Old Jan 19, 2012, 01:18 PM
funbags is offline
Find More Posts by funbags
Blade CP Pro Newb
funbags's Avatar
New York
Joined Sep 2006
Can anyone post or link to some suggested settings for the DX6i and the vapor? Thank ya!
funbags is offline Find More Posts by funbags
Old Jan 20, 2012, 01:46 PM
funbags is offline
Blade CP Pro Newb
funbags's Avatar
New York
Joined Sep 2006
I played around a bit last night, it was a blast. I did have the prop come off on the last flight. Do I just stick it back on there or is the prop ruined?
Also I noticed in a lot of the video's everyones vapor is going a lot slower then mine is for the indoor flight. Any suggestions to get that more floaty type flight for indoor use?
Old Jan 20, 2012, 03:01 PM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
Move the battery back as far as you can.
lovespicyfood is offline Find More Posts by lovespicyfood
Old Jan 20, 2012, 03:22 PM
funbags is offline
Blade CP Pro Newb
funbags's Avatar
New York
Joined Sep 2006
Till it hits the board?
Old Jan 20, 2012, 03:26 PM
Joined Sep 2004
Yes.
Old Jan 20, 2012, 03:28 PM
funbags is offline
Blade CP Pro Newb
funbags's Avatar
New York
Joined Sep 2006
Yes.
I'll try that tonight thanks!
Old Jan 21, 2012, 01:27 AM
funbags is offline
Blade CP Pro Newb
funbags's Avatar
New York
Joined Sep 2006
Any tips on getting the snapped rod out of the prob? It snapped flush so I can't even grab it with a needle nose...
Old Jan 21, 2012, 02:04 AM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
I use a DX7 and mix about 40% "up"elevator with rudder input to stop nose drop in turns. You can always just fly the regular way and add "up" manually but it does make it easy and would help when you let some one fly it.
whirlcap is offline Find More Posts by whirlcap
Old Jan 21, 2012, 06:24 AM
Chris_F is offline
Find More Posts by Chris_F
The new guy
Londonderry, NH
Joined Oct 2010
Nope, you will need a new prop and shaft. I recommend the Champ prop instead of the stock Vapor, MUCH more thrust, but you'll have to glue it on since the hole is too big to screw on to the stock shaft.
Chris_F is offline Find More Posts by Chris_F
Old Jan 25, 2012, 10:14 AM
BlackIce is offline
Find More Posts by BlackIce
Joined Dec 2007
Is the Night Vapor a good rc plane to learn to fly with?
I am thinking about getting a RTF for someone that has only flow Air Hogs 2 channel planes before.
BlackIce is offline Find More Posts by BlackIce
Old Jan 25, 2012, 10:29 AM
joemi is offline
Find More Posts by joemi
joemi's Avatar
United States, WA, Kent
Joined Sep 2001
I think so. Very slow and lightweight. Plenty of time to make corrections.
Careful though... You could very well be starting them off to a lifetime of addiction.
joemi is offline Find More Posts by joemi
Old Jan 25, 2012, 11:18 AM
ODUsurfer is offline
Find More Posts by ODUsurfer
Fly it like you stole it!
ODUsurfer's Avatar
United States, VA, Purcellville
Joined Aug 2009
YES!
That's basically the same path I took when learning to fly RC. I started with Air Hog-type stuff, and then I got a Vapor. They are very forgiving in a crash as long as you aren't full throttling it right into the ground, and they are great learner planes. I also spent quite a bit of time on a simulator as well, but I was able to easily transition into my first parkflyer plane not long after owning my Vapor, a GWS Formosa.
ODUsurfer is offline Find More Posts by ODUsurfer
Old Jan 25, 2012, 02:09 PM
bobbutts is offline
Find More Posts by bobbutts
bobbutts's Avatar
USA, NH, Bow
Joined Jun 2007
Yes, for sure.
The thing you will quickly notice after some initial jitters is that the Night Vapor is easy to fly and the Air Hogs are difficult comparatively. I rarely crash the Night Vapor, and even with lots of practice had a hard time keeping any air hog up for an entire flight. The hardest transition is getting used to your commands actually reaching the plane reliably!
Once you go up to another plane, be careful because the night vapor is capable of angles and speed that stall most stuff. For that it may not be ideal as a learner.
bobbutts is offline Find More Posts by bobbutts
Old Jan 25, 2012, 02:12 PM
whirlcap is offline
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Yes it is, if you have very calm wind conditions... Meaning practically none at all! Or if you have enough room indoors. Another good choice is the Hobby Zone Champ, 89.99 USD everything you need to fly in the box. It will handle light wind too. (fly with no wind at first recommended though) any breeze at all will quickly ground a Vapor or send it out of sight, it doesn't have the power to push into much of a breeze at all.
I have one of each and they are both great.
Old Jan 25, 2012, 03:24 PM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
+1 ^
Bugbitten is offline Find More Posts by Bugbitten
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro Ready-to-Fly 65 Nov 17, 2010 08:53 AM
New Product New Parkzone Night Vapor! 3D4life Scratchbuilt Indoor and Micro Models 22 Jul 10, 2010 06:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 02:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 06:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 02:26 PM
