Old Apr 11, 2010, 09:19 AM
Barthez is offline
Find More Posts by Barthez
PMBC
Barthez's Avatar
Joined Oct 2005
My build of Egrette a Rhine pusher tug and barge
I usually only build warships but I decided over Christmas to build a tug. I built a springer hull and a bit of superstructure but, never completed it. I stopped because I saw a plan for a crawler crane and barge on the Springer forum. This set me wanting to build a scale tug. I got a second hand plan for the Rhine pusher tug Egrette published in Model Boats in the UK.
The boat is of all plasticard construction. I built it with a lot of internal ribs and used plastic weld in liberal quantities this has given the starved dog effect that you see on modern welded ships. I will see how effective it is when it's painted.
I can't sail this weekend so I am making a barge from 6mm plywood for the crane more pics to follow.
Bart
Barthez is offline Find More Posts by Barthez
Old Apr 11, 2010, 09:46 AM
Barthez is offline
PMBC
Barthez's Avatar
Joined Oct 2005
A few pics of the crawler crane cab, pasticard for the most part with blocks of balsa shaped to aid the skin being bent to shape. I will make the boom from square plasticard tubing.
The tracks were made from plasticard. I made four formers then used a jig to attach strips at an even spacing to simulate the tracks, I was about .5 mm out on the last track, the larger gap is hardly noticeable.
bart
Old Apr 11, 2010, 01:10 PM
pops52 is offline
Find More Posts by pops52
pops52's Avatar
United States, OH, Richfield
Joined Aug 2007
Very nice Barthez. Please keep posting you progress.
pops52 is offline Find More Posts by pops52
Old Apr 12, 2010, 12:40 PM
Barthez is offline
PMBC
Barthez's Avatar
Joined Oct 2005
thanks pops, wish I had seen your heavy lift barge post before I started on my crane. I built the basic barge this weekend out of ply wood and given it a quick coat of resin to seal it so I can get the ballast right.
Old Apr 12, 2010, 12:45 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Barthez what do you cut the plastic with? Your work is very nice and the boat and the crane are looking great. Pete
norgale is offline Find More Posts by norgale
Old Apr 12, 2010, 02:23 PM
Barthez is offline
PMBC
Barthez's Avatar
Joined Oct 2005
Thanks Pete, I score the plasticard with a stanley knife then bend it to snap it off.
Bart
Old Apr 12, 2010, 02:24 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Barthez, I remember the article and plans for the Egrete in "Model Boats" from quite a few years ago. I believe it was written by Davis Metcalf?
A very interesting model.
I still have that issue somewhere---.
der kapitan is offline Find More Posts by der kapitan
Old Apr 12, 2010, 03:17 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Great work putting all this together.
Especially so, using "plasticard".
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Apr 12, 2010, 05:06 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Very nicely done so far. With all that plastic bracing, almost looks real. Just need to paint that interior with some steel paint or greencoated like in the shipyard. That crane is going to be a peice of art in of itsself!! Keep the photos a comming and thanks for sharing.
keith S is offline Find More Posts by keith S
Old Apr 17, 2010, 05:24 PM
Barthez is offline
PMBC
Barthez's Avatar
Joined Oct 2005
Thanks guys
Kaptain, your are correct it is the David Metcalf plan that was in model boast in 1988.
Work got in the way of model building this week but I still managed to get a bit done on the barge. I am experimenting with a water ballast tank. I did a test with two plastic containers filled with water. I made a tank in the centre of the barge and coated the inside with resin.
I put a lid on it but and set it in the test tank (wifes pond) It would not sink !! The tank only got a few mm in it and the barge stayed where it was. I suspect its the buoyancy in the plywood. If I pressed down on the hull the tank would fill so I know the air can escape.
The water was only going to be part of the total ballast, so I will try again tomorrow with some shingle ballast to help the barge sink to its water line, before I stick the deck in place.
The bow of the boat has four roller fairleads, The plan calls for them to be built from plastic tube. I decided to build mine from brass as I would be passing ropes from through them, I needed mine to be more durable.
I will order the metal for my running gear this week and try and get the barge fininshed.
bart
Old Apr 18, 2010, 07:42 PM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Nice fairlead! And a cool build.
Jerome Morris is offline Find More Posts by Jerome Morris
Old May 25, 2010, 07:39 AM
Barthez is offline
PMBC
Barthez's Avatar
Joined Oct 2005
I have been a bit busy with work and other hindrances to modeling of late, I have made some progress with my tug. I made a simple interior for the bridge and completed the scissor mechanism from left over acrylic green house glazing and made up the guardrails.
Next job is to fit the running gear and make up the smaller fittings and fit leds for lights.
Can't wait to paint it and make the bridge detail stand out.
Bart
Old May 25, 2010, 01:31 PM
Joined Jun 2005
Thanks for giving the date on the Egrete article, Bart.
It has saved me hours of rummaging through piles of magazines---.
Old May 25, 2010, 02:35 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I missed the roller chocks shown earlier... very nice.
As is the pilot house details.
Old May 25, 2010, 05:12 PM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
What is plasticard and where do you get it. Looks like great boat building stuff. Pete
Discussion My Build of Abeille Bourbon salvage tug ezhie Scale Boats 19 Mar 30, 2011 08:41 AM
Help! My long awaited pusher build! Time for blades!!!! HyperHelis Auto Gyros 17 Sep 25, 2009 01:33 AM
Gallery My company's Articulated Tug&Barge Greg Hiltz Dock Talk 10 May 12, 2009 05:48 PM
Question Tug Boat Barge Tmblewd Scale Boats 5 Sep 04, 2007 04:07 PM
Gallery Articoupled Tug & Barge photos Greg Hiltz Scale Boats 4 May 11, 2006 03:56 PM
