Old Apr 12, 2010, 04:23 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Question
what usual setting are used when coupling elevator to flaperons
and do they differ from airfoil to airfoil? say for a RG15 foil.... if I want a frontside plan to snap thru a pylon turn.. I know the basics on how to couple flaperons (i.e. flaperons down a couple degrees, elevator up a few degrees)
I guess my question is ..what are the rules of thumb you all use? (if there are any)
and how can you tell when you've put in too much of one or the other... ? or not enough? just trying to optimize my settings..
thanks
grfcon is offline Find More Posts by grfcon
Old Apr 12, 2010, 05:42 PM
screamin' eagle is offline
Find More Posts by screamin' eagle
R/C Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
You can spend a lot of time setting up snap-flap correctly on a given airplane. Essentially I eyeball it at the outset and then tweak the amount of down travel on the flaperons until max efficiency is achieved (sharpest turn with least loss of speed). You will want to program in some deadband around center as well so you're not pulling brakes while flying level. Also, make sure your elevator stick is set up so that you don't have excess throw - otherwise you'll never get to pulling full snap flap because you're never pulling full elevator.
As you increase the snapflap, you'll get more momentum out of the turn until you hit the max efficiency. More than that and it will start to burn off speed in the turns. Dial it back down at that point.
Most of the above was related to me by Target and I found it extremely helpful.
EDIT - PS my RG15 planes have liked snap flap, but a few milimeters. The amount will vary dependent on the width of the control surfaces relative to the wing, CG and I believe tail moment. Your best bet is to find someone with the same plane and cop their settings.
screamin' eagle is offline Find More Posts by screamin' eagle
Old Apr 13, 2010, 01:11 PM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thanks D. Now if I can find someone with an old renegade.....
Old Apr 14, 2010, 07:24 PM
samotage is offline
Find More Posts by samotage
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
usually I adjust the magic setting to 4.5
samotage is offline Find More Posts by samotage
Old Apr 15, 2010, 12:59 AM
oldscooler is offline
Find More Posts by oldscooler
Ask me about VTPR
oldscooler's Avatar
America
Joined Aug 2002
Go to CR Aircraft. Chip may have one or he would be glad to set you up with a ARF or kit.
E...
oldscooler is offline Find More Posts by oldscooler
Old Apr 15, 2010, 01:16 AM
Sensiblenick is offline
Find More Posts by Sensiblenick
Tearing the Skies a new one...
Sensiblenick's Avatar
Sweden: Ystad
Mine go to 11.
Sensiblenick is offline Find More Posts by Sensiblenick
Old Apr 15, 2010, 12:44 PM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thx
Discussion What kind of person are you when upset jumpinjo Life, The Universe, and Politics 20 Mar 23, 2010 03:06 PM
Question Aileron/elevator coupling - HOW ? RonJ Electric Plane Talk 4 Mar 06, 2010 06:46 AM
Discussion Setting up DX6i for flaperons on Corsair? Swaneyjoe Electric Warbirds 6 Feb 21, 2010 11:02 AM
Discussion What to do when spoiled by ailerons and no cross-coupling? Jim_Marconnet Electric Plane Talk 8 Jan 19, 2010 04:10 PM
