Old Apr 10, 2010, 06:51 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Cannot solder aluminum tab to nickel ones ??
Hi ...
I just want to make a 2s Lipo out of 2 bare cells, unfortunately I don't have any access to special flux for soldering aluminum .. is there any other way I can bond the two tabs together without that special aluminum flux
Thanks a lot
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Apr 10, 2010, 10:49 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Chech here
https://www.tanicpacks.com/product_i...a9a750511295d8
and they have $2 shipping on small orders.
I would advise cleaning the batter soldered araeas and the soldering iron very well when done as this flux is corrosive.
I use a seperate soldering iron with such and these days I rarely run across Lipoly tabs which are in need of it. Most now have a nickle strip spot welded to the aluinum tab.
Have you tried both sides of the tab? Make sure it is very clean and that the iron tip is also and freshly tinned.
It is a good idea to practice on a strip of kitchen aluinum foil and a piece of scrap wire if the spacial flux must be used. Also be fast as heat will damage the seal on the LiPoly.
Charles
Old Apr 10, 2010, 12:34 PM
Joined Nov 2006
Thanks a lot ,... that's a lot of good info
Khaled
Old Apr 10, 2010, 04:15 PM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
On all my modern low cost lipos one side of the aluminum tab is plated to take solder. No special flus needed.
The biggest issue is use heat sink between iron and cell and be quick or you'll risk damaging the seal.
rich smith is offline Find More Posts by rich smith
Old Apr 10, 2010, 09:46 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
+1 on the Tanic flux. I have a jar and am fairly certain I could solder two sticks of balsa together with it if I tried. Use a little sand paper if needed to clean any crud off the surfaces and look for a plated side like Rich said.
SteveM732 is offline Find More Posts by SteveM732
Old Apr 11, 2010, 05:58 AM
Joined Nov 2006
Does this also apply when soldering a connector to the pack wires ??
Khaled
Old Apr 11, 2010, 06:50 AM
Southern Pride
Perhaps if the leads are extremely short and you solder so poorly that you wick solder the full length of the wire.
In your case starting with bare cells then yes soldering th power leads to the cell tabs is same as soldeing cell tabs together in series. Be extremely careful with heat sink on tabs as a short will ruin the LiPoly.
Everyone should learn to solder well before soldering anything for RC,period.
As above I suggested practicing on kitchen foil. Chances are that the first LiPoly cell / battery that one tries to repaire they will damage in one way or another anyway.
Most LiPolys are so inexpensive these days it is not practicle to repaire them. If it is a $200 plus LiPoly then send it to someone suchs as Rampman who has the experience.
Old Apr 11, 2010, 12:44 PM
Joined Nov 2006
Thanks a lot
Khaled
Old Apr 11, 2010, 08:02 PM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
From my experience, the tabs are prepared to take solder on the outer part of the tabs. If that part of the tab is gone, you can use this solder paste, or other liquid products to solder aluminum together. If you have a soldering iron that uses a copper plated tip, it will remove the copper. I am lucky to have solid copper tips, and I use the same one to solder these tabs, when I have to.
H.
himeros is offline Find More Posts by himeros
Old Apr 12, 2010, 12:04 PM
rich smith's Avatar
Joined Dec 2006
It is just the opposite. All irons have solid copper tips. The good tips are iron plated and last 100x longer. Aluminum flux is a disaster for both types which is why I try to avoid it.
Old Apr 12, 2010, 12:11 PM
u.rusty is offline
Find More Posts by u.rusty
Novice RC pilot
u.rusty's Avatar
California
Joined Feb 2008
I once had the bright idea of using cheap 40 watt soldering irons and machining the tip to a point to suit my needs. Well it worked great except the bare copper tip errodes away with just a little use. It didn't take long for me to realize it is worth every penny to get a decent solding iron with an iron plated copper tip. The iron plated tip works better, and doesn't erode away like a bare copper tip.
u.rusty is offline Find More Posts by u.rusty
Question Lipo solder tab fred685 Batteries and Chargers 10 Nov 04, 2009 02:14 AM
Discussion V3 Lama swashplate ball joints hitting motor solder tab cyclonite Coaxial Helicopters 5 Nov 07, 2006 05:15 AM
Help! Joining Nickel Solder tabs to Lipo terminal post bruce.mciver Batteries and Chargers 5 Jan 11, 2006 12:15 PM
Problem with Mega 1615/X Solder Tab stone_axe Power Systems 1 May 09, 2005 07:23 AM
What does a solder tab look like Al P Electric Plane Talk 4 May 15, 2001 11:10 PM
