Old Jun 03, 2003, 08:56 PM
mitchamus is offline
Find More Posts by mitchamus
wheel chock
mitchamus's Avatar
NSW, Australia
Joined Nov 2002
getting former section from a 3 view -Autocad
Can anyone direct me to information on how to do this?
I have traced out a 3-view and want to extract sections to create the fuselage formers.
I tried to use solid>section but nothing really happened once I had selected my 3 points.
Mitch.
mitchamus is offline Find More Posts by mitchamus
Old Jun 06, 2003, 11:18 PM
John Boren is offline
Find More Posts by John Boren
John Boren's Avatar
Colorado
Joined May 2003
I've read this post several times but I can't figure out what you are trying to do with the solid>section part. Our you trying to ask AutoCad to generate a half dozen or so fuselage cross sections between two sections that you have created? If so I believe you have to do your drawing in solid modeling.
John Boren
John Boren is offline Find More Posts by John Boren
Old Jun 07, 2003, 10:16 AM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
I'm not using my AC2K very much, but in DesignCAD3K it's "slice by plane" or "plane slice" for solid objects and "plane intersect" for wire frame. The working plane is set and oriented to the former positions for this. These work in 3d modes ("3-view" implies 2d). Maybe this helps?
Gary Warner is offline Find More Posts by Gary Warner
Old Jun 09, 2003, 05:30 PM
wheel chock
mitchamus's Avatar
NSW, Australia
Joined Nov 2002
what I'm trying to do...
I have a basic 3 view of a fuselage,
What I want to do, is using a front view and a side view, extract my former (bulkhead) shapes.
cheers,
mitch.
Old Jun 09, 2003, 06:05 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
I think you will want to use the top and side views to extract the "major" cross section dimensions. You will have to interpret the exact shape within the bounds of the major cross sections.
A head-on only view typically only shows the shape at it's maximum cross section, and maybe a few other shapes at certain stations (like a ray-dome cover, windshield, etc.), though you should be able to get the basic shape. It will depend on the plane you're trying to make.
What's the plane you're trying to model?
Old Jun 09, 2003, 06:20 PM
wheel chock
mitchamus's Avatar
NSW, Australia
Joined Nov 2002
It's the global Hawk UAV
A-10 From 3-view to 3-D Build JasonJ Electric Ducted Fan Jet Talk 9 Oct 17, 2007 04:17 PM
Question HELP rhino airplane from 3 view Doc Dyer The Builders Workshop 6 Jul 21, 2004 04:58 PM
Getting from a 3 view to a flying model? Ado Electric Ducted Fan Jet Talk 20 Feb 22, 2003 04:41 AM
How to get from a 3 view to a flying model? Ado Slope 4 Feb 19, 2003 04:36 PM
