Old Mar 29, 2011, 08:00 PM
anti-gravity is offline
Find More Posts by anti-gravity
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
Speed. Then pull into the far back corner. Then as it enter the upside down part, move the stick far up corner (left or right).
Its tricky, specially on a vapor
anti-gravity is offline Find More Posts by anti-gravity
Old Mar 31, 2011, 09:23 AM
Scarface26 is offline
Find More Posts by Scarface26
Colorado Springs, CO.
Joined Mar 2009
I bought a used Night Vapor on EBay. It should arrive today. I am really looking forward to getting it in the air. There is a monthly indoor meet here in our city auditorium, and I am planning on giving it a good work out at the next meet.
Scarface26 is offline Find More Posts by Scarface26
Old Mar 31, 2011, 09:24 AM
Boise, Idaho
Joined Jul 2009
Good luck!
Old Apr 06, 2011, 04:20 PM
lazor 22 is offline
Find More Posts by lazor 22
lazor 22's Avatar
Wendell, NC
Joined Jun 2010
I can get mine to loop all day long, with the 25C packs and -100% expo/125% D/R. Rolls I have not been able to accomplish yet.
lazor 22 is offline Find More Posts by lazor 22
Old Apr 06, 2011, 09:28 PM
Boise, Idaho
Joined Jul 2009
Did you put it to full throw on the control surface?
Old Apr 06, 2011, 10:22 PM
lazor 22 is offline
lazor 22's Avatar
Wendell, NC
Joined Jun 2010
Yep
Old Apr 07, 2011, 07:55 AM
Boise, Idaho
Joined Jul 2009
Try getting more speed when you go into it
Old Apr 21, 2011, 09:34 AM
Joined Mar 2009
Well, I maidened my Night Vapor in our city auditorium last night. As I mentioned in a previous post, it was used when I bought it. It is the easiest plane to fly I have ever seen! It needs some tweaking though. On takeoff it goes very nose high with 70 mAh batteries. It required full nose down subtrim on my DX7 plus holding extra nose down with the stick and almost full throttle to get it to move forward faster than a crawl. That was with the battery all the way forward. A 130 mAh Hyperion battery helped quite a bit by extending the end of the battery between the landing gear legs. This resulted in less throttle and less nose down trim needed for level flight. Do I need to move the wing back a bit?
Old Apr 21, 2011, 04:38 PM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
Mine flies pretty high alpha when I punch the throttle to full, but other than that it cruises pretty level. The hyperions really give it more punch, but I've got 160s so they take a lot of the float out of it. Can't grease those one wheeled touch and goes when I have them in. On the other hand, loops are easy.
Belem is offline Find More Posts by Belem
Old Apr 21, 2011, 08:26 PM
Afraidtoregister is offline
Find More Posts by Afraidtoregister
Looking4Grass in AZ
Afraidtoregister's Avatar
United States, AZ, Mesa
Joined Feb 2011
Is that what that does? I thought those slots were for fine zeroing of the control surface. Which is the most movement, the furthest hole?
Afraidtoregister is offline Find More Posts by Afraidtoregister
Old Apr 21, 2011, 10:05 PM
Boise, Idaho
Joined Jul 2009
On the control surface. The Closer to the surface, the more throw.
Old Apr 21, 2011, 10:33 PM
Looking4Grass in AZ
Joined Feb 2011
Wow, I had no idea. I thought those slots were because the thing was mass produced and they just used the slot that zeroed the control surface while the servo was centered. Hello tighter turns. Thank you.
Old Apr 21, 2011, 10:34 PM
Boise, Idaho
Joined Jul 2009
No problem man!
Best of luck. and take it one hole at a time. It will make your vapor way more responsive.
Old Apr 23, 2011, 09:52 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Just bought mine.
I haven't had a chance to fly her. I'm looking forward to the experience.
TomCrump is offline Find More Posts by TomCrump
Old Apr 23, 2011, 10:26 AM
Boise, Idaho
Joined Jul 2009
Best of luck. You will love her!
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro Ready-to-Fly 65 Nov 17, 2010 07:53 AM
New Product New Parkzone Night Vapor! 3D4life Scratchbuilt Indoor and Micro Models 22 Jul 10, 2010 05:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 01:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 05:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 01:26 PM
