This thread is privately moderated by nerdc0re79, who may elect to delete unwanted replies.
Old Apr 15, 2010, 02:35 PM
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
shifty wing
Pulled some old templates today and decided to build a wing. I think its based on simple wing by gene bond and the swift.
This build was very fast indeed. I went to dollar tree store and purchase a handle full of foamboards. For thing delta wing I only used one sheet. Trace template cut and paint 10mins it took for all that. Waited about 5mins til paint is dry enough for me to handle and glue the 2 wings together using hot glue. I gave it about 1 1/2 in dehiedral because I wanted a slow flying wing,
Then the electronics are installed . I used a blue wonder 1500 kv with 8 or 10 amp esc. 8x4.3 gws sf prop. 2x turnigy cheapy servos. 800 mah 2 cell lipo.
Also added a 12in cf tube spar to keep the angle of the dehiedral on the wing. Cf control rods that was on my f22. Good thing about the rods are the length of em. It was like ment to be. A lot of people use ca glue to hold em but I always like to use hot glue and shrink tube,this way I can just heat up the glue and freely adjust control rods to trim the control surface. Can't do that if you use CA to hold it.
Maiden flight.
It was windy on the first flight. CG was way off. I think I had the battery 4inches back from nose tip.. tailheavy. So I moved batt on the nose. BaM!! Perfect!
Inside loops and outside loops are easy. Wing tracks very well. Rolls are ok since there's a dehiedral on wing rolls looks like a barrel roll.
Conclusion.
Its a fun cheap wing and I know I will be making more .maybe version 2 without dehiedral.with that I know it will roll better
Seriouly i f u have a bw 1500 laying around and 2 cheapy servos and about 45 mins to spare....build one.
the video
version 1
shifty wing.wmv (4 min 58 sec)
version 2 no dehidral
maiden flight
SHIFTY WING V2.wmv (2 min 55 sec)
nerdc0re79 is offline Find More Posts by nerdc0re79
Question charger rc cr-i cr-2 or shifty? which is better? usedhippo 3D Flying 0 Sep 12, 2006 04:59 PM
Discussion Charger Shifty pro foamy! Upside-Down 3D Flying 26 Jul 07, 2006 01:12 PM
Discussion Shifty from CHARGERRC porscheflyer Foamies (Kits) 26 Jun 15, 2006 05:11 PM
For Sale 6 chan rx's gws neg shifty solorsix Aircraft - General - Radio Equipment (FS/W) 9 Mar 11, 2006 02:57 PM
Idea SHIFTY SHIFT +or- aeroflop DIY Electronics 3 Sep 09, 2004 11:08 AM
