Old Sep 14, 2010, 08:55 AM
Jstplanenutz is offline
Find More Posts by Jstplanenutz
Joined Sep 2010
Question.....I have read as much as I have been able to find on these life batteries and from what I can gather some say its ok and some say not to run these packs without a voltage regulator. Would that be correct? I have two life 1800mah 6.6v packs and I was going to plug both of these into my JR 9 channel receiver. I am running specktrum servo's A6010 and A6020 in 30cc gasser. About six servo's in total. Do I need a voltage regulator???
Jstplanenutz is offline Find More Posts by Jstplanenutz
Old Sep 14, 2010, 09:07 AM
Silent-AV8R is online now
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
United States, CA, Ladera Ranch
Joined Aug 2004
I've been running LiFePO4 packs (Hyperion brand) unregulated since last December. In addition I know a large number of others doing the same thing. So far I have not heard of anyone who has had a problem. The only potential issue is if you are using servos that simply cannot handle more than 4.8 volts.
Silent-AV8R is online now Find More Posts by Silent-AV8R
Old Sep 14, 2010, 10:02 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
A6010 Digital Aircraft Servo
Product Specifications
Size Category: Standard
Type: Digital
Application: Aircraft
Torque: 100 oz-in @ 6V
Speed: 0.14 sec/60 @ 6V
Length: 1.6 in (20mm)
Width: 0.8 in (41mm)
Height: 1.5 in (39mm)
Weight: 1.7 oz (49.0 g)
Bushing Or Bearing: Bearing
Bearing: Dual
Motor Type: Brushed
Connector Type: Z Connector
Gear Type: Metal
Gear Material: Metal with one plastic gear
Voltage: 4.8 or 6.0V (4 or 5 cell)
4.8 or 6.0 go for it....I would.I use this pack in both my 65 3dhs vyper and my 3dhs 70 aj slick since last year..Neary a glitch.4 hs 985 hitec servos in mine.
The 6020 voltage ratings are the same...So yea,Id roll with it
Manta1 is offline Find More Posts by Manta1
Old Sep 14, 2010, 11:30 AM
MikeMcChiken is offline
Find More Posts by MikeMcChiken
Fly'em like you Stole'em
MikeMcChiken's Avatar
The Gehto,Ca.
Joined Jun 2008
Type: Digital
Bearing: Dual
Motor Type: Brushed
Gear Type: Metal
If you have ever used a 6v Nimh rx pack you would notice that the voltage on it , fully charged , is high than that of the LiFe or A123 . Did you ever run a regulator with a 6v NiMh pack ?
MikeMcChiken is offline Find More Posts by MikeMcChiken
Old Sep 14, 2010, 03:26 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Ive not run 6vnimh packs except maybe in my kadet senior with saito on it and a skyraider.
Neither of those have regulators.Most of what I have now are electric aerobatic planes.I do not use regulators on either one that i run the life pack in.for about a year or so now.
The life packs maintain a steady voltage while under load.Very nice.Only thing is this voltage holds until the pack gets depleted,then will nose dive so I hear.Ive not had one do this to me as I recharge after a few flights and noe the amount of mah goes back in,then compare to how many mah the pack is rated for.Then I kinda know how many flights I can have between charges..I have flown 8-10 flights on single charge on the flight pack before recharging..I usu go 6.
Old Sep 15, 2010, 12:36 PM
The Gehto,Ca.
Joined Jun 2008
I do have a regulator on one of my LiFe packs but only cause it was already in the plane . I figure no harm no foul .
Old Sep 16, 2010, 09:31 PM
Joined Sep 2010
Awsome! Thanks guys I think I will give it a shot with no regulator.
Old Sep 29, 2010, 06:53 PM
MK2 is offline
MK2
Find More Posts by MK2
MK2
IT's A SLICK SICKNESS...
MK2's Avatar
Long Island NY
Joined Oct 2008
How do you test the voltage or whats left in the pack while at the field? I have been using Lipo packs and have no issues knowing how much power is left.
MK2 is offline Find More Posts by MK2
Old Sep 29, 2010, 07:14 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
it is my understanding these packs hold steady volts until they are dead,then drop off rather quickly.So what I do,is fly about 5-10 times,then recharge and see how many mah i put back in my pack.Then I can kindof figure out how much I use durinf each flight.
I only charged my packs 1 time throughout a fly in this past weekend..
Old Sep 29, 2010, 08:09 PM
MK2 is offline
MK2
MK2
MK2's Avatar
Long Island NY
Joined Oct 2008
Ok Thanks I will try that.
Eddie
Old Jan 27, 2011, 07:12 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Hey guys I wanted to bump this thread up and see if how these packs have been working for you guys?
I have two 2100 packs that I plan to use in my gaint scale P-51... I've been useing them for setup in the shop and everything is checking out with them.
Whats the word do you guys think they are good packs?
Ron101 is offline Find More Posts by Ron101
Old Jan 27, 2011, 07:42 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I have been using the 1200 mah ones I have for about a year now.Still going strong.
Old Jan 27, 2011, 07:44 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Still very happy with mine.
Old Jan 27, 2011, 09:12 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
Cool to hear...
Some of the jet guys have been saying to only use true A-123. I know they are good but havn't seen anyone say the hobbico are bad
always good to hear feedback
Old Jan 28, 2011, 12:08 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
A123's are great, but round and heavy.
Discussion Intersting new LiFe 6.6V, 15g, battery kcaldwel Hand Launch 68 Aug 15, 2011 12:19 AM
New Product Hobbico LiFe 200 mAh Rx Batt - 5 grams per cell tai626 Batteries and Chargers 2 Apr 06, 2010 06:43 PM
Help! LiFe 6.6v for reciever applications dlittle Castle Creations 2 Mar 08, 2010 11:23 AM
Sold two Hobbico VoltWatch2 4.8V/6V Rx Battery Monitor's ddierking Aircraft - General - Radio Equipment (FS/W) 2 Jan 10, 2010 08:57 PM
For Sale For Sale - New 6.6v 1100mah LiFe Receiver Packs - No Fire Hazard Steve_O Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 18, 2009 09:58 AM
