Joined Jul 2011
Night Vapor Maiden
Got my Night Vapor last week and it's great. I love being able to just step out the front door and fly on a whim. I had my daughter record the first flight and if anyone wants to check it out, here's the video.
Joined Dec 2010
I put the J-3 motor in tonight. Direct fit, no muss no fuss. Went in like a charm. Everything is working great so I must have damaged the stock motor by not throttling down fast enough. I decided I liked the idea of reinforcing the wings and elevator. i happened to have some 0.5mm CF rod so i set to do it. I felt that hot glue would be the best way to do this as CF and epoxy are too messy and i wanted a little give for shock absorption. and hot glue would be easier to reverse if i get it on wires or the frame etc.
I put supports on the front and back of the main wing and across both sides of the elevator, of the horn. Here are pics. Took it out for a test flight. ITS A COMPLETELY DIFFERENT PLANE! in a great way! It will do its usual Night Vapor thing but its way more powerful and steady. I can almost vertical climb and it cruises really fast. its great to get it level at about 30% throttle and then go full bore! its accelerates fast. and I love the sound of it too. wooooooot! Current weight (w/o battery): 17.1g |
Londonderry, NH
Joined Oct 2010
It appears you put a support from your elevator control horn, crossing under the rudder, to the opposite side of the elevator. When you adjust your control horns for max throw (highly recommended BTW, makes the plane very aerobatic) you'll find that this support will catch on the rudder when you give it full up elevator and rudder. I found the single support that runs on the same side as the rudder to be plenty for the elevator.
Londonderry, NH
Joined Oct 2010
![]() I tend to try and fly it like a "scale" plane, low throttle, high endurance. Wonder how long I can go on a Hyperion 160? I got some old ThunderPower 160s I wouldn't mind risking in the name of science... |
N. Adams,Ma.
Joined Sep 2008
I've had a regular Vapor for quite some time. One of my favorite things to do was go fly under the streetlight at midnight. Sometimes I would lose orientation, so forget about flying in the yard. Today I got a Night Vapor(and a t28 Trojan, it was a good day). What a wicked good plane(yeah, I'm from New England). Flying in the dark in the yard is no problem at all. I never lost orientation IN THE DARK. A factory fresh new plane is nice too. What a great flyer!
| Thread Tools | |
| Discussion New parkzone night flying vapor!!!!! | lightspeeddud | Micro RTF | 65 | Nov 17, 2010 07:53 AM |
| New Product New Parkzone Night Vapor! | 3D4life | Indoor and Micro Models | 22 | Jul 10, 2010 05:27 PM |
| Discussion Why is this night different from every other night? | Michael in Toronto | Life, The Universe, and Politics | 17 | Apr 01, 2010 01:42 PM |
| Discussion New Night Flying Vapor with pre-installed lights | Darth_Elevator | Night Flying | 0 | Mar 18, 2010 05:17 PM |
| Discussion Thursday Night is Heart Attack Grill night in Chandler AZ | Michael Heer | Arizona Electric Festival | 23 | Feb 02, 2010 01:26 PM |
