This thread is privately moderated by bosco49, who may elect to delete unwanted replies.
Old Apr 10, 2010, 02:01 PM
bosco49 is offline
Find More Posts by bosco49
bosco49's Avatar
USA, CA, Shasta Lake
Joined Mar 2005
High Aspect-ES 3.1M electro-glider #4
RTF....all I need is some nice weather....
I went with a MEGA MOTOR 22/30/3 .....and a CC Phoenix Ice Lite 75.....13x7 prop....Turnigy 2650mAh 3S 30C Lipo .....57oz with out batteries ...Now I'm running a Turnigy1800 4s 35c lighter setup more power too.
bosco49 is offline Find More Posts by bosco49
Old Apr 15, 2010, 12:45 PM
nuevo is offline
Find More Posts by nuevo
nuevo's Avatar
United States, AL, Madison
Joined May 2002
So did you change motor & ESC? Earlier you showed a PJS motor and Hyperion ESC. Any problems from either setup?
And most important, have you flown it yet?
Very nice looking bird!
nuevo is offline Find More Posts by nuevo
Old Apr 15, 2010, 07:02 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
nuevo I have not flown it yet....when the weather gets good.I had to change the motor out and put a heavy motor in to make to plane balance on the CGs....then I had to get a bigger ESC...I was pulling over 50 AMPs so I went with a 75A ESC......And thank you.
Scott
Old Apr 16, 2010, 10:51 AM
nuevo is offline
nuevo's Avatar
Joined May 2002
super nice plane. Best wishes on the first flights. Thanks for the info in motors & ESC.
Old Apr 16, 2010, 11:12 AM
jollyroger is online now
Find More Posts by jollyroger
Central Lake, Michigan
Joined Dec 2002
Are you using a gearbox with the Mega or direct drive. The reason I'm asking is that I'm building a glider and have a 22-30-3 which I would like to use but it seems that I would have to include a gearbox (planetary) .
If It's possible to use this motor direct drive then it's worth a try.
cheers
jollyroger is online now Find More Posts by jollyroger
Old Apr 16, 2010, 10:23 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
The Mega 20/30/3 without a gearbox wanted to pull the High Aspect right out of my hands pointing straight up....that with a 13x8 prop and a Turnigy 2650mAh 3S 30C Lipo Pack.The battery is about 9oz...so 66oz wanted to go straight up
Old Apr 22, 2010, 06:55 PM
bosco49 is offline
bosco49's Avatar
Joined Mar 2005
Salmon-Run I have sent you a IM
Discussion Tail heavy High Aspect-ES 3.1M electro bosco49 Electric Sailplanes 26 Apr 02, 2010 06:19 PM
Discussion Art Hobby High Aspect-E 3.1M electro-glider bosco49 Electric Sailplanes 3 May 16, 2006 05:34 AM
