider. turning the pot varies the voltage to the corresponding analog input. ie: 0v to 5v = low to high. ian's code measures that voltage and converts it to value which is then inserted into the ppm signal to the tx.
if you only need the pan axis, you can use any potentiometer that suits your needs. no need to hack up a joystick for the throttle control... you can simply pick a pot that fits your desired rotation in and add a knob of your preference. slide & rocker pots are fair game as well. cheers!
-sj
Old Aug 30, 2010, 07:16 AM
dmackie is offline
Find More Posts by dmackie
Dave Mackie
London
Joined Oct 2005
nice bit of kit, you got rudder pedals on the cards too?
Am looking at getting a second hand FF9 to deconstruct and distribute into a throttle box, a joystick and some rudder pedals... for FPV of course. Just wondering tho, do you know if the FF9 can output all channels to the LRS whilst still accepting channels 7 and 8 from a Gyro sensor on goggles? (and hence passing that thru to the output?)
just thought i'd throw that out there
dmackie is offline Find More Posts by dmackie
Old Aug 30, 2010, 09:23 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by dmackie View Post
...Just wondering tho, do you know if the FF9 can output all channels to the LRS whilst still accepting channels 7 and 8 from a Gyro sensor on goggles? (and hence passing that thru to the output?)
Yes
renatoa is online now Find More Posts by renatoa
Old Sep 14, 2010, 08:00 PM
HaydenH is offline
Find More Posts by HaydenH
Oz Noob
Sydney, Australia
Joined Sep 2010
I've just started making on of these, and while I'm alright with code and electronics in general, I'm hopeless on the actual design side of electrics.
Is it possible for anyone to put up a rough sketch of the circuit?
Labeling the capacitors used on the input power etc.
Thx.
Cheers,
HH
HaydenH is offline Find More Posts by HaydenH
Old Sep 14, 2010, 09:18 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Thx.
Cheers,
HH
Get the documents for the Microstar 2000 and have a look, then think of how you might modify it for the processor you want to use. If you are already using a PIC then you may want to contact Gordon and see about sharing the code to help with the software development.
village_idiot is offline Find More Posts by village_idiot
Old Sep 17, 2010, 08:25 PM
kukger is offline
Find More Posts by kukger
Joined Sep 2010
Cool project! I don't know when i can design one like that. I try my best
kukger is offline Find More Posts by kukger
Old Nov 30, 2010, 08:22 AM
snowmanf is offline
Find More Posts by snowmanf
Olden days FPVer now returning
Surrey
Joined Nov 2010
Any more news on this one?
Ian, the snow must be pretty heavy up there now.
Just spoke to a relly in Skye and their snow is much deeper than ours down here today.
snowmanf is offline Find More Posts by snowmanf
Old Nov 30, 2010, 01:14 PM
IanJ is offline
Joined Dec 2007
Aye, pretty bad up here........fine excuse to take a few days off though....
Ian.
Old Dec 01, 2010, 08:21 AM
ali1980 is offline
Find More Posts by ali1980
Joined Jun 2010
hi guys
I wanna to build suitable encoder for Corona DIY 2.4GHz that could control 4 servos of helicopter ..can anybody help me .
regards
ali1980 is offline Find More Posts by ali1980
Old Jan 19, 2011, 02:14 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Great project there Ian. I decided to give this a go. Now just waiting for the bits to arrive. Any update on your coding lately?
Martin Y is offline Find More Posts by Martin Y
Old Jan 19, 2011, 05:02 PM
IanJ is offline
Joined Dec 2007
Hi,
The code hasn't changed recently, it's still as per my website.
Let me know how you get on, I always like to see other folks's builds, especially pics!
Ian.
Old Jan 19, 2011, 05:39 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Originally Posted by IanJ View Post
Hi,
Ian.
Will Do.
Discussion Looking for cheap RC radio TX/RX sets 1145climber Electric Power Cars 3 Apr 08, 2010 05:24 AM
Build Log Re-inventing /modding Thunder tiger's P-51D Mustang kusunokimasahige Electric Warbirds 12 Mar 22, 2010 12:57 PM
Discussion Re-inventing the wheel philgib Blimps 5 May 25, 2006 06:42 PM
