Old Aug 29, 2012, 11:01 AM
YelKiteFlyer is offline
Find More Posts by YelKiteFlyer
Canada, BC, Aldergrove
Joined May 2011
Originally Posted by whirlcap View Post
I don't think so... Your mix is the fix. I do it also but leave some rudder on the right stick in case my brain thinks ailerons
I am new to the hobby. I have a dx8, could you give me a step by step instruction for programming the mix, from rudder right stick to rudder left stick?
Thanks in advance,
Robin.
YelKiteFlyer is offline Find More Posts by YelKiteFlyer
Old Aug 29, 2012, 09:34 PM
Matt Ls Thumbs is offline
Find More Posts by Matt Ls Thumbs
Joined Aug 2012
You need to use two mixes.
Rudder -> Aileron mix, +100, +100
Aileron -> Aileron mix, -100, -100
On all the time, with trim.
The two numbers are the adjustment for negative movement and positive movement.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Sep 28, 2012, 11:10 AM
Red5 is offline
Find More Posts by Red5
United States, KY, Prospect
Joined May 2004
My Night Vapor got wet- Now what?
Flying off of my boat at night has it's inherrant dangers. Add a bunch of booze to this equation and you end up with one Night Vapor taking the plunge.
So here is what happens:
I turn it on and it will bind. THe lights all work. The rudder and elevator are very jerky and have about a second delay. The motor starts to spin up and then shuts off.
Is there any saving this thing or is it headed to the trash.
Guessing it is the ESC / board. Can I fix this?
Red5 is offline Find More Posts by Red5
Old Sep 28, 2012, 11:38 AM
Docta is offline
Find More Posts by Docta
Life is better, when you fly.
United States, CO, Conifer
Joined Oct 2006
Salt water or fresh water?
I've dunked a couple of my micro blade heli's in hotel fountains and as long as I pull the battery right away and let them dry, they work fine.
From the sounds though, I think you need a replacement ESC.
Docta is offline Find More Posts by Docta
Old Sep 28, 2012, 12:51 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The Motor shutting off is probably the battery. Water is how you kill them. Buy a new one.
Use a #000 phillips screw driver to remove the servo racks. Use alcohol and a Q-tip to wipe the carbon off the resistive strips and servo brushes, then screw the racks back on.
You may have hurt the ESC if you tried to run the brick while it was still wet, but I'd still go with the battery.
UNGN is offline Find More Posts by UNGN
Old Sep 28, 2012, 01:54 PM
ourbluehorizon is offline
Find More Posts by ourbluehorizon
UK, Ballymena, Ballymena
Joined Aug 2008
Waterproofing ESC's
The esc could have been dried out but yes running just to see if it still works.........There is product called "Corrosion X" which the waterplane guys use. You can use it to waterproof almost anthing electrical. I had a receiver proofed with this which survived 2 weeks in storms hung high up a tree.
ourbluehorizon is offline Find More Posts by ourbluehorizon
Old Oct 01, 2012, 03:52 PM
k4pacific is offline
Find More Posts by k4pacific
AMA 988154
k4pacific's Avatar
United States, NJ, Somerset
Joined Jan 2009
I 've had my NV for a few months now, first plane. I bought a prop saver and some GWS props from rcfunlab. The props are a EP4040, EP4025 and a EP4540. Is there a preferred one or is the stock prop still my best choice? The NV is a fun plane even though I only fly it indoors in a armory, lots of space and at least a 30 foot ceiling
Thanks for any suggestions.
k4pacific is offline Find More Posts by k4pacific
Old Oct 01, 2012, 05:01 PM
davidterrell80 is online now
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
I've not been a reader of this thread... I've just subscribed... so, I may be speaking in ignorance. But, the stock prop is a metric140x45 (5.5x1.8 inches) or about equal to a 5518 in the EP numbering scheme. I don't know what the stock prop weighs but the 4040 is almost 1.1 g. and the 4025 is 1.25 g... that is almost 1/10 the weight of my vapor's 16.5 grams, and the propsaver and o-ring will probably bring the total up to 25% of the plane's all-up weight (AUW). You might end up nose heavy.
I'll be reading the thread to see what others' might have said. have you thought of using the thread tools to search for "prop"?
Edited after some searching.....
I didn't know about the little GWJ propsavers... you might be on to something. I still think you'd need to beware of nose weight but others have done it.
davidterrell80 is online now Find More Posts by davidterrell80
Old Oct 01, 2012, 07:42 PM
AMA 988154
k4pacific's Avatar
Joined Jan 2009
Yes. I did search "props" just about everything I found pertained to props with broken shafts, not much on performance with various sizes. The stock NV prop weighs 1.26 grams with spinner, .90 without.
Old Oct 01, 2012, 08:07 PM
Joined Apr 2012
There was a feller in Colorado at post #620 that was using some non-stock props to advantage.
Latest blog entry: General Aircraft Skyfarer
Old Oct 01, 2012, 08:53 PM
I R Irv is online now
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Go to page 22, I posted a pic of the prop and a link. There not cheap but you'll never regret buying one. I've used this prop on the Vapor since it first came out. Haven't broke a prop or a prop shaft yet and it's quite an improvement over the stock one. Keep reading after pg22 because there's a elevator mod that should be done to all Vapors.
TODD
I R Irv is online now Find More Posts by I R Irv
Old Oct 01, 2012, 11:39 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
That elevator mod is a good idea. I've never been one to "speed" fly or dive my NV but if your outside and a sudden gust hits you head on, you will get the sudden nose dive effect from that too. Normally I have no problem with the stock tail but after the other day I may do the mod. I was lucky and recovered before it hit the ground.
whirlcap is offline Find More Posts by whirlcap
Old Oct 02, 2012, 12:08 AM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
I might try a 5030 prop. I have prop adapters. I use j3 motor stock prop and love it.
J
jabsten is offline Find More Posts by jabsten
Old Oct 12, 2012, 02:23 PM
Nobby33 is offline
Find More Posts by Nobby33
South Africa, WC, Cape Town
Joined Mar 2012
Had a NV for two weeks now, getting used to flying it in our lounge
Night Vapor Indoor Flying (0 min 34 sec)
Nobby33 is offline Find More Posts by Nobby33
Old Oct 13, 2012, 07:58 PM
Tony Twoskids is offline
Find More Posts by Tony Twoskids
USA, GA, Kennesaw
Joined Dec 2003
Just to add on to that... My vapors are flown in my living room 99% of the time and I love them for the ability to do so. Nearly a constant turn (small living room!), but so much fun.
Tony Twoskids is offline Find More Posts by Tony Twoskids
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro Ready-to-Fly 65 Nov 17, 2010 07:53 AM
New Product New Parkzone Night Vapor! 3D4life Scratchbuilt Indoor and Micro Models 22 Jul 10, 2010 05:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 01:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 05:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 01:26 PM
