Old Jul 27, 2012, 03:15 PM
planesilver is offline
Find More Posts by planesilver
planesilver's Avatar
United States, ID, CDA
Joined Dec 2010
Originally Posted by rcflyer40plus1 View Post
A lil breeze came up and blew my NV into the ground! Broken shaft. Replaced and in the air again tonight. Hey, is there any way to extract the broken shaft from the prop and re-use? I know, so cheap..
I broke my prop shaft and I shaved the back of the prop down enough with a hobby blade to get a small needle nose with teeth to hold it steady and unscrewed the prop ...a hemostat would also work..then I screwed the prop back on the new shaft...
planesilver is offline Find More Posts by planesilver
Old Jul 27, 2012, 03:19 PM
Joined Dec 2010
Originally Posted by DIYJIM View Post
Thanks tyme4me, I'll do that. I guess if I get more tares I'll recover with a Mylar balloon.
I don't know if anyone mentioned but, a good repair or recovering material is a mylar space blanket at wally world camping supply dept for a buck
Old Jul 28, 2012, 06:00 PM
rcflyer40plus1 is offline
Find More Posts by rcflyer40plus1
I'd rather be flying!
rcflyer40plus1's Avatar
Joined Jul 2010
That makes a lot of sense actually. I'm sure I could shave enough to get ahold of it. Thanks for the tip. Still enjoy flying this little plane - have gotten some interesting reactions from the neighbors. All positive / amazing technology really.
rcflyer40plus1 is offline Find More Posts by rcflyer40plus1
Old Jul 29, 2012, 12:57 AM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Thanks, good tip!
Got two packs flown in the front yard tonight. Was nice and calm but couldn't keep up with the bats
whirlcap is offline Find More Posts by whirlcap
Old Jul 31, 2012, 07:18 AM
jwp2 is offline
Find More Posts by jwp2
United States, IL, Essex
Joined Feb 2010
Did the bats want to check out the Vapor?
jwp2 is offline Find More Posts by jwp2
Old Jul 31, 2012, 09:36 AM
whirlcap is offline
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
No . Would have been fun if the flew around it. They pretty much stayed away. Must be a "bug" that is too big to eat on their radar
Old Aug 02, 2012, 03:36 AM
jwp2 is offline
Joined Feb 2010
lol. Probably.
Old Aug 05, 2012, 05:41 PM
DIYJIM is offline
Find More Posts by DIYJIM
Joined Jan 2012
Hey guys, the covering on my wing & elevator are starting to come off. What kind of glue can I use to attach the covering to the carbon frame?
Thnaks
DIYJIM is offline Find More Posts by DIYJIM
Old Aug 05, 2012, 05:54 PM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I used cellophane tape.
TomCrump is offline Find More Posts by TomCrump
Old Aug 05, 2012, 09:59 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Thnaks
A foam glue like UHU por or Beacon's Fabritac/foamtac works best.
CA will make the CF rods brittle and prone to crack.
A foam glue will remain flexible.
UNGN is offline Find More Posts by UNGN
Old Aug 06, 2012, 07:40 AM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
I used 3m liquid pen and it worked fine and stays flexible.
Tim
w4yn is offline Find More Posts by w4yn
Old Aug 06, 2012, 03:50 PM
DIYJIM is offline
Joined Jan 2012
Thanks, I'll try any of the suggested that I come across first.
I was teaching my son to fly my nv & he nose dived it into the ground, the main carbon rod just behind the motor mount is now broken. I am going to epoxy that back tonight.
Wish me luck.
Thanks.
Old Aug 27, 2012, 10:08 PM
Notsogood is offline
Find More Posts by Notsogood
Notsogood's Avatar
United States, ID, Mountain Home
Joined Sep 2011
Nice night out so I got out the Night Vapor for a few flights. What a fun little plane.
Notsogood is offline Find More Posts by Notsogood
Old Aug 28, 2012, 09:46 PM
Matt Ls Thumbs is offline
Find More Posts by Matt Ls Thumbs
Joined Aug 2012
I bought one a few months ago, but didn't maiden it until this week. Fun little plane sums it up, as long as you have NO wind.
First flight was with default plane settings (dx6i) and the rudder is on the right stick. I kept trying to use the left stick, so I put the rudder on the left stick using the two mixes.
Is there a way to program the brick to use the rudder channel for the rudder?
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Aug 29, 2012, 12:03 AM
whirlcap is offline
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
I don't think so... Your mix is the fix. I do it also but leave some rudder on the right stick in case my brain thinks ailerons
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro Ready-to-Fly 65 Nov 17, 2010 07:53 AM
New Product New Parkzone Night Vapor! 3D4life Scratchbuilt Indoor and Micro Models 22 Jul 10, 2010 05:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 01:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 05:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 01:26 PM
