Old Oct 15, 2012, 01:18 AM
Aberdeen, Scotland, UK
Joined Dec 2007
Originally Posted by vertcnc View Post
Ok, I am baffled. I did measure the joystick pots wrong they are 5k. V on wiper is 2.5v. one side ground the other side measured at 5v. so when I measure the voltage while moving the joystick I get 1.8v one direction and 3v the other, centered 2.5v. so the joystick is not using the whole range of the pot.
raw data in test mode indicates 504 centered 636 one direction and 369 the other. If I change the code as suggested, raw data does not change.
Raw data won't change, 0vdc = 0, 5vdc = 1023...........and that's fixed. It's the output of the scaling calculation that will change, i.e. the PPM values.
You are not getting much of a range in your raw value, but it may be ok.
I'd also tweak the centre to 504, that will make sure your stick is trimmed centre off the bat.
By making all these tweaks and settings you should have the full PPM range when moving the stick, and properly centred. Use the TEST mode to confirm this.
Ian.
IanJ is offline Find More Posts by IanJ
Old Oct 15, 2012, 08:09 AM
Illinois, USA
Joined Aug 2009
Ok, I will check the PPM out in the test mode and see where I am at. Appreciate the help.
vertcnc is offline Find More Posts by vertcnc
Old Oct 15, 2012, 01:54 PM
Joined Oct 2010
Ok have code up and running on arduino mega, I am using Aurora 9 joysticks. It appears that the output on the pots only vari from 1.8 v to 3.0v. Is there a way to scale these so the raw data is correct. it appears that these are only 500 ohm pots.
Did it take much work to get it running?
R_Lefebvre is online now Find More Posts by R_Lefebvre
Old Oct 15, 2012, 04:38 PM
Illinois, USA
Joined Aug 2009
No, not really. Just takes a little bit to learn the code. Changed to I2c display, and also seperate trim switches per each axis. I am just a rookie with arduino, but getting there.
Old Oct 25, 2012, 01:51 PM
Joined Oct 2010
vertcnc, do you mind sharing your code?
I'm thinking of trying one of these LCD shields with integrated buttons. Anybody have any input on that idea?
I just realized what you are talking about with the Aurora 9 joysticks. I wish I had noticed those earlier. I almost bought the joysticks at servo city, but I think the Aurora's will be much nicer.
But do I understand correctly that you basically only have 267 bits of resolution on those sticks? Maybe it's OK, though it seems low.
Old Nov 01, 2012, 12:34 PM
rimshotcopter's Avatar
Joined Aug 2009
Brilliant work! Thanks
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 01, 2012, 01:14 PM
Illinois, USA
Joined Aug 2009
Code is pretty much what Ian provided. I just ported the LCD to an IC2 dsiplay. Currently working on adding seperate trim switched for each stick axis. Soon as I get a little further along, I can provide copy of changes I have made.
Old Nov 02, 2012, 08:38 AM
Joined Oct 2010
Ok, I'd appreciate seeing it. The LCD stuff is new to me.
I'm humming and hawing about going with the Arduino Due instead of the Mega, to take advantage of the Audio driver. I'd love to be able to have it give audio feedback about the flight condition.
Old Nov 02, 2012, 08:50 AM
Joined Oct 2010
Oops
Old Nov 02, 2012, 01:09 PM
Illinois, USA
Joined Aug 2009
LCD stuff is pretty easy as far as programming. You just need the arduino library for the particular LCD type your using. Most places that sell the LCD'S have sample code and the library available.
The thing that I don't know about is Ian used a serial LCD and I am using a I2C LCD, the I2C LCD's may need more resources and mess with the timing, But havn't found it to be a problem yet. Havn't really tested using RF module so time will tell. Busy right now working on the hardware configuration, joysticks, buttons, lcd and such. Let you know.
Old Nov 02, 2012, 01:14 PM
charlienofun's Avatar
United States, CA, Alameda
Joined Mar 2008
What I2C display are you using? I started a version for use with the web4robots i2c LCD http://www.arduino.cc/playground/Code/LCDi2c but I stopped I don't really need a display as I send the signals through my futaba and let it do the mixing/trims etc.
http://www.wentztech.com/radio/ardui...es/LCDI2C.html
charlienofun is offline Find More Posts by charlienofun
Old Nov 02, 2012, 01:29 PM
Joined Dec 2007
I used a serial LCD mainly due to resources.
