Old Jul 26, 2011, 11:29 AM
The new guy
Londonderry, NH
Joined Oct 2010
Good idea on hot glue. I reinforce with epoxy before installing then I use CA only on the little slot at the bottom of the mount to glue it to the frame. That way you can shave the mount and glue off in one stroke.
Chris_F is offline Find More Posts by Chris_F
Old Jul 26, 2011, 11:30 AM
I used to like trees
rchank's Avatar
United States, WA, Spokane
Joined Jul 2011
Originally Posted by alpinesandtoys View Post
Thanks for the heads up on twisting the stock props! Now I have a ton of spare props cause I kept buying new ones that sucked..was heating them up to try and put more pitch into them and ruining them. Didn't realize all you had to do was twist them. No more uncontrolled dives for me! With the J-3 motor it'll go as high as I want....was up higher but brought it down so I could see it on my iphone....lol!
http://www.youtube.com/watch?v=PAwk4H6IaxM
I found out you can over pitch the prop too. I twisted a bit too far a few nights ago and the plane was flying sluggishly with what sounded like abnormally low r.p.m.s I landed it, checked the little motor and man was it ever HOT! I then backed off on the pitch and all was back to normal.
rchank is offline Find More Posts by rchank
Old Jul 26, 2011, 02:56 PM
The new guy
Londonderry, NH
Joined Oct 2010
Does the pitch stay once you've re-pitch'd the prop? Maybe I'm not twisting enough but it seems I only get a minute or so of increased pitch from the prop.
Old Jul 26, 2011, 03:55 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Guys these CF props aren't cheep but you don't have to re-pitch them and they'll probably be the last prop you'll have to buy. I've never broke one with the Vapor.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Jul 26, 2011, 04:03 PM
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
Link to the prop and adapter?
anti-gravity is offline Find More Posts by anti-gravity
Old Jul 26, 2011, 04:33 PM
rchank's Avatar
Joined Jul 2011
I found that I had to give it a little "tune-up" twist for a few days. It seems like it wants to return to its original pitch.
Old Jul 26, 2011, 05:33 PM
I R Irv's Avatar
Joined Nov 2008
He's out of the props but they are the Micro Invent 5030 prop, here's the adapter you need.
TODD
http://bsdmicrorc.com/index.php?productID=926
http://bsdmicrorc.com/index.php?productID=946
Old Jul 26, 2011, 08:38 PM
Boise, Idaho
Joined Jul 2009
Old Jul 27, 2011, 01:29 AM
alpinesandtoys's Avatar
Joined May 2011
Do you have the uncontrolled dive problems with that prop? I've been testing aftermarket props on the vapor and the all have this issue except the stock prop
alpinesandtoys is offline Find More Posts by alpinesandtoys
Old Jul 27, 2011, 05:03 AM
Hamburger Eatin' Fool
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I've had the dive issue with the stock prop.
TomCrump is offline Find More Posts by TomCrump
Old Jul 27, 2011, 06:08 AM
I R Irv's Avatar
Joined Nov 2008
The dive issue is caused by the airframe itself not the prop.
TODD
Old Jul 27, 2011, 10:50 AM
United States, KY, Madisonville
Joined Mar 2011
deleted
Bugbitten is online now Find More Posts by Bugbitten
Old Jul 27, 2011, 11:39 AM
The new guy
Londonderry, NH
Joined Oct 2010
TODD
I suspect the elevator itself is actually flexing. But that's just a wild guess.
Old Jul 27, 2011, 04:14 PM
Good Times!
Micro Budget's Avatar
Joined Feb 2011
pull the cabanes apart that connect the front and back of the wing. just give them a little tug away from each other like you're stretching the wing from front to back. seems to help me a lot when trying different props on the vapor
Micro Budget is offline Find More Posts by Micro Budget
Old Jul 30, 2011, 09:47 AM
I R Irv's Avatar
Joined Nov 2008
Your correct here's the mod I did to stop the diving problem. This Vapor has a ball bearing gearbox, J3 Cub motor, 5030 carbon fiber prop and a Hyperion 70 cell. This combo puts out a ton of thrust and I can run it full throttle. At full throttle it will pull up and to the right with no stick input. Big loops and big circles are easy now at full throttle,also modded to do tight loops and turns. To me this is the ultimate 3-CH plane and I'll never go back to a stock one.
TODD
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro RTF 65 Nov 17, 2010 07:53 AM
New Product New Parkzone Night Vapor! 3D4life Indoor and Micro Models 22 Jul 10, 2010 05:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 01:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 05:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 01:26 PM
