Old Jul 16, 2010, 02:17 AM
toeickris is offline
Find More Posts by toeickris
korea
Joined Jun 2010
help needed after changing the esc
I don't know how to insert clip so I linked my 330x problem.
one motor suddenly stops...so I changed one esc 10A , others are stock 7a
and I just connected then the beep sounds are differnet with changed one.
but when throttling, it starts...but the changed one stops and spins.
the white propellar is the changed one.
can somebody help me the problem?
what procedure-such as setting esc- do I miss?
or what...
toeickris is offline Find More Posts by toeickris
Old Jul 16, 2010, 05:44 AM
fung is offline
Find More Posts by fung
Flying-Hobby
Joined Dec 2003
Originally Posted by toeickris View Post
hi,
http://blog.naver.com/kjj2008
or what...
hi
can you disconnect the other 3 7A esc and check if the 10A working or not.
wait your test
thank you
fung
www.flying-hobby.com
fung is offline Find More Posts by fung
Old Jul 16, 2010, 05:48 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
hi,
or what...
Did you calibrate your ESC for the end points of your throttle?
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Jul 16, 2010, 06:14 AM
jago_svensson is offline
Find More Posts by jago_svensson
jago_svensson's Avatar
Zurich Switzerland
Joined May 2010
gu344 controlling a 2000g X8 quad with 5000g of payload capacity
Just a prof of concept, that the GU344 can be used in quite different applications.
Maiden Flight H-X Quad (5 min 12 sec)
Cheers
/Jago
jago_svensson is offline Find More Posts by jago_svensson
Old Jul 16, 2010, 06:39 AM
tom6696950 is offline
Find More Posts by tom6696950
Michigan
Joined Dec 2008
http://vimeo.com/13368598
Cheers
/Jago
Hey that thing is cool can you get some pic of it close up would really like to see it Thanks
tom6696950 is offline Find More Posts by tom6696950
Old Jul 16, 2010, 08:20 AM
korea
Joined Jun 2010
i did...
Originally Posted by fung View Post
hi
wait your test
thank you
fung
fung...by the way i ordered one 330x from your site and I didn't mention mode 1.
Plz check...by id on your site is same: toeickris@naver.com
i did 10A alone and it didn't work.
do I have to calibrate just 10A alone?
Old Jul 16, 2010, 09:54 AM
john339 is offline
Find More Posts by john339
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
toeickris If you already calibrated the other ESCs then you will need to do the same to the new one. Hook them all up and then do the transmitter full throttle.
Turn on the transmitter and then turn on the quad.
After some beeps lower the throttle to zero on the transmitter and wait for more beeps.
Then unplug the quad and turn off the transmitter.
You shouldn't have to do that unless you change ESCs again.
john339 is offline Find More Posts by john339
Old Jul 16, 2010, 10:05 AM
skagroovy is offline
Find More Posts by skagroovy
Joined Jul 2010
Does any one know where i can buy a gaui gyro for the 330x that is not sold out.... thinking about just building on with a sigma q4-600 frame.....
skagroovy is offline Find More Posts by skagroovy
Old Jul 16, 2010, 10:14 AM
Joined Jul 2010
does any one know were i can buy a gaui 330x gyro....every were i look they are sold out.... i am think about building one with a sigma q4-600 frame....any thoughts... also the gyro will work with any 2.4ghz radio right....
sorry for the double post ....
Old Jul 16, 2010, 10:44 AM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
I've seen some around... I would ask Lee from www.gothelirc.com
AceMigKiller is online now Find More Posts by AceMigKiller
Old Jul 16, 2010, 12:27 PM
Vince53 is offline
Find More Posts by Vince53
Potage, MI
Joined Dec 2003
Check out the parts at http://www.allerc.com/index.php?cPath=24_159
Vince53 is offline Find More Posts by Vince53
Old Jul 16, 2010, 12:56 PM
john339 is offline
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
skagroovy Yes the GAUI brain will work with any radio setup.
Old Jul 16, 2010, 12:59 PM
john339 is offline
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
So there I was minding my own business when a sudden gust of wind caused my Gaui to crash.
Actually it was pilot error and required gluing back one motor mount with motor and re-attaching the three leads.
About 4 minutes of work and some CA glue and I was back in action.
Here is the link to the crash.
I mounted a small cheap camera to the Gaui so it is from that view.
Gaui hillcrest 071610.wmv (1 min 21 sec)
Old Jul 16, 2010, 01:23 PM
Michigan
Joined Dec 2008
http://www.youtube.com/watch?v=e38UhkdW4ac
Nice vid I'm trying to decide if i want to buy a nice camra to use on my 330x or should i buy a FPV system i need some help finding a system that wont brake the bank what do you all think any input will help Tom
Joined Jul 2010
i have been really looking at the sigma frame.... i looked a bit closed at the pdf link on cnc website and it looks like it is just made of wood...??? would i be better off to just buy a flycam camera mount and get the gaui S version????
anyone have luck getting a dslr off the ground.....
thanks
Discussion GAUI - Quad-copter kapteinkuk Multirotor Talk 5 Apr 14, 2010 10:33 PM
Discussion New Gaui 200 SE V1 and DX6i owner fiercebadger Beginner Training Area (Heli-Electric) 0 Feb 25, 2010 02:59 PM
Wanted Want to Trade: New Gaui 200 canopy for old Gaui 200 canopy Splix Aircraft - Electric - Helis (FS/W) 1 Jun 28, 2008 01:07 PM
Quad-winged pager flyer snakeX2 Scratchbuilt Indoor and Micro Models 33 Jan 29, 2005 02:47 PM