Analogue Input pins (0-5vdc):
Pin 0 = Elevator potentiometer --> PPM Ch.2 - Elevon mix Aeleron 2 (averaged) (Invert mode) (Exponential mode)
Pin 1 = Aeleron potentiometer --> PPM Ch.1 - Elevon mix Aeleron 1 (averaged) (Invert mode) (Exponential mode)
Pin 2 = Rudder potentiometer --> PPM Ch.4 (averaged) (Invert mode) (Exponential mode)
Pin 3 = Throttle potentiometer --> PPM Ch.3 (averaged)
Pin 4 = Aux potentiometer 1 --> PPM Ch.6
Pin 5 = Battery Voltage (2.2v at input to display 12.6v)
Pin 6 = Aux potentiometer 2 --> PPM Ch.7
Digital Input pins:
Pin 2 = Function panel button
Pin 3 = Trim adj panel button
Pin 4 = Trim adj panel button
Pin 5 = HI/LO rates set panel button
Pin 6 = Thumb stick AEL up
Pin 7 = Thumb stick AEL down
Pin 8 = Thumb stick ELE up
Pin 9 = Thumb stick ELE down
Pin 13 = Aux switch 1 --> PPM Ch.5
Pin 11 = Aux switch 2 --> PPM Ch.8
Digital Output pins:
Pin 10 = PPM output
Pin 12 = Buzzer output
Pin 1 = Txout, Serial LCD (TTL mode)
Old Nov 02, 2012, 01:41 PM
Joined Aug 2009
Spectrum Protocol
lanJ,
How hard do you feel it will be to implement the Spectrum Protocol into your fantastic creation? The hope is to bypass the PWM transmission and send this information over Xbee or some other similar system.
The Protocol
The protocol transmits data in frames of 16 bytes. The first 2 bytes are header bytes used for syncing the communication. Then the channels are transmitted one by one. Where one channel consist of two bytes.
[Header][Aileron][Flaps][Elevator][Rudder][Throttle][Gear][Ch7]
(The channel order might change depending on 6 vs 7 channel transmitter and Mode 1 vs Mode 2 Stick setup on the transmitter, use serial monitor to find the right order of the channels)
Header
always consist of
byte 0x03 followed by 0x01.
Aileron
Range: 1024 - 2046
Center: 1535
Flap
Range: 5120 - 6142
Center: 5631
Elevator
Range: 2048 - 3070
Center: 3582
Rudder
Range: 3072 - 4094
Center: 3582
Throttle
Range: 0 - 1022
Center: 511
Gear
Range: 4096 - 5118
Center: 4607 (Theoretic)
Channel 7
Range: 6144 - 7166
Center: 6144
NOTICE: You will normaly newer reach the endpoints of the ranges. For example the throttle channel will normaly go from aproximately 150 to 850. The rest of the range is avilable for trim and travel adjustment. Setting the travel adjustment to 125% and subtrim all the way in one direction will let jet you reache the end points.
http://www.dogfight.no/2011/01/spect...o-arduino.html
Old Nov 02, 2012, 02:55 PM
Illinois, USA
Joined Aug 2009
I think that the same brand I have. 20x4. I have it working just fine. Working on bar graph code for battery display at the moment.
Old Nov 02, 2012, 03:57 PM
Joined Oct 2010
Digital Input pins:
Pin 10 = PPM output
I see. Well since I'm using the Mega, I have a few more pins available. Plus, I don't plan to have the thumb stick buttons.
How would an I2C LCD compare to a "4 bit" version. I might think the 4-bit will use up hardware timers? Basically I'm wondering which one would take up the least resources.
I'd like to be able to have the Mega talking to a GPS (serial), Xbee (serial), a compass (I2C?) and then of course outputting the PPM stream at the highest priority for best performance of that.
Discussion Looking for cheap RC radio TX/RX sets 1145climber Electric Power Cars 3 Apr 08, 2010 05:24 AM
Build Log Re-inventing /modding Thunder tiger's P-51D Mustang kusunokimasahige Electric Warbirds 12 Mar 22, 2010 12:57 PM
Discussion Re-inventing the wheel philgib Blimps 5 May 25, 2006 06:42 PM
