Latest blog entry: Some stuff
Joined Mar 2007
Technica, no problems here; I just basically wanted us to get back on tract about the 180Z and make a few humble points of my own as to the "marketabilty" of the Quark verses the 180Z. The point is that due to it's "style/looks", features, etc. the 180Z is a more appealing heli than the Quark; let's face it, Walkera helis are nice looking and generally have that sought after "pro look". Even though I have never flown a Quark SRB, I believe you and Balr that it is a very nice heli and in many ways superior to the 180Z; I was only critiquing it from a sales and marketing standpoint.
I think if WOW's "transformer" 180Z Pro is all that they claim it to be, then it may well prove to be the "missing link" in stepping up from a coaxial to an FP and beyond without having to spend the money(hard to do in this lousy economy), by purchasing several helis while you are progressing in skills, because yes, you are right that people still need to LEARN to fly an FP heli and there is no escaping the skills needed to do so. I can't afford to buy 2 or 3 different types of helis to get to where I want to be; so the idea of a "transformer" heli than can be "transformed" as your skills progress seems to me to be a brilliant idea and a money saver as well. Anyway it's all good, and WOW, hurry up and release the "transformer" 180Z! |
Australia
Joined Aug 2009
I wouldn't be surprised if the new recommended training path will become: 1. Flybarless FP 2. Flybarless CP With RC technology advancing at a seemingly exponential pace, the only thing that would stop a complete beginner in the future going straight to CP is the complexity if the hardware - not the difficulty of flight. Until then, the 180Z transformer may have it's place. That is until next week when Walkera or someone will bring out a super stable mind controlled heli. ![]()
Joined Jul 2010
Help Repairing CB180Z Flybar
Had a nice crash into daughters toy jeep..ouch. Anyhow need to replace FLYBAR. Ordered new part, but having difficulty removing old flybar from main hub/shaft assembly. There appears to be two bearings pressed into both sides of hub assembly. This is the pivot point for the flybar. Cannot slider flybar out and held in place..dont want to pull or mess up more. Any suggestions on how to get flybar out, or get pressed bearing/pivot point bearings out. Looked at new exploded view on walkera site. This confirmed that there are two bearings on either side. Thanx Paul
Joined Jan 2009
![]() Anyway, they’re not glued in, so just gently push them out, then the fly bar will slide out “fairly” easily.
SINGAPORE
Joined May 2006
You could run a constant 4000rpm headspeed on a small CP heli which gives you enough cyclic-authority to let you enjoy the flight in the wind, but you can't do that with an FP. Everytime you descend an FP, headspeed drops and cyclic-authority will follow-suit. So, I was about to say "Blade SR!"... but your right, a CP heli that size is not forgiving at all. In fact, it's a major step-up. The SR will suit someone who has already mastered the hovering of a conventional FP heli like the honeybee FP or any other non-coaxial fixed pitch 'trainer' model that does not have that 45* stabilizing-flybar design. But don't get me wrong, I do like the CB180Z a lot. It's like the ultimate FP machine in Walkera style (I'm a fan of Spektrum, so I prefer Spektrum bind-n-fly instead of Walkera's) which I would certainly like to add to my fleet. |
SINGAPORE
Joined May 2006
Popular 200/ 250-sizes CP models like SJM 215, Trex 250 and Gaui 200 are all capable of approaching 4000rpm when flown with 100% flat throttle-curve in Idle-up(Stunt) mode when 3D pilots use up-sized pinions (from 3rd party like Xtreme Productions). If they throw in a Scorpion motor for upgrade, they don't need full throttle to hit 4000rpm with using the stock pinion. However, since most manufacturers caution not to exceed 4200 safety limit, the stock pinion usually needs to be down-sized instead to accommodate the higher-kv Scorpion. Sorry for the off-topic...
Joined Jan 2009
CB180Z-Pro is now available at WowHobbies.com
WowHobbies.com has just released the CB180Z-Pro Wind-Rider. Many here have tried to fly the CB180Z outdoor and most were disppointed on how it got blown away by wind. There are a few mods mentioned here but nothing commercially availabe until now. Unlike the stock CB180Z the Wind-Rider is an action packed upgraded CB180Z called the CB180Z-Pro which can fly well in 3-5 mph wind at the same time being able to retain its easy-to-fly Bell design characteristic of the stock CB180Z. The maneuverability comes from the extra travel in the CB180Z-Pro cyclic servos which is lacking in the stock model. The CB180Z-Pro also comes with stock servo parts so you can easily put it back to the CB180Z stock form even thou you would never need to. See video on what the Wind Rider can do in the wind that can't be done on the stock CB180Z.
There are several versions of the CB180Z. Buyers please beware of the differences. 1. Stock CB180Z & WK2402 transmitter. 2. Upgraded CB180Z-Pro Wind-Rider & WK2402 transmitter (Without dual rate). The upgraded CB180Z-Pro has extended servo travel and is more agile than the stock versions. 3. Stock CB180Z & WK2403 transmitter with the upgraded dual rate and throttle limit adjustments. This is a $15 upgrade from 2402 to 2403. 4. Upgraded CB180Z-Pro Wind-Rider & WK2403 transmitter with dual rate which allows for tame or wild outdoor windy conditions flights at a flip of a swith on the transmitter. It also has a throttle limit adjustments. The upgraded CB180Z-Pro impletements the extended servo travel and is much more agile than the stock versions. Cheers, Jonathan www.WowHobbies.com |
SINGAPORE
Joined May 2006
Nicely done Jonathan. The flip switch idea is a good one! So far, I have only seen this feature in the Nine Eagles Solo, where its tx has a switch for toggling between low and high rates of the swash movement.
For those who have never flown FP heli before, they probably won't think highly of the flight in the video. But for those who started the hobby with a fixed-pitch like myself, we can tell immediately that the video is a good testimonial of the mods. Here's why - A honeybee FP or one of those conventional FP models with a 90* flybar will be able to fly like that in the wind, but they don't auto-stablilize and they require tremendous skill and determination to enjoy them. It takes like 2-3 weeks to be able to hover and several months to be able to fly circles. On the other hand, a FP model that has a 45* flybar to auto-stabilize itself (like the CB180Z), will never be able to fly in that wind, not unless you do the correct mods to it. So it looks like Wowhobbies had done it again. Congratulations!
Joined Jan 2009
Jonathan WowHobbies.com |
| Thread Tools | |
| New Product CB180Z Video | JHawk19 | Micro Helis | 41 | Jun 04, 2010 10:09 PM |
| Discussion Walkera 5#10 Build Log and questions. (Pics on page 2) | nubskillz | Coaxial Helicopters | 21 | Apr 12, 2010 11:54 AM |
| Discussion My first pics!(more pics added) | stoked6.0 | Aerial Photography | 24 | Jan 02, 2010 04:33 AM |
| Discussion First Heli: Esky Lama V4 vs. Walkera 5#4Q4 vs. Walkera CB-180Q FP | shannon520sx | Beginner Training Area (Heli-Electric) | 8 | Oct 28, 2009 09:32 PM |
