Old May 01, 2010, 07:47 PM
AnnihilaT is offline
Find More Posts by AnnihilaT
Joined Apr 2005
Success!
So... I have some good news to report. This project is a success! It works!
On the advice of a friend i ended up using an HEF4010 instead of the other two IC's mentioned earlier and this one worked a charm right from the start. This buffering issue was indeed my only problem. Very happy with the results.
Range is at least 1-2 meters (which is more than I need for this application) with an antenna of 23cm on the transmitter only. For some reason beyond my understanding, when i attach any sort of antenna to the receiver, it practically kills reception and range becomes very short and unreliable.
I've attached some pictures of the "Revision 1" modules. The wireless headtracker module will be built into a pair of Fatshark goggles and the trainer port "dongle" will eventually be refined to look nicer, be less in the way, and the entire system will be modified to still accept a PPM signal in for buddy boxing.
Pretty happy with the results and I appreciate the advise and comments the two of you (Rich and Ian) gave me. Helped alot!
AnnihilaT is offline Find More Posts by AnnihilaT
Old May 01, 2010, 08:03 PM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Those 4000 series are great. Even though older than LS they are still popular. They work from 1.5-12v and it tales almost nothing to drive them.
I'm shocked that buffering was the problem. The OOK units I have including those from Sparkfun had plenty of drive from the LM358s. Good job.
rich smith is offline Find More Posts by rich smith
Old May 01, 2010, 08:38 PM
Joined Apr 2005
In case anyone else would like to try this, Here is a list of the parts i ended up using:
Transmitter and Receiver modules:
http://www.sparkfun.com/commerce/pro...oducts_id=8945
http://www.sparkfun.com/commerce/pro...oducts_id=8947
(23cm antenna on the TX)
Hex Non Inverting buffer (HEF4010 / HCF4010):
http://pdf1.alldatasheet.com/datashe...S/HCF4010.html
5V regulator for receiver module:
Any will do. I actually used the BEC from an old tiny 10A brushed ESC. It was small and gave me the +5V i needed for the RX module from the 9C trainer port.
The 4010 IC needs voltage to pins 1 & 16. Signal goes in on pin 3 and comes out buffered on pin 2. Ground to pin 8.
PPM out from your headtracker goes on the data pin of the TX module and you should see the PPM train on the data pin of the RX module.
Earlier in this thread there is a picture of the Futaba 9C trainer port pinout. One of the voltage pins will give you voltage regardless of whether the Futaba radio is on or off and the other will only give voltage when the radio is on. I used this one. Data out pin from your RX module goes to PPM IN of the futaba radio and you will need to regulate the +/-12V from the Futaba radio to between 4.5 & 5.5v for the RX module.
That's all there was to it.
All in all, it was maybe 15 USD in parts to build this wireless conversion and for me its absolutely worth it to not have to worry about that stupid cable between my head and my radio anymore. i can set my radio down with out worrying about ripping my goggles off my head and its one less thing to have to carry around with me.
Old May 02, 2010, 04:45 AM
IanJ is offline
Find More Posts by IanJ
Aberdeen, Scotland, UK
Joined Dec 2007
Thats the FET inputs of the CMOS 4000 series working for you, i.e. next to no current.
Nice one!, glad to see another problem solved.
Ian.
IanJ is offline Find More Posts by IanJ
Old May 02, 2010, 05:04 AM
Joined Apr 2005
Thanks Ian!
@Rich: Did the OOK units from spark fun that you used have a datasheet ? Im curious because the ones i used clearly stated that 10 uA was the max output current. In the beginning i just didnt know what that meant.
EDIT: The ones im using are ASK not OOK... if im correct thats something different so maybe even we are talking about different modules here?
Old May 02, 2010, 05:43 PM
rich smith's Avatar
Joined Dec 2006
I picked them up from Sparkfun a cuople years back and they look very similar to your link. Not sure if I even downloaded or looked at specs from them. It's possible they have changed. Of the dozen or so different types none are as weak as 10us. That strikes me as almost useless. Your results are pretty clear though.
Old May 02, 2010, 05:45 PM
Joined Apr 2005
yeh i was just checking into it again and realized these ones i used are ASK and not OOK (I believe thats something fundamentally different?) so im thinking prolly I used something a bit different than you had.
Old May 02, 2010, 05:48 PM
Joined Apr 2005
One last vid showing a bit more of the system working:
Wireless Headtracking module (2 min 37 sec)
Old May 02, 2010, 05:59 PM
rich smith's Avatar
Joined Dec 2006
yeh i was just checking into it again and realized these ones i used are ASK and not OOK (I believe thats something fundamentally different?).
Nope, ASK (Amplitude Shift keying) = OOK (On-Off Keying)
Who knows, the important thing is you got it working. You've discovered as I did, PPM does work over short distance because it is a continuous signal unlike rs232.
Old May 04, 2010, 04:12 PM
mrfliboy is offline
Find More Posts by mrfliboy
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Excellent work here. I'm thinking of giving this a shot. Is there a basic schematic here?? I believe I understand the components, just the actual wiring?? Thanks and great work.
mrfliboy is offline Find More Posts by mrfliboy
Old May 04, 2010, 05:50 PM
Joined Apr 2005
It's such a simple circuit im not really sure a schematic is needed... have a look here:
http://www.rcgroups.com/forums/showp...8&postcount=33
if you still have any questions about the wiring just ask and let me know what you dont understand and ill help the best i can
Old May 04, 2010, 07:08 PM
mrfliboy is offline
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
http://www.rcgroups.com/forums/showp...0&postcount=25
Another diagram part of the equation?
Old May 20, 2010, 01:11 AM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
Ordered the parts tonight. Looks to be exactly what I was lookin for!!
braindead4554 is offline Find More Posts by braindead4554
Old May 20, 2010, 03:01 AM
Joined Apr 2005
This chip isnt actually used anymore... during planning i was going to use one of these but did not in the end.
Old May 20, 2010, 03:02 AM
Joined Apr 2005
Good luck! BTW, What frequency did you order and also which frequency are you using for your video link?
Discussion Help with DX7 tx and AR500 rx Rydogg420 Radios 5 Mar 19, 2010 02:48 PM
Question might a bandpass filter help with 2.4 V-Tx locking out FASST Rx? lichy FPV Talk 9 Oct 24, 2009 08:02 AM
Discussion Futaba 14MZ modules with serial data instead of PPM? village_idiot Xtreme Power Systems 2 Jan 10, 2008 10:36 AM
Discussion New serial checksum RX protocol instead off old PPM? LoopForEver DIY Electronics 13 Jun 11, 2007 11:51 AM
Need help with TX serial cable to Belkin serial to USB converter. ggood Simulators 4 Sep 23, 2006 09:58 PM
