Old Aug 23, 2010, 05:44 AM
mxandrews1 is offline
Find More Posts by mxandrews1
United States, CA, San Gabriel
Originally Posted by squishydonut View Post
Does it have decent power when flown at lower throttle settings on the carbon prop?
I'm not very experienced with what makes or breaks certain flight characteristics, but from what I experienced, the power wasn't as good as the speed with the carbon prop. When attempting slow speed high alpha passes with the carbon prop, it seemed to not want to fly slow nor keep the nose up doing so as opposed to the the 4-site prop which definitely felt it would hang from the prop easier.
The Vapor wasn't designed to be a fast flyer, but having the power to do loops (inside and outside), vertical climbs and the ability to pull out from low to ground "dumb thumb" maneuvers, makes it more enjoyable.
If you want to maintain slow flight and still be able to do tricks, I would rate the props as:
1. 4-site prop
2. Stock Vapor prop
3. BSDMicro carbon prop
If others have experience with these, please chime in.
mxandrews1 is offline Find More Posts by mxandrews1
Old Aug 23, 2010, 07:10 AM
BladeHead is offline
Find More Posts by BladeHead
Flick lives
BladeHead's Avatar
beautiful, picturesque Southern New Jersey, USA
Joined Dec 2008
Any deals on vapors/night vapors that anyone knows about?
I got my BNF Night Vapor for $91.99 with free shipping at Red Rocket Hobbies with their 4th of July 8% sale promotion. If you register on http://www.redrockethobbies.com, they will email you e-coupons for various promotions, usually 8% off your purchase from their Web site. These usually come around U.S. holidays, so get in there now for their end of summer/Labor Day coupon that will probably be out in less than two weeks.
BladeHead is offline Find More Posts by BladeHead
Old Aug 23, 2010, 02:07 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
1. 4-site prop
2. Stock Vapor prop
Someone mentioned that the cub motor weighed more... but if it slides in AND the gears mesh, sounds good to me. I know that the cub performs well on a small prop.
MikeRx is offline Find More Posts by MikeRx
Old Aug 23, 2010, 06:00 PM
rclayton is offline
Find More Posts by rclayton
rclayton's Avatar
Mooresville, IN
Joined Mar 2009
Does the cub motor fit into the stock motor mount?
rclayton is offline Find More Posts by rclayton
Old Aug 23, 2010, 06:37 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
thanks for info
Here is the link for the prop adapter. He ships it with two 3/16 rubberbands.
http://www.bsdmicrorc.com/index.php?productID=665
I'm running the 4-site prop instead of the supplied BSDMicros carbon 5030. The carbon prop definitely sped up the Vapor and I wasn't interested in a hot-rod Vapor.
I haven't noticed any ill affects of the 4-site prop. You will have to hollow out the prop hole a bit to get it on the BSDMicro's prop adapter, then just use the provided rubberbands. With the battery mounted under the RX board, 4-site prop and BSDMicro adapter, the plane is a little nose heavy. It will glide down with a little up elevator.
When outside, I love to crank the throttle and climb vertically then just coast down with no power. The J-3 cub motor seems to give it that "ummppff!" it needs without having to modify the crap out of a perfectly good flyer.
Hope that helps.
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Aug 23, 2010, 11:09 PM
Yes it does, as they are the same diameter. The J-3 motor is a little bit heavier, but it's not a significant weight increase.
Old Aug 23, 2010, 11:26 PM
rclayton is offline
rclayton's Avatar
Mooresville, IN
Joined Mar 2009
Do you think the extra weight is worth the extra power?
Old Aug 23, 2010, 11:31 PM
Without a doubt!
Old Aug 24, 2010, 12:15 AM
rclayton is offline
rclayton's Avatar
Mooresville, IN
Joined Mar 2009
Without a doubt!
Is there a dramatic cut in flight time with the more powerful motor?
Old Aug 24, 2010, 05:35 AM
I get about 15 mins on the 150mah packs. Again, this is the same motor from the J-3 cub which in that plane was providing 15-20 minute flights.
I would just try it for yourself since there isn't any hacking up of the Vapor to get this mod to work. That's the beauty of it.
Old Aug 24, 2010, 01:23 PM
rclayton is offline
rclayton's Avatar
Mooresville, IN
Joined Mar 2009
Do you think the extra power puts more stress on the frame?
Old Aug 24, 2010, 06:49 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Vapor airframe will take a ton of stress. Fast level flight isn't so good though, just not designed for it. Front and rear main wing supports help alot with increased power.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Aug 27, 2010, 10:59 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
A few Night Vapor pics shot this evening.
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
bobbutts is offline
Find More Posts by bobbutts
bobbutts's Avatar
USA, NH, Bow
Joined Jun 2007
bobbutts is offline Find More Posts by bobbutts
Old Aug 27, 2010, 11:00 PM
bobbutts is offline
bobbutts's Avatar
USA, NH, Bow
Joined Jun 2007
wow, exact same time we resurrect this thread.. hah nice ones
Discussion New parkzone night flying vapor!!!!! lightspeeddud Micro Ready-to-Fly 65 Nov 17, 2010 08:53 AM
New Product New Parkzone Night Vapor! 3D4life Scratchbuilt Indoor and Micro Models 22 Jul 10, 2010 06:27 PM
Discussion Why is this night different from every other night? Michael in Toronto Life, The Universe, and Politics 17 Apr 01, 2010 02:42 PM
Discussion New Night Flying Vapor with pre-installed lights Darth_Elevator Night Flying 0 Mar 18, 2010 06:17 PM
Discussion Thursday Night is Heart Attack Grill night in Chandler AZ Michael Heer Arizona Electric Festival 23 Feb 02, 2010 02:26 PM
