The NV is a very docile flyer, shouldn't take long to master. I mix about 35 to 40 percent " up" elevator with rudder to make it very easy to stay level in turns. I also recommend flying with the battery tray slid all the way back, flys high alpha very well and will fly very slow that way too.
I had forgotten how much fun the NV is in the front yard but I have started flying her every calm evening lately. Usually calmest just before dark and the lights are great for keeping orientation. |
Joined Dec 2011
I had a original vapor and just bought a night vapor.
And I realized night vapor dont fly as well as original For example, my original vapor is able to fly level with just 1/4 throttle, but night vapor require more than half. Had been playing around with the different cg, but night vapor still dont fly as easy as original. The former motor is also always hotter after each flight. Anyone had the same issue? |
Joined Mar 2010
You want to learn as much as you can with the NV. So do not mix anything. You very much need to learn to turn LEFT AND RIGHT all the while staying level. This teaches you to add back stick pressure as you turn...
low rate at 70% is good. Happy flying... |
CLEVELAND,OHIO
Joined Feb 2003
lol,I havent got one pack through it yet and already need replacments
![]() I snapped one leg off of the landing gear,im sure there has to be a mod for this maybe just some wire? I can deal with that,but I just planted it and the prop came off,im not sure but it looked like it broke off in the prop? I cant seem to push it back on. Is this common? |
UK, Ballymena, Ballymena
Joined Aug 2008
Fix for landing gear
I've broken the motor mount on mine and repaired with superglue. The replacement prop didnt work but but the champ prop with a bit of masking tape round the shaft was a vast improvement. Nano tech batteries also make a difference. I've also fixed the prop with superglue! |
HTH. |
CLEVELAND,OHIO
Joined Feb 2003
I was looking at hobby king,This is where you would get the better battery?
I see the 160mah looks to be pretty close to the dimension of the stock battery,this is what I should get? But I see there not in the US anywhere to get in the states? |
Joined Apr 2012
PS - the nanotech are also rated 25c. |
Joined Apr 2012
http://www.rcgroups.com/forums/showp...&postcount=562 The landing gear is very easy to break, but luckily it's also easy to repair. The thing that bugs me the most is how easy it is for the prop to break from the prop shaft. Once it's broken then it's time to buy new prop shaft and new props. I suggest getting a prop saver to save you the headache. Not only does it save you money but it allows you to use different types of props. I'm now flying with a 4505 prop which is a high pitch prop that gives really good power. Tons of fun. |
| Thread Tools | |
| Discussion New parkzone night flying vapor!!!!! | lightspeeddud | Micro RTF | 65 | Nov 17, 2010 07:53 AM |
| New Product New Parkzone Night Vapor! | 3D4life | Indoor and Micro Models | 22 | Jul 10, 2010 05:27 PM |
| Discussion Why is this night different from every other night? | Michael in Toronto | Life, The Universe, and Politics | 17 | Apr 01, 2010 01:42 PM |
| Discussion New Night Flying Vapor with pre-installed lights | Darth_Elevator | Night Flying | 0 | Mar 18, 2010 05:17 PM |
| Discussion Thursday Night is Heart Attack Grill night in Chandler AZ | Michael Heer | Arizona Electric Festival | 23 | Feb 02, 2010 01:26 PM |
