Old Jun 01, 2012, 06:35 AM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
My NV plane couldn't lift the 808 #16 with the full housing and internal battery. But this cheaper camera I stripped down will give me 720x480 video and seems to work pretty good for $10.
jpconard is offline Find More Posts by jpconard
Old Jun 03, 2012, 12:43 AM
Av8rshane is offline
Find More Posts by Av8rshane
Joined Feb 2012
My NV did pretty good up here at 9000'. Not sure that the stock motor would of handled the altitude so well. Just looked it up and it's 8150'.
Av8rshane is offline Find More Posts by Av8rshane
Old Jun 03, 2012, 08:27 AM
S2Rdriver is offline
Find More Posts by S2Rdriver
Joined Oct 2011
I live at 8500' and fly with stock motor and a GWS 5030 prop. Stock NV propeller required full power to maintain level flight, 5030 flies well at about 1/2 power.
S2Rdriver is offline Find More Posts by S2Rdriver
Old Jun 04, 2012, 09:55 PM
rcflyer40plus1 is offline
Find More Posts by rcflyer40plus1
I'd rather be flying!
rcflyer40plus1's Avatar
Joined Jul 2010
Been waiting for days, and I seen no box when I got home, then my wife says after dinner "There's a box that arrived for you - it's in the van" - hoo ha! Night Vapor in mint condition w/3 70mAh batts just ready to go. I could not believe how light the frame is on this lil plane. Took her out for a quick test drive - no problems, but there was a little bit of a breeze and - man so sensitive! But, wind has died down this evening to nothing. Some high clouds and moon out. Took her out for a flight in the dark. I am an adrenaline freak, but I think sometimes the attraction is really the calm that follows. Skipped the adrenaline, straight to the calm. Sense of relaxation I've never had before flying. Light as a feather and super easy to keep orientation. When I brought her down low, it was like a moth - so quiet. That was SO MUCH FUN! Thanks guys for convincing me to pick one of these up!
EDIT: Oh, on further thought, I still like the adrenaline - lol. But this lil moth really is a unique joy to fly - quietly in the night.
rcflyer40plus1 is offline Find More Posts by rcflyer40plus1
Old Jun 06, 2012, 01:23 AM
Joined Feb 2012
My next upgrade will be the prop. Going with the Cf 5030 as soon as they are back in stock.
Old Jun 07, 2012, 12:55 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Nite Flying
Late evenings in back yard or at remote dark site (scout camp) is a real treat.
It does not get much better than this for me!
Every now and then I loose orientation but it only takes a flip of rudder to reorientate my brain. White LED's on front will actually illuminate ground on dark night, IE landing lights!
Tim
w4yn is offline Find More Posts by w4yn
Old Jun 07, 2012, 07:38 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Tim
Those bright forward white lights are great, would be much harder for me to keep orientation if they had left them out. It's pretty dark in my front yard and fifty or sixty feet up needs some good lights for me on this little plane.
whirlcap is offline Find More Posts by whirlcap
Old Jun 15, 2012, 04:19 PM
Lanzer is offline
Find More Posts by Lanzer
Joined Apr 2012
I've been flying with a 4540 and it's a ton of fun. Less than half throttle for level flight, and after upgrading to a J3 motor this thing's a beast! I'm sure you'll have a blast once you get your hands on a J3 motor.
Lanzer is offline Find More Posts by Lanzer
Old Jun 16, 2012, 02:03 AM
iHatePoles is offline
Find More Posts by iHatePoles
NOOOooooooo......
iHatePoles's Avatar
Joined Jun 2012
The night vapor is officially the best toy I have ever bought in 31 years.
I take this thing for walks around the neighborhood, and a crowd just follows me wherever I go.
I think it's time to scratch build an absurdly larger version of the NV.
The formula is simple...
More LEDs + More Bigger = More Better!!1
Well.... I'm going to go marinade on that thought and fly the vape..... Vape XXL build thread to follow.
iHatePoles is offline Find More Posts by iHatePoles
Old Jun 21, 2012, 11:11 PM
Joined Jul 2010
A lil breeze came up and blew my NV into the ground! Broken shaft. Replaced and in the air again tonight. Hey, is there any way to extract the broken shaft from the prop and re-use? I know, so cheap..
Old Jun 23, 2012, 09:09 AM
NOOOooooooo......
iHatePoles's Avatar
Joined Jun 2012
I've found you can get another use out of a broken prop shaft with a little hot glue. This works best if you have one or two threads that can latch onto the prop. It doesn't have to be a firm hold, but just a lil' something that lines it up right while the glue sets....
  1. First, put a big glob of hot glue on the prop (the size of the cone, on the reverse side).
  2. Hold it so the glue stays balanced & uniform on the prop shaft (nose down).
  3. Take the NV and push the remaining (already attached) prop shaft through the hot glue nose down (make sure you don't get any glue on the gear).
  4. Hold it perfectly perpendicular (nose down) for about 5 minutes, blow on it, and let it rest another 10 min.
  5. Go outside & give it a whirl.
It ain't pretty, but it'll get you flying again in about 15 minutes (while your lipos recharge).
Old Jun 24, 2012, 01:18 AM
jpconard is offline
Joined Feb 2007
I've got the broke shaft out of the prop saver adapter (part that goes on shaft to hold the prop) by using a small nail and hammering it out. Then I just super glue the adapter (or stock prop as well) on to what is left of prop shaft. In my experience the shafts snap on the threaded part.
Old Jun 24, 2012, 09:01 PM
Joined Jul 2010
Thanks guys. Once I have another nose plant, I'll try some of those tips. Threw a 160mAh batt in her last night and that was cool. A little more power, very little adverse effect I could tell. I got a number of those laying around since I replaced those with Turnigy nano-tech 160mah 1S 25~40C, which do an *awesome* job on the micro 4-site and micro sukhoi.
Old Jun 27, 2012, 12:09 PM
k4pacific is offline
Find More Posts by k4pacific
AMA 988154
k4pacific's Avatar
United States, NJ, Somerset
Joined Jan 2009
NV Battery Holder
Just recenly got my Night Vapor, first plane. When using a 150MAh battery, many times it will come out of the battery clip and just dangles in the air. It seems the velcro isn't strong enough to keep the battery in place. Is there any way to prevent this from happening? Other than the battery, it's just very relaxing fun.
k4pacific is offline Find More Posts by k4pacific
Old Jun 27, 2012, 02:04 PM
ourbluehorizon is offline
Find More Posts by ourbluehorizon
UK, Ballymena, Ballymena
Joined Aug 2008
velcro
change the velcro on the plane and the batteries
ourbluehorizon is offline Find More Posts by ourbluehorizon
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro Ready-to-Fly 65 Nov 17, 2010 07:53 AM
New Product New Parkzone Night Vapor! 3D4life Scratchbuilt Indoor and Micro Models 22 Jul 10, 2010 05:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 01:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 05:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 01:26 PM
