Old May 10, 2012, 12:02 PM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Don't forget to place the equiptment in a fashion so as to balance it nose to tail as well.
goldguy is offline Find More Posts by goldguy
Old May 11, 2012, 05:18 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
With disk planes the acceptable CG range is very narrow , and although we try our best, sometimes the CG does not end up where exactly we want it (or where the plane wants it) ... So we always resort to the old “lump of Clay”on the nose (no, not our nose, the plane’s ) ... an ample supply carried in the field box for just such occasions... Perfect for “fine tuning” of the flying properties ..
The small bit of added extra weight is much offset by the improved flying qualities...
Just thinking that if one did extend the nose a bit for better balance , the side area should be kept to a minimum (no implied radials /cowlings ) ... or maybe even just an extended motor stick ... but then it wouldn’t be a Yak , not that it’s even close now ...
gpw is online now Find More Posts by gpw
Old May 12, 2012, 01:09 PM
UBILDIT is offline
Find More Posts by UBILDIT
Victoria Super Mortem
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Ahhhh! That's Better
O.K. the picture is just an edited version of the first one.. Rudder servo is now forward. The dark shaded areas on the rudder itself ... I milled 3mm of foam out of each side in the shape of the shaded area... but after all that.. the best thing I did was glide test it , only to find that in a glide it was quite nose heave... so I unglued the two bamboo skewers holding the upper part of the motor in place and gave it a bit of down thrust, which apparently was actually level or maybe slightly down.. and it will now fly with a 450 mah battery instead of an 800 and the handling with all input... especially rudder is outstandingly better... thanks for ya'lls input...
Bo
Oh, also.. moved receiver and esc forward as suggested... rock on...
UBILDIT is offline Find More Posts by UBILDIT
Old May 12, 2012, 04:30 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
That sounds much more fun now!
tymbrewolf is offline Find More Posts by tymbrewolf
Old May 19, 2012, 04:31 AM
brett.c is offline
Find More Posts by brett.c
Foam is where the heart is
brett.c's Avatar
Australia, NSW, Sydney
Joined Aug 2010
I've had about 8 flights with my 18inch piyak and I'm starting to get the hang of it.
I ditched the landing gear because it flew much better without.
Throws are now set to the maximum for maximum fun.
Down elevator is a little savage but up and roll controls are fine.
Rudder travel may be a little too much because she'll corkscrew towards mother earth on full travel. However that does make for some rather interesting manoeuvres.
Pretty tough too. I've doinked a few times with no ill effects.
Great little plane
brett.c is offline Find More Posts by brett.c
Old Feb 28, 2013, 10:29 PM
Joined Feb 2007
I thought this needed a little bump as many may have not seen one of the best designs on the planet...
Old Mar 01, 2013, 06:06 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Canada, ON, Ayr
Joined Apr 2010
Although most of my fleet is balsa, there is always a piYak raring to go. Still one of my most favourite fun planes.
If you haven't built one, what on earth are you waiting for?
philipa_240sx is offline Find More Posts by philipa_240sx
Old Mar 01, 2013, 08:02 AM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
I'm still flying an EPP Pi. It's a bit shabby now, heavier and needs to be replaced after hundreds of flights and hours of fun.
A wonderful design.
Old Dec 18, 2013, 04:18 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
You Guys were holding out on me I just found this thread after My Friend Tim on facebook told me about it
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Dec 18, 2013, 05:55 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
Look here ................ http://www.rcgroups.com/forums/showt...ighlight=pipla and here too ................
http://www.rcgroups.com/forums/showt...ghlight=piplan
Old Dec 22, 2013, 04:06 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
here are two ideas Ive been using on my smaller squarer bodied Pi yak
This is a 15.25" version from 6mm EPP
another idea for a new build is to use pallet strapping to replace spars.. Its a cheap material and very strong....two strips glued in a sandwich above and below a wing makes it very stiff.. the strapping can also be split down its length and glued round any flat leading edge for further stiffness and damage protection
davereap is online now Find More Posts by davereap
Old May 31, 2014, 02:16 PM
dhobsman is offline
Find More Posts by dhobsman
United States, AR, Bella Vista
Joined Aug 2011
Thrust anle?
I'm pretty sure I read that the PiYak needs no thrust angle - down or right - is this correct? I'm getting ready to put my 18" er together and sometimes I just build the thrust angle into the motor mount. I sure would appreciate some input on this please! Thanx
dhobsman is offline Find More Posts by dhobsman
Old May 31, 2014, 02:27 PM
aeronot is offline
Find More Posts by aeronot
'Lectric Aficionado
aeronot's Avatar
USA, TX, San Angelo
Joined Mar 2006
With all the hovering, torque rolling, etc u can do with a pi yak, a zero thrust line has always been best for me.
aeronot is offline Find More Posts by aeronot
Old Jun 01, 2014, 01:11 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
Yup..............zero zero
Old Jul 24, 2014, 11:53 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
aeronot.......... very fun plane..........thanks.
just gave u and the pi some kudos over on the nut ball thread to see if i could send some of the n/b er's over here for a look. this design does not get the interest it deserves .
chuck.
chas650r is offline Find More Posts by chas650r
Discussion How about an indoor micro kite? del Scratchbuilt Indoor and Micro Models 7 Nov 22, 2013 10:06 AM
Question How about a ww1 monoplane?? sidecar53 Foamies (Scratchbuilt) 4 Apr 10, 2010 01:24 PM
Discussion How about we help Rick out MattinAZ Gilbert Quiet Flyers (Arizona) 25 Apr 08, 2010 08:12 PM
Discussion how does one go about charging several batteries vygec Batteries and Chargers 16 Mar 24, 2010 05:20 AM
