Old Apr 14, 2010, 12:22 AM
bwanajim is offline
Find More Posts by bwanajim
Circles in Lift
bwanajim's Avatar
Redmond, Washington, USA
Supra Pro Competition Pushrod Question
Quick Q for those of you who have built a new Supra Pro Competition...
The pushrods are preinstalled in the boom in these new planes, and they exit the boom together on one side. You can't really separate them and run them on either side of the ballast tube like on the previous Supra Pro. For those of you who have built these new planes, how did you handle this? Did you run them forward into the pod together, and have the elevator and rudder servo arms on the same side, bending the nylon arms for clearance or shimming up the forward servo? Or did you somehow separate the pushrods and run them on either side of the pod as before? I couldn't get them separated without increasing pushrod friction unacceptably.
Thanks - Jim Laurel
bwanajim is offline Find More Posts by bwanajim
Old Apr 14, 2010, 04:58 AM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Jim,
I used the same trick on the Supra Pro Comp as I did on the Sprite. Mount one servo on the top of the tray, and the other from the bottom. This will give the necessary separation height in the servo arms so the clevis' won't interfere with each other. I did separate the rods for an inch or so from the canopy end to allow the rods to move a bit more independently and not have the stationary one stress the moving one.
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Apr 14, 2010, 10:01 AM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
jaizon is offline Find More Posts by jaizon
Old Apr 14, 2010, 03:17 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
Jim,
Here's another option as per Kennedy's builder.
Preston
Old Apr 14, 2010, 04:45 PM
bwanajim is offline
Circles in Lift
bwanajim's Avatar
Thanks, guys. Pretty much confirms my thoughts as well. The pushrods do run smoothest when they are both on the same side of the pod. Will do them same as the Sprite. I've got three of 'em to build, so better get crackin'!
Old Apr 14, 2010, 05:40 PM
varoman1 is offline
Find More Posts by varoman1
Joined Nov 2004
I did exactly what JT suggested in his reply above. I used 2-56 bolts to secure the servos. The rear servo mounted under the tray while the front servo went on top.
I flew my Supro Pro Competition today for the first time. Wind was 8mph. Plane weighs 57.25 oz. Cg at 103mm from wing leading edge. The trailing edge of the stab is 38 mm from the top of the boom. This gave a nice launch off a high start. My tow hook is 13 cm from the rear boom to fuse seam to the center of the vertical part of the hook as it goes into the fuselage. Did not need to bring extra underware! It was fantastic.
Thanks to D. Hauch, Ron Mong and D. Harris for their good advice!
Andy
varoman1 is offline Find More Posts by varoman1
Discussion Supra Competition Bobalew Multi Task F3X 15 Feb 17, 2010 11:27 AM
Question Supra Pro Competition questions ozmo01 Sailplane Talk 7 Dec 01, 2009 09:44 PM
Discussion Molded Supra pushrod exits old dodger Thermal 16 Feb 03, 2008 09:45 AM
