Old Jul 17, 2010, 02:21 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Originally Posted by carlosmc View Post
Hi,... looking for help...
Let's see,... i got an small accident wich the 330x, one motor went out, i fixed it like other times and it's perfect, but,.... when I fly it the motors 2 and 4 got vibrating up and down, it's not too much but it's noissy, any idea???
The blades are ok, and I think motors and esc also, because it flies, ...
Home anyone understand my spanglish, jejeje
Your Spanglish works great!
I would take a closer look at your props. After a few crashes my props were slightly bent and I had some vibrations. Put some new props on and it was smooth again. I've since switched to the APC props brand as they are supposed to be more reliable. I've had two separate incidents of the replacement gaui props breaking in mid air, let me tell you... that sucks!
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Jul 17, 2010, 02:26 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by jago_svensson View Post
Just a prof of concept, that the GU344 can be used in quite different applications.
Cheers
/Jago
Hi Jago, where did you place the 344? Did you center it on the centerplates or put it left from the center axis like on the original setup?
kinderkram is offline Find More Posts by kinderkram
Old Jul 17, 2010, 02:52 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Is there any place that has these in stock. I would like to buy one, but dont know how long to pre order wait is.
kirby
kepople is offline Find More Posts by kepople
Old Jul 17, 2010, 02:56 PM
john339 is offline
Find More Posts by john339
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
kenseinemo There were two other rc pilots leaving as I arrived and they said it was getting gusty higher up.
I stayed low down and was OK
Then I lifted up high and the wind caught it and it immediately zipped away as I watched.
I should of stayed low down or not flown.
I know better but I get the urge to fly and don't use good sense.
It is almost glued back together so I can fly again while waiting for the new arm to arrive.
john339 is offline Find More Posts by john339
Old Jul 17, 2010, 03:01 PM
john339 is offline
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
carlosmc Make sure the wires are all in tight to the brain and your receiver.
Check each tiny leads to the motors also.
I found after my crash that the battery had slid way out of the wrapping it came in.
I shoved it back again and added some CA glue.
One motor had popped partway off the arm so I pushed it back and glued it again.
Look it over carefully and maybe you will find things to fix.
Old Jul 17, 2010, 03:15 PM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
Someone using APC props? If so, which size and how does they differ from the original?
tritan
tritan is offline Find More Posts by tritan
Old Jul 17, 2010, 03:26 PM
ramovan is offline
Find More Posts by ramovan
ramovan's Avatar
United States, NV, Mesquite
Joined Aug 2004
tritan
I'm using APC 8x3.8 SLO and APC 8x3.8 SLO Pusher props and they seem to work very well. The APC props are a bit stronger and have less flex than the stock props. Amp draw is very similar.
ramovan is offline Find More Posts by ramovan
Site Sponsor
Old Jul 17, 2010, 03:28 PM
tritan is offline
Joined Apr 2007
the APC's obvoiusly weighs a bit more - does that make the quad less stable?
Old Jul 17, 2010, 03:36 PM
tritan is offline
Joined Apr 2007
Are the Gaui props the same as the EPP?
I have heard that the EPP should be loaded max 200-250 gram per prop.
Old Jul 17, 2010, 03:47 PM
ramovan is offline
ramovan's Avatar
Joined Aug 2004
I didn't notice any change in stability. APC props are nylon whereas the Gaui props are plastic. The nylon is stronger but weighs a little more so you'll likely consume a little more power. I've got about 20 flights with the APC's on a completely stock setup with 7A ESCs though and have not had any problems.
Site Sponsor
Old Jul 17, 2010, 05:21 PM
john339 is offline
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
This Gaui has plenty of power to handle the APC props, the little difference in weight is probably matched by their being more efficient.
See, you cannot tell it has been broken and then repaired...
Old Jul 18, 2010, 12:19 AM
aka Helidaho
Joined Jun 2010
tritan
I too am using the APC props. I'm using the 8x3.8 props. I'm still waiting for the pusher props so I've been flying with the original pusher props and the APC regular props. It actually flies quite well this way.
Old Jul 18, 2010, 01:33 AM
tritan is offline
Joined Apr 2007
Helidaho,
so you are flying with both the original AND the APC at the same time in spite of being different pitch size?
I am a bit afraid after reading about people loosing (original) props in mid air - using a camera with mount that would cost if that happens .....
Old Jul 18, 2010, 01:39 AM
tritan is offline
Joined Apr 2007
Balancing
Have anyone balanced their original props?
I did that yesterday using my Top Flite Magnetic Balancer and was surprised how much tape I had to put on each blade. Not sure how much it helped - should have made an in-flight video before and after to see if there where any differences.
Looked at the APC website today searching for props and found out that I have balanced my previous APC props the wrong way. I used the cones against each other and not the way that APC recommends:
http://www.apcprop.com/v/html/balancing.html
tritan
Old Jul 18, 2010, 06:56 AM
tom6696950 is offline
Find More Posts by tom6696950
Michigan
Joined Dec 2008
APC Propellers
Can some one give me the part numbers for the two props i need from APC thanks
tom6696950 is offline Find More Posts by tom6696950
Discussion GAUI - Quad-copter kapteinkuk Multirotor Talk 5 Apr 14, 2010 10:33 PM
Discussion New Gaui 200 SE V1 and DX6i owner fiercebadger Beginner Training Area (Heli-Electric) 0 Feb 25, 2010 02:59 PM
Wanted Want to Trade: New Gaui 200 canopy for old Gaui 200 canopy Splix Aircraft - Electric - Helis (FS/W) 1 Jun 28, 2008 01:07 PM
Quad-winged pager flyer snakeX2 Scratchbuilt Indoor and Micro Models 33 Jan 29, 2005 02:47 PM
