Old May 05, 2012, 01:29 AM
timatworksg is offline
Find More Posts by timatworksg
timatworksg's Avatar
Singapore, Singapore
Joined Oct 2011
Hmmm,...if we land a few more on the tree, all different colors, by Christmas it'll be decorated. Gotta find a positive..LOL!
timatworksg is offline Find More Posts by timatworksg
Old May 05, 2012, 09:55 AM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
[QUOTE=philipa_240sx;21516682]Since you are in the UK, Giantcod has a few suitable replacements:
http://www.robotbirds.com/catalog/images/409945-1.jpg
Thanks for the info.....went with this one from robotbirds. Ordered yesterday 4pm
received at 10am this morning.
Looks rather familiar !!!!!!!!
GPW... bit heavy maybe ,but hey who knows ,it might work
geedee is offline Find More Posts by geedee
Old May 06, 2012, 12:25 AM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
Been thinking about building something new I was really thinking about one of these. http://www.rcgroups.com/forums/showthread.php?t=1561600
I wonder if there is some kind of way to morph that flip flop into a round thing. Maybe gluing on winglets on the outside of the skids, but would have to recess the motor back into much of the circle which might mess with getting the cg right...
tymbrewolf is offline Find More Posts by tymbrewolf
Old May 06, 2012, 04:08 AM
Joined Oct 2011
I can only think of using CF rods bent to a circle for either both sides or actually create a globe of CF rods fully around a Pi-plane like a hamster ball.
Interesting thought tho tymbrewolf
Old May 06, 2012, 08:13 AM
Joined Feb 2007
In any case, I am surprised the that plane hasn't found its way to the scratch build side eventhough motorhead is kitting it only. Seems like most commercial ventures are in some way copied in free plans on here.
Old May 07, 2012, 01:40 AM
brett.c is offline
Find More Posts by brett.c
Foam is where the heart is
brett.c's Avatar
Australia, NSW, Sydney
Joined Aug 2010
Miyak.
18inch with shortened fuselage (I should have added an extra inch to the 16inch version )
9mm EPP
Turnigy 2730 1500kv
HK 10A speedie
8x3.8 prop.
HXT500 servos.
195g with 500mA 3s.
I intend to run 2s when the batteries arrive.
With the wheels the battery sits right in the cg line.
Only had a quick bust around the backyard. Hope to take it to the field soon.
brett.c is offline Find More Posts by brett.c
Old May 07, 2012, 07:07 AM
Joined Feb 2007
Nice!
Old May 08, 2012, 08:28 PM
UBILDIT is offline
Find More Posts by UBILDIT
Victoria Super Mortem
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Pi Yak .. Delta Pi Chapter
Here's mine... just flew it.. The only thing I've ever built that could be tail heavy on purpose or by accident and still survive the maiden.... in fact it hovered around and torque rolled and I landed it a few feet away un-harmed. Made some changes to the overall bottome side... cut a bit away from the tail and put on a larger battery and flew it again.
Motor CSRC = to Hacker A10-7L
7X3.5 gws
CC 10A ESC
3 HS 55's
True RC 450mah 2S
Basic flames on top so I can see it... flys great... probably going to make a version 2. For me and my buds....
Thanks for the cool plane man..
Bo
UBILDIT is offline Find More Posts by UBILDIT
Old May 08, 2012, 11:06 PM
Joined Feb 2007
Ubidit, of course you could always mvoe your rudder servo forward a tad too for balance. No one would notice the foam plug where the old hole was.
Old May 09, 2012, 06:02 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Canada, ON, Ayr
Joined Apr 2010
The servo's on my piYak are ~4" back the LE. The design definitely requires to mount most of your components forward of the CG point to get it to balance.
philipa_240sx is offline Find More Posts by philipa_240sx
Old May 09, 2012, 06:32 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Just an idea ... it may be prudent to make the nose slightly longer in order the get the CG so the battery sits on the CG directly .... that way you can use different size batteries with no consequence... These disk planes fly so well that a super light battery will enable them to lightly “Float" around in your backyard (GeneBond showed me that ) ... Fun for those calm summer evenings when you just Have to get in a flight or two ...
gpw is offline Find More Posts by gpw
Old May 09, 2012, 09:12 AM
Canada, ON, Ayr
Joined Apr 2010
It's pretty hard to get the CG right without having the battery pack well forward of the CG. On my piYak, ALL of the components need to sit forward of the CG point (25% from LE) just to get it to balance.
I suppose a longer nose would help, it would be interesting to see what effect a few inches added to the nose would have on handling. I would hate to loose the short snappy loops the piYak is capable of.
Not having the battery at the CG point isn't a big deal though. If you layout the components so that the ESC and RX are on one side of the fuse, you can then install a long strip of velcro on the opposite side for the battery. This will give you a large range of CG adjustment.
Another tip: place a couple of dots of hot melt glue on the underside of the 'wing' along the CG point to allow 'fingertip' balancing of the plane at the field.
BTW, I don't spend too much time balancing the piYak anymore. I adjust the battery pack on the fly to suit the wind conditions and my flying style: Forward CG for better wind penetration on breezy days, rearward CG for better hovering in calm conditions.
Old May 09, 2012, 10:13 AM
UBILDIT is offline
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
I thought So..
Thanks for everyone's input. I think I'm going to have to move the rudder servo forward and even considered shortening the tail to the point just before the rudder hinge meets the elevons. There's a bit over 1/4 inch extra vertical area there right now. Those changes should help for sure... but even so, I absolutely enjoyed it.. tail heavy then, normal..
Bo
Old May 09, 2012, 06:49 PM
Joined Feb 2007
that bit of foam on the tail won't make a difference. Move the servo!!
Old May 09, 2012, 08:09 PM
Joined Feb 2007
Bo, that receiver looks like it could move forward too just a tad or you could even move the esc under on the wing or above the wing on the fuse and move the receiver in its place. Lots of things can move before changing the body.
Discussion How about an indoor micro kite? del Scratchbuilt Indoor and Micro Models 7 Nov 22, 2013 10:06 AM
Question How about a ww1 monoplane?? sidecar53 Foamies (Scratchbuilt) 4 Apr 10, 2010 01:24 PM
Discussion How about we help Rick out MattinAZ Gilbert Quiet Flyers (Arizona) 25 Apr 08, 2010 08:12 PM
Discussion how does one go about charging several batteries vygec Batteries and Chargers 16 Mar 24, 2010 05:20 AM
