Old May 22, 2010, 07:33 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Comparison graph of 2100 LSD NiMH and a 2100 (not 2.2as on legend) LiFePO4.
http://www.rcgroups.com/forums/showa...1&d=1274374944
Charles
Old May 23, 2010, 05:23 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
It sure would be nice if Futaba approved the use of these or any other LiFePO4 battery packs w/o the use of a regulator/BEC.
Ohmic is offline Find More Posts by Ohmic
Old May 23, 2010, 05:58 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
They are just playing it safe. I am using 2 cell A123 in all of my gas planes with 7 and 14 channel fasst rx's. I will never go back.
bracky72 is offline Find More Posts by bracky72
Old May 25, 2010, 06:06 PM
MikeMcChiken is offline
Find More Posts by MikeMcChiken
Fly'em like you Stole'em
MikeMcChiken's Avatar
The Gehto,Ca.
Joined Jun 2008
People have been running 6volt Nimh packs forever . If you notice a good pack is over 7volts when it is charged . I am also running a regulated 7.4volt LiIo pack in my Gasser . No problems . People at Futaba need to get off there buttts and answer some questions we have by testing there product on stuff we want to use . Who wants to use an outdated Nicad pack any more ? Why are Tx's still comming with a 700mah nicad pack when better technology is around ? My 9c Super has been a great radio but I am done with Futaba when I go 2.4 . Can you say AURORA .
Everydayflyer , I don't believe that chart . I get about 5hrs of flight on my LiFePo4 pack in my Tx before I charge it . It is usually at 9.7volts still . I could probly go another few hours on it . I don't think I have ever got anywhere close to that on a Nimh pack of a higher mah .
MikeMcChiken is offline Find More Posts by MikeMcChiken
Old May 26, 2010, 03:25 PM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Originally Posted by MikeMcChiken View Post
People have been running 6volt Nimh packs forever . If you notice a good pack is over 7volts when it is charged . I am also running a regulated 7.4volt LiIo pack in my Gasser . No problems . People at Futaba need to get off there butts and answer some questions we have by testing there product on stuff we want to use . Who wants to use an outdated Nicad pack any more ? Why are Tx's still comming with a 700mah nicad pack when better technology is around ? My 9c Super has been a great radio but I am done with Futaba when I go 2.4 . Can you say AURORA....
I don't think We should quite ditch Futaba yet . True, NiCd packs are ridiculous, but clear answers to the LiFe question would be appreciated (ya know -- it's only a few tenths of a volt -- NiMH vs LiFePO4).
I think possibly that the voltage discharge "shelf" of the LiFePO4 battery may have something to do with Futaba's position. (Mike, pda4you, refers to this in his review at the end in the "minus" section: "Voltage dump is steep at the end of useful capacity".
This in my mind would be a legitimate concern. This would make inexpensive low-voltage detection tricky. But with careful battery management, the LiFePO4 advantages seem to outweigh the disadvantages, especially considering the disadvantages of other battery types.
An official reply by Futaba would be very appreciated.
nioa is offline Find More Posts by nioa
Old May 26, 2010, 03:33 PM
The Gehto,Ca.
Joined Jun 2008
I got a response from Hyperion when I got the Tx pack . They said I could run it down to 9.0volts on there 9.9volt pack and it would still have capacity left . So I am guessing the 6.6 could go to 6.0 safely .
I would like to know how to get a good mearsurment on these . What kind of load do we test these at ? Maybe we can just read the voltage with no load like a Lipo ?
Old May 27, 2010, 06:57 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Do a discharge cycle on them with your charger. Watch, they drop quickly around 3v-2.9v/cell to the 2.5v number then tell you not to go below. I fly to 6v then recharge, there is no question I am missing capacity, but don't need to squeeze the last 100-200 mA out of a pack.
Then you can decide on your own floor limit for the cells.
Old May 27, 2010, 07:12 PM
The Gehto,Ca.
