Old Apr 10, 2010, 03:20 PM
flashkick is offline
Find More Posts by flashkick
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
Build Log
Heinkel-178
so i was looking at planes online and saw this one. i think its adorable, so i'm gonna try to build one. i'm using the fiddlersgreen plan and i will tweak it as i go. i plan on using a jetscream fan and a vapor brick. i will try it with 1mm depron first but if its too heavy i have some durobatics i might try. if any body has any suggestions or comments please post.
flashkick is offline Find More Posts by flashkick
Old Apr 11, 2010, 06:54 PM
flashkick's Avatar
Joined Dec 2008
here are some pics. i nuked the fuse in the microwave to get it to hold its shape, worked great. its just taped together for the pics. the ar6400 and fan are there for size comparison and cause they will hopefully power it. waiting for my lipos to get here cause i washed all my other ones..... its just rudder and elevator.
Old Apr 11, 2010, 06:57 PM
flashkick's Avatar
Joined Dec 2008
and looking at it its going to need cheaters. so i cut some holes next to the landing gear so its not real noticable. hopefully it will work if not i'll have to look at cutting more holes. and the exhaust is probably too small. this thing has weird proportions for edf. if it still doesn't work i might just stick a propeller on the front and be forever condemed to rc hell for putting a propeller on the first jet
Old Apr 14, 2010, 10:42 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Sometimes you just have to do what ever makes it fly. It's such a nice looking plane! I have been using echargers fans for years now but it is still hard to get them to fly with only one fan. This little panther seems very fast but needs trimming to fly level and climb w/throttle. It is rudder only due to its weight, but I may have been able to add the extra servo but was afraid it would be too heavy. On the second pic below you can see the cheater hole! I made this outta wallfoam. there is virtually no thrust lost this way.
MUTCAKE is offline Find More Posts by MUTCAKE
Old Apr 14, 2010, 11:49 PM
flashkick's Avatar
Joined Dec 2008
ya i want to try some of the echarger fans but i can't get them anywhere in utah. so i go with jetscream ones. hopefully it flies if not i can get a gws and 1012 inrunner from hobbyking that should get it flying.
Old Apr 25, 2010, 04:10 PM
flashkick's Avatar
Joined Dec 2008
looks like i have to go brushless cause at my altitude i'm getting 6 g of thrust from the js fans.
Old Apr 26, 2010, 01:04 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
I suspect your ducting is part of the problem. What % of fan area have you got on the inlet and outlet?
Roughly, the inlet should be 30mm dia. (same as the fan) and the outlet should be about 27mm dia. give or take a mm or two.
If the ducting is wrong then your not going to get decent thrust no matter what fan you fit.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Apr 26, 2010, 01:16 AM
flashkick's Avatar
Joined Dec 2008
ya the ducting is a problem. i cut cheaters and it probably need more though. the exhaust is also undersized i think. i think i'll just need to enlarge it a little and it should fly better. i have to go brushless cause even with plenty of air the fans aren't getting more than 6g of thrust.
Build Log Gary Hethcoat 42" Heinkel He100 prototype build der Oberflügel Scale Kit/Scratch Built 102 Jul 11, 2012 09:44 AM
Discussion USS Dekaury YTB 178 Prins Willem Dock Talk 8 Mar 05, 2012 10:01 AM
Sold Jazz HDv 178 Video Camera Twinkletoze Non R/C Items (FS/W) 1 Nov 14, 2009 04:43 PM
Discussion Heinkel He 178 géry 46 Electric Ducted Fan Jet Talk 2 Feb 09, 2009 02:25 PM
Heinkel He-178 V1 - World's first jet aircraft to fly Gyroguru Electric Ducted Fan Jet Talk 8 Aug 15, 2006 03:31 PM
