Here's a Miss Wind 50 "walkaround"
Looks like there'd be room to move the battery to adjust CG. Anybody confirm this? edit: http://www.hacker-motor.com/deutsch/ lists a couple of different suggested setups: 5S Setup A50-14S MasterBASIC 70SB APC Thin Electric 16x10 1x TopFuel Hacker 30C 3800mAh 5S 6S Setup A50-16S MasterBASIC 70SB APC Thin Electric 16x10 1x TopFuel Hacker 30C 3800mAh 6S |
Here's a couple pics of my battery installation. As noted, the 6s pack needs to go back quite a ways making it difficult to add a velcro wrap to the rear of the pack. I have a 'stop' on the floor to prevent the pack sliding rearward, as well as a 1/4 sq bar across the bulkhead to hold the rear in place. The front in velcroed in place. I little sandpaper keeps the pack fixed from sliding and a couple more 1/4 sq scraps stop it from sliding forward. I'm finding I'm a little nose heavy at the moment so may need to tweak the location a little to move the pack back a bit, or add a small weight in the tail. I may do that first until I nail down the best CG, then use the battery position to allow removal of the weight.
I got 5 more flights this morning (I have 5 6s packs so I don't need to wait for charging at the field...very efficient ). I'm averaging about 7-7.5 mins of flight time and putting about 2300-2500mAh back in the 5k packs. I'll continue to watch this as I get more comfortable and wring out the model more and more. I've pulled no more than 64.4Amps on the controller so maybe I could have go away with a light ESC than the phoenix Ice 100. I do like the data it provides however.
For inspiration for those on the fence about getting this model.
![]() http://airtoimedia.nl/web/upload/vdVechten/MissWind.wmv |
| Thread Tools | |
| Discussion Sebart Angel S 50E with a Hyperion ZS 4025-14? | RobC(UK) | Sport Planes | 4 | Mar 22, 2010 07:12 AM |
| Help! Advice for powering a SEBART MISS WIND 50E | claude_3d | Power Systems | 3 | Dec 04, 2009 12:08 PM |
| Discussion Sebart Katana S 50e or Sukhoi 29S 50e for 5s 4900 | sideway5 | Electric Plane Talk | 0 | Nov 25, 2009 11:23 PM |
| Sold Sebart Miss Wind 50E Bieplane | Tommyb240 | Aircraft - Electric - Airplanes (FS/W) | 7 | Sep 18, 2009 10:50 PM |