Joined Jun 2008
I thought I was missing capacity too on the Hyperion 9.9volt pack until I contacted them . At full charge it goes to 10.2-10.4 . It drops to 9.9 in a couple minutes then in about 15-20 minutes to 9.8 . But right now I have used my radio for almost 5hrs and it is hanging at 9.7 . They say in their LiFe and the G3 Lipo's get better with 20 or so cycles . I think I put about 1100mah's back in after about 5-5.5hrs of use with the voltage down around 9.6-9.7 .
Old May 28, 2010, 08:20 AM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
Maybe this is a dumb question, but I am not seeing much about chargers to use, I have lots of Lipo's, and I have Astro 109 chargers with the Astro Blinky for balancing, and have been very happy with what I have, do I need to get a more compatable charger if I start using the Life batteries as receiver packs?
s2000 is online now Find More Posts by s2000
Old May 28, 2010, 08:23 PM
Southern Pride
Simple answer yes unless you monitor the charge and stop it when 3.65- 3.8 per cell is reached.
My now very old A123 charging thread
http://www.rcgroups.com/forums/showthread.php?t=603368
back then few chargers had a LiFePO4 mode.
For a 2S receiver battery the Pb (lead acid / gell cell) 6V mode works well.
There is a mod for the AF109 ,see post at link.
Some childrens electric cars use 6V Pb battery and a charger for one of these should work fine but charge needs to be monitored just to be safe . I use a 2S LiFePO4 2300 battery in a hand help spot light whic had a 6V Pb gell cell in it and the original charger works fine with it.
Charles
Old May 29, 2010, 09:53 PM
Udet is offline
Find More Posts by Udet
LarsL
United States, IL, Naperville
Joined Sep 2006
I have a 1/5th scale Super Cub that I am outfitting with 2 Spektrum DS821's, 4 Hitec HS-85MG's, and a Hitec HS-81. All are rated for 4 and 5 cell NiCd/NiMH. Am I OK with using one of these new Hobbico LiFe batteries to power the airborne systems?
Lars
Udet is offline Find More Posts by Udet
Old May 31, 2010, 08:12 PM
badpilotto is offline
Find More Posts by badpilotto
BadPilot
badpilotto's Avatar
United States, IL, Custer Park
Joined Nov 2007
I just wish LiFe batts did not weigh so much. Super batteries with great benefits minus the burning risks.
badpilotto is offline Find More Posts by badpilotto
Old May 31, 2010, 09:18 PM
The Gehto,Ca.
Joined Jun 2008
They are lighter than a Nimh pack . What do you mean heavy? Any other battery is lighter than a Nimh . Lipo , LifePo4, A123
Old Jun 01, 2010, 08:39 PM
BadPilot
badpilotto's Avatar
Joined Nov 2007
I was referring that LIfe batts are heavier than a Lipo and that was the only negative item about that type of batt. If I am using it in my transmitter, no big deal but in a flying plane it could be especially as the power source.
Old Jun 02, 2010, 08:35 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I use one in my 87 shp,my 70 slick,and 65 vyper for rx packs.charge once fly all day.only have to swap the motor packs out for recharge
Manta1 is offline Find More Posts by Manta1
Discussion Intersting new LiFe 6.6V, 15g, battery kcaldwel Hand Launch 68 Aug 15, 2011 12:19 AM
New Product Hobbico LiFe 200 mAh Rx Batt - 5 grams per cell tai626 Batteries and Chargers 2 Apr 06, 2010 06:43 PM
Help! LiFe 6.6v for reciever applications dlittle Castle Creations 2 Mar 08, 2010 11:23 AM
Sold two Hobbico VoltWatch2 4.8V/6V Rx Battery Monitor's ddierking Aircraft - General - Radio Equipment (FS/W) 2 Jan 10, 2010 08:57 PM
For Sale For Sale - New 6.6v 1100mah LiFe Receiver Packs - No Fire Hazard Steve_O Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 18, 2009 09:58 AM
