Old Apr 12, 2010, 10:09 PM
bnixy7 is offline
Find More Posts by bnixy7
Grand Rapids, MI
Joined Mar 2010
Help!
OS 91FX Engine Prop question
I am getting some conflicting information and im hoping someone either with this engine or someone who knows can just help me...
I just got a OS 91FX ringed engine and the manual says for prop selection to be 15x8, 16x6-8, 17x6, or 14x7 (3-blade), and a friend of mine showed me the OS website and it says 13x8, 13x9. CONFUSED!! Anyone suggest a break-in prop? Its going on a Cessna 81" Top Flite from towerhobbies. Thanks guys
bnixy7 is offline Find More Posts by bnixy7
Old Apr 13, 2010, 01:48 AM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
Please remember that prop selection is in fact more about the airframe than the engine. Are you wanting to prop for power or torque. Or speed verses climb.
But for your engine I would work with the 15 to 16 inch props unless you are looking for some extreme performance that is outside then norm for sport flying.
http://www.osengines.com/engines/eng...continued.html
There is a typo on this site. For break in use a prop that will be about 1 inch in diameter or 2 inches in pitch smaller that what you think you will need to fly. Actually it more about keeping the engine near the operating RPM point while she is running rich than it is about any flying prop. So what kind of RPM are you looking for?
Friends don't let friends fly nickel,
Konrad
Konrad is offline Find More Posts by Konrad
Old Apr 13, 2010, 04:46 AM
ronwc is online now
Find More Posts by ronwc
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
prop
14x6 15x6 14x7 13x7 13x8
ronwc is online now Find More Posts by ronwc
Old Apr 13, 2010, 09:56 AM
bnixy7 is offline
Grand Rapids, MI
Joined Mar 2010
Im basically looking at general scale flying. Not many loops or anything are going to be performed. I just want a solid looking plane with a real smooth flight. I guess if anything its going to be speed because climbing is not going to be an issue. It would be gradual with my airplane.
I currently dont have a tach to get my rpm readings from other planes but im assuming just basically a solid RPM right before the max out because I never like to run my engine totally maxed. Plus its a plane set for a .60 engine so a 91 2 stroke is going to be plenty of power anyway.
I do currently have a 15x8 because that's what i saw in the manual so I went and bought that. Konrad, am i going to be good with using this for break in's? it suggests a 16x14 for break in on the os page.!!!!!!!! I thought the point was just a prop to help it run, not appear to wanna kill it! haha any help? thanks!
Old Apr 13, 2010, 10:46 AM
Konrad is offline
Everett Wa.
Joined Jun 2001
That is one of many typos on that site. I would look to use a little smaller prop to break in the engine, but it is not critical
Old Apr 13, 2010, 11:08 AM
bikeman is offline
Find More Posts by bikeman
bikeman's Avatar
United States, PA, Ephrata
Joined Dec 2005
14x6 for break in on that engine with stock muffler.
bikeman is offline Find More Posts by bikeman
Old Apr 13, 2010, 02:48 PM
bnixy7 is offline
Grand Rapids, MI
Joined Mar 2010
after break-in can i use the 15x8 or should i return it?
Old Apr 13, 2010, 03:20 PM
Konrad is offline
Everett Wa.
Joined Jun 2001
The 15x8 is on the heavy side but recall that OS is trying to pull the RPM down to help make the engine quieter. If your ship is on the lighter side of the recommended range (for the engine) I would try the 15x8 if you don't need to find more power by going up the RPM band? I like to 8 inch pitch prop. As you will need pitch speed to make the wing generate lift.I recall that OS says max power is developed at 16K rpm. This would need something like a 12 inch prop to get the OS to spin that fast.
Old Apr 13, 2010, 04:54 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I started with an APC 15x6 on my Shoestring with OS 91FX but switched to an APC 16x6. I liked it better with the 16x6 so I left it there.
Ivan
ivanc is offline Find More Posts by ivanc
Old Apr 13, 2010, 10:54 PM
Rube Goldberg is offline
Find More Posts by Rube Goldberg
Joined Dec 2006
I recently acquired a Sig 1/4 scale Cub that had an older 90 or 91 OS engine...maybe an FSR. Anyway the previous owner was running a Zinger 16X5 on it and I can tell you the Cub needs about 40% power to rotate and climb out. Full throttle pulls very hard with that prop.
Rube
Rube Goldberg is offline Find More Posts by Rube Goldberg
Old Apr 14, 2010, 04:20 PM
bnixy7 is offline
Grand Rapids, MI
Joined Mar 2010
im going to break-in with the 14x6 and hopefully it take off with it :P
Old Apr 14, 2010, 06:44 PM
ronwc is online now
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
Very good choice -
Old Jan 31, 2014, 12:35 PM
mlstevens is offline
Find More Posts by mlstevens
United States, NH, Concord
Joined Aug 2005
apc 15x4 works good with larger fun fly.
mlstevens is offline Find More Posts by mlstevens
Old Aug 03, 2014, 01:51 PM
moisesh is offline
Find More Posts by moisesh
United States, TX, McKinney
Joined Oct 2009
I know its's an old thread, but wanted to share. 15x8 is the minimum 2-blade size prop for the 91fx. I used the smaller 14" due to clearance issues in my UltraStick 60 and the engine would over-rev and die during certain dive / aerobatic maneuvers (not even all-out aerobatic, just "spirited" sport flying). I mean a dead stick every flight unless I just few circles. Switching to 15x8 solved the problem. Now my problem is not enough clearance so will look into either a 3-blade prop or taller landing gear.
moisesh is offline Find More Posts by moisesh
For Sale OS .91FX excellent $140 aerowoof Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 06, 2010 03:34 PM
Sold OS Max FP .40 engine with muffler and prop run only 3 times $37 shipped planebldr Aircraft - Fuel - Engines and Accessories (FS/W) 4 Dec 20, 2009 11:57 AM
Discussion OS 91FX 3 bladed prop pryor808 Fuel Plane Talk 2 Jul 04, 2009 07:29 PM
Sold OS 91FX Engine chris8105 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Oct 27, 2006 12:28 PM
Sold OS 91fx engine Steve H. Aircraft - Fuel - Engines and Accessories (FS/W) 4 Aug 05, 2006 05:45 PM
