Old Apr 15, 2010, 12:07 PM
bosco49 is offline
Find More Posts by bosco49
bosco49's Avatar
USA, CA, Shasta Lake
Joined Mar 2005
Best place to put a tow hook
I have this old EZ glider with the motor removed,And I want to use a Hi start....so were would the best spot be to place a tow hook.I made this tow hook out of 2 paces of plywood and will be gluing it in.....Any idea guys
bosco49 is offline Find More Posts by bosco49
Old Apr 15, 2010, 12:32 PM
rc4fun is offline
Find More Posts by rc4fun
Maryland
Joined Dec 2002
Why not glue some plywood (say 3/16 or 1/4" x 1 x 1/2) flush with the fuse and use a screw in 'L' hook. Then you could move it if needed?
rc4fun is offline Find More Posts by rc4fun
Old Apr 15, 2010, 01:42 PM
williamson is offline
Find More Posts by williamson
Joined Feb 2006
When putting plywood into the fuselage, watch out for the plastic tube in which the antenna runs. That tube is about a quarter inch up from the bottom of the fuselage.
The sweet spot for a tow hook on the glider version of an Easy Glider is right at the rear of the recess for the supplied plastic tow hook. However, that doesn't help you too much because your Easy Glider has no recess.
williamson is offline Find More Posts by williamson
Old Apr 15, 2010, 02:30 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Dick helped dial in Nicks' Easy Glider last year at the Easy Glider Contest at Davis Field.
Until we moved the tow hook back, it simply wouldn't stop popping off.
I drilled a hole then and there, and Ken, I think, gave me a piece of L-bend with one end threaded.
I ca'd a piece of hardwood into the hole I drilled, and screwed the hook in with some more ca.
Worked like a charm.
If you want, I will go and measure exactly where we put it.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Apr 15, 2010, 03:12 PM
DLD is offline
DLD
Find More Posts by DLD
DLD
David Layne
Tracy, Ca
Joined Jun 2004
Directly under CG is usually best. If you want to be extra-safe, move it forward a bit, maybe 1/4 inch. Best is to make it adjustable, start a little forward of CG and move it back until you get the launch you want, or until it starts to get unstable on tow.
Good luck,
DLD
DLD is offline Find More Posts by DLD
Old Apr 15, 2010, 07:13 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
Kenny Sharp would you do that measure for me,thank you....I have a 2.4 system so no antenna tube....Do you all see the line I made on the pace of plywood....So that line would be about 1/4 inch forward the CG line ''DLD''?
Old Apr 16, 2010, 05:27 AM
turn, turn, turn.
Joined Oct 2005
Exactly 2 3/4 inches from the leading edge of the wing.....works great!
Interestingly, the stock tow hook is 1 1/2 inch from the leading edge!
Old Apr 16, 2010, 08:34 AM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
So Kenny that the hot spot.....Thank you guys for info.
Discussion CG and tow hook position Thews Sailplane Talk 6 May 22, 2010 03:02 AM
Found Airtronics Releaseable Tow Hook ldm1839 Aircraft - Sailplanes (FS/W) 2 Apr 01, 2010 06:33 PM
Discussion Ava Pro Tow hook P-51flyer Thermal 19 Mar 25, 2010 06:16 PM
Where should I put the Tow Hook? rc_ron Sailplane Talk 3 Nov 13, 2004 10:21 PM
Where to put the tow hook? Peter Young Thermal 10 Sep 18, 2003 11:46 PM
