Old Apr 12, 2010, 07:09 PM
aeronot is offline
Find More Posts by aeronot
'Lectric Aficionado
aeronot's Avatar
USA, TX, San Angelo
Joined Mar 2006
Cool! I have a 4x3 mm carbon tube spar 15" long about midway and my CG is 4&3/4" from the front of the disc.
Your elevons look smallish (at least in the pic they do), but you can always cut bigger ones if you need to. Mine are 4" from back of disc to hinge line with a 1" forward sweep to the outer edge. It seems that pi planes thrive on lots of control surface.
Have fun!
Mark
aeronot is offline Find More Posts by aeronot
Old Apr 13, 2010, 09:57 PM
sr71fan is offline
Find More Posts by sr71fan
Flying...Pushing Air Down
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Mark,
Build me one of them, will Ya?
Gary
sr71fan is offline Find More Posts by sr71fan
Old Apr 13, 2010, 10:18 PM
aeronot is offline
'Lectric Aficionado
aeronot's Avatar
USA, TX, San Angelo
Joined Mar 2006
Sure, right after you...............
oh never mind, I don't wanna!
Old Apr 13, 2010, 10:23 PM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Old Jun 24, 2010, 12:23 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Some places 9mm EPP can be found
http://rcfoam.com/
http://flyingfoam.com/
http://rcskyflyer.com/
Re-drawn because the design evolved for the better!
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jun 24, 2010, 02:52 AM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
How 'bout an outdoor video. Another interesting circle. Can't hardly make a bad disc plane or delta. Nice... Might just have to convert my wannabee triple threat to that if I can get a rudder servo far enough forward with out having to move the elevon servos. I haven't been flyin it lately. I have liked adding big rudders to previously elevon only planes as of late too.
tymbrewolf is offline Find More Posts by tymbrewolf
Old Jun 25, 2010, 07:44 PM
RCSkyFlyer is offline
Find More Posts by RCSkyFlyer
EPP Foam is Good
RCSkyFlyer's Avatar
Southern California
Joined Sep 2006
Thanks rick.benjamin for mentioning us, much appreciated sir
RCSkyFlyer is offline Find More Posts by RCSkyFlyer
Old Jun 26, 2010, 12:24 AM
Joined Feb 2007
Old vert stabs removed. New fuse cut out, rudder attached. Just a little paint added. Reduced by 10 percent as my disc was 16".
BTW, I really like my WTT especially since it stores so easily. But recently ( a few months the last time I flew it) I thought it just wasn't holding very well in hi alpha slow. I went a head and made the yak fuse and then proceeded to remove my verts. Guess what, my center vert was cracked on the bottom and half loose on the top so that she was free to hinge right rudder in flight which was why I needed to hold left. I sure hope the new piyak holds up to how I think it will as I am getting fond of elevons and rudders as the WTT could be thrown in about anywhere and go fly. That is probably why the vert is loose.
Last edited by tymbrewolf; Jun 26, 2010 at 07:14 AM. Reason: I really like the WTT as well!!!
Old Jun 26, 2010, 08:08 AM
Joined Feb 2007
Fuse just set on. May finish by the end of the weekend. I hope I won't need to move the elevon servos forward to balance, But, I fear I might...
Old Jun 26, 2010, 08:32 AM
Joined Feb 2007
BTW, did you notice that the plan canopy placement differs from the prototype. The canopy placement in the prototype gives a fun almost cartoonish appearance in my opinion, the placement of the canopy in the plan gives more of the muscle car look.
Old Jun 26, 2010, 11:23 AM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Two different Yaks, two different canopies. One's for fun, the other serious business. Although having fun is serious business.
goldguy is offline Find More Posts by goldguy
Old Jun 26, 2010, 06:12 PM
Joined Feb 2007
Waiting on some calm. Third pic shows my little triple strength bottom as that seemed like a weak point to me. Not very pretty as it was a fairly worn plane prior to the transformation. Should fly well though. This won't be floaty like aeronot's, but it will be an outdoor breezy flier anyway...
Old Jun 26, 2010, 10:15 PM
Joined Feb 2007
200 sq. in. area. Weight 176g with 500 mAh 2s. 4.32 oz/sqft.
Old Jun 27, 2010, 10:35 AM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
Looks great wolfie. The Piplane is a great design, so you'll have a load of fun with it.
Old Jun 27, 2010, 10:44 AM
Joined Feb 2007
A couple of videos from this morning. Flies nice.
maiden
PiYak maiden flight.wmv (5 min 36 sec)
Full rates
PiYak on full rates.wmv (3 min 53 sec)
Discussion How about an indoor micro kite? del Scratchbuilt Indoor and Micro Models 7 Nov 22, 2013 10:06 AM
Question How about a ww1 monoplane?? sidecar53 Foamies (Scratchbuilt) 4 Apr 10, 2010 01:24 PM
Discussion How about we help Rick out MattinAZ Gilbert Quiet Flyers (Arizona) 25 Apr 08, 2010 08:12 PM
Discussion how does one go about charging several batteries vygec Batteries and Chargers 16 Mar 24, 2010 05:20 AM
