Old Jan 27, 2013, 06:28 PM
Notsogood is offline
Find More Posts by Notsogood
Notsogood's Avatar
United States, ID, Mountain Home
Joined Sep 2011
Originally Posted by Nighthawk74 View Post
2nd upgrade all about power.
I just attached a Champ prop, to my NV. It already has the J-3 motor upgrade and a 150mAh batt. Tested it in the living room *******Whooooooooosssssh********* its fast
Noticed the rudder getting "flimsy". >Probably from all the living room crashes over the years
Sounds live fun. Mine is still stock. Only changed the prop shaft after breaking the first one. Been to windy and COLD to fly here. Can't wait for a break in the weather.
Notsogood is offline Find More Posts by Notsogood
Old Jan 29, 2013, 08:40 AM
Nighthawk74 is offline
Find More Posts by Nighthawk74
RC addict? I'm not addicted...
Nighthawk74's Avatar
Danmark, Midtjylland, Roslev
Joined Jul 2011
I'll drink to that Its pretty much the same here in northern europe. Hope things clear up for you guys, so you can get out with your bigger stuff too...ohh and helis
Nighthawk74 is offline Find More Posts by Nighthawk74
Old Feb 18, 2013, 01:42 AM
Nobby33 is offline
Find More Posts by Nobby33
South Africa, WC, Cape Town
Joined Mar 2012
Hi
I need to replace the prop on my Night Vapor. I bought a replacement over the weekend but haven't had a proper look yet. How do i get the old prop off? And tips? I don't want to break anything
Nobby33 is offline Find More Posts by Nobby33
Old Feb 18, 2013, 07:11 PM
Steve 0 is online now
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
Originally Posted by Nobby33 View Post
Hi
Do some searching around....like this...
http://www.rcgroups.com/forums/showt...p#post24072788
The prop should just unscrew and screw on the new one. I grip the main gear, the motor and go.
Steve 0 is online now Find More Posts by Steve 0
Old Feb 18, 2013, 11:42 PM
Nobby33 is offline
Joined Mar 2012
Thanks Steve O
Old Feb 19, 2013, 12:24 AM
Slope-a-Dope
Steve 0's Avatar
Joined Dec 2012
You're welcome. I flew my Mini-V this evening and nosed it into my B-ball court from about 12 feet up. BANG! Snapped the prop shaft.....second one now. I was using the micro citabria prop which makes the plane speedy and a tad squirrely for the airframe's slow fly design. Fixed it quickly.
Old Feb 21, 2013, 12:14 AM
Nobby33 is offline
Joined Mar 2012
Prop came off really easily Not sure what i was expecting, I am not that great with fixing things, just want to fly them Anyway, she is as good as new now.
The Mini Vapor and the Parkzone UM Spit has finally arrived in South Africa, I really want to get both of them, now to try to convince the wife
Old Feb 23, 2013, 11:58 AM
SpinningProp is offline
Find More Posts by SpinningProp
SpinningProp's Avatar
Joined Jan 2012
What material should I use to re-do the main wing on my NV ?
I would like to be able to find something in HobbyLobby or Walmart.
...and what glue to use. Thanks
SpinningProp is offline Find More Posts by SpinningProp
Old Feb 23, 2013, 03:40 PM
jbarchuk is offline
Find More Posts by jbarchuk
DeBary, FL
Joined Nov 2010
[QUOTE=SpinningProp;24226711]What material should I use to re-do the main wing on my NV ?
Interesting coincidence you should ask that be cause I was going to ask a similar Q.
At Lowes today for painters tape , just below that I notice 3M masking file. The website calls it paper, but whatever. The 3M page calls it film http://solutions.3m.com/wps/portal/3...gl85WXMWTCXVbl
Not quite that page, because they make a ton of different size packages, but another page says it's 0.4mil. I poked at it a little and it seemed *very* strong.
Anyone ever tried it? I don't know any painters or auto body people or I'd ask for a sample.
Homefly.com has mylar and also a page that mentions dope or glue stick. http://www.homefly.com/reference/mylar-instructions.htm
Plain old saran wrap works too.
jbarchuk is offline Find More Posts by jbarchuk
Old Feb 25, 2013, 12:38 AM
Nobby33 is offline
Joined Mar 2012
After fixing the N vapor prop, i got to fly it outside this weekend (no wind, not a normal thing for Cape Town lol). On friday night i flew it in our apartments parking area, and out over the street at about 20 metres up. Lets just say a few cars riding past slowed down to have a look at the strange light in the air
Old Feb 25, 2013, 05:59 PM
Scooch is offline
Find More Posts by Scooch
Scooch's Avatar
United States, NJ, Jackson
Joined Nov 2011
Was flying the NV and the rod that runs through the pivot point broke. Any suggestions on how to fix this????
Scooch is offline Find More Posts by Scooch
Old Feb 25, 2013, 08:09 PM
jbarchuk is offline
DeBary, FL
Joined Nov 2010
Lap a piece of CF from the plastic piece to the other remainder of the broken CF.
Tie each side with thread. Maybe 2 ties on each side of the break depending on how firm the first ties feel. Dental floss works too but it's very wide compared to thread. Best would be very lightweight Spider Wire fishing line or other similar Kynar. Obviously, snip of loose ends.
Add CA off the tip of a pin or toothpick. No kicker just wait for it to set up.
Fixed LG that way and need to do it again.
Old Feb 25, 2013, 08:43 PM
Scooch is offline
Scooch's Avatar
Joined Nov 2011
Can you post a pic or a sketch of what you mean?
Old Feb 25, 2013, 09:23 PM
jbarchuk is offline
DeBary, FL
Joined Nov 2010
Ohhhh I'm sorry I did *not* realise that that piece of CF is the elevator hinge!
On the plus side the theory of the fix is still roughly the same.
The difference is that that piece of CF that still attached, you need to snap that off.
Then you need another piece of CF the same diameter so it'll fit into the hinge part that's attached to the fuse.
Tie one side first, then fit on fuse, then tie other side. Add CA *VERY* carefully with micro-drops from a pin, just enough to wick into the ties and between new CF and plastic.
Here're a thousand words. Well, maybe 85 words.
Old Feb 26, 2013, 06:13 PM
T.W. is offline
Find More Posts by T.W.
United Kingdom, Newcastle upon Tyne
Joined Jul 2002
Flew my Night Vapor tonight after changing the standard motor for the J-3 Motor - gobs more power; will take-off and go vertical; loops with ease now that the motor can 'power the model over the top' (no need to dive to gain speed). I put a video on YouTube (
Parkzone Night Vapor flying high alpha (2 min 12 sec)
) but unfortunately all it shows is some slow and high-alpha flying (had the camcorder recording when I thought it was off and vice verse . . . better luck next time, eh!). Tony
T.W. is offline Find More Posts by T.W.
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro Ready-to-Fly 65 Nov 17, 2010 07:53 AM
New Product New Parkzone Night Vapor! 3D4life Scratchbuilt Indoor and Micro Models 22 Jul 10, 2010 05:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 01:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 05:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 01:26 PM
