Old Apr 17, 2010, 11:11 AM
KMKAZE is offline
Find More Posts by KMKAZE
Question gravity.
KMKAZE's Avatar
Kane County, Il
Joined Sep 2000
Excellent service from Sig with Avistar Warranty
I just wanted to give Sig a big thumbs up. My Aviastar .46 had a spun lower bearing (very well could have been caused by running it too rich), and in the course of taking the engine apart, I had lost one of the screws that held the muffler on.
It took about 3.5 weeks to get the engine back, but I got a note stating what they repaired, and he threw in the muffler screw at no charge (I told him I was perfectly willing to pay for it).
The engine started right up and is running sweet. So that means I have two aviastar engines in the fleet. I feel like I can't blame them for the spun bearing, as my .53 has never given me problems and I've been careful not to let that engine go too rich, and I gave it an easy, extended break-in before flying.
KMKAZE is offline Find More Posts by KMKAZE
Old Apr 17, 2010, 04:05 PM
flying-things is offline
Find More Posts by flying-things
In love with aviation
flying-things's Avatar
Joined Apr 2010
It seems like for the most part this hobby has many warranty "triumphs" compared to the rest of the stuff we buy, ie. how do they treat you at best buy? Probably because RC is so expensive!
flying-things is offline Find More Posts by flying-things
Old Apr 19, 2010, 08:54 AM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
I dont think your bearing troubles were caused by running too rich(even though a rich mix can cause liner binding) , the AV engines are know to occasionally burn up a lower rod bearing.
The cause is under investigation but too tight a bearing tolerance is probably the culprit. And as you have found they are a great engine if you get one with a good carb.
jeffie8696 is offline Find More Posts by jeffie8696
Old Apr 19, 2010, 11:55 AM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
Do you know what is causing the variability with the carb? Are you confident that the issue has been isolated to the carb and not a seal issue with the engine.
Too tight a tolerance usually only causes manufacturing issues. Too loose (wide) a tolerance can cause operational issue as the stack up might result in too little or too much bearing clearance.
Can you expand on the "liner binding" issue?
Konrad is offline Find More Posts by Konrad
Old Apr 19, 2010, 12:08 PM
b7gwap is offline
Find More Posts by b7gwap
It's Prime Time for Slime Time
b7gwap's Avatar
Joined May 2004
I thought a lean run was what killed bearings... good on SIG though.
b7gwap is offline Find More Posts by b7gwap
Discussion Little Screamers warranty service (BAD) cyhyam Vendor Talk 65 Feb 23, 2010 08:00 PM
Discussion Neu Motor warranty/Repair Service EdBall Flies! NeuMotors 9 Jan 20, 2010 08:51 AM
Rave 7 day warranty turnaround from Neu service, thanks! blueviewlaguna NeuMotors 17 Jul 12, 2008 06:33 PM
Excellent service from an excellent company BIGSAPPY Vendor Talk 0 Jun 12, 2002 12:47 PM
Excellent Service from Hobby People soholingo Vendor Talk 0 Dec 05, 2001 08:57 PM
