The DX6i needs to use Mix 1 & Mix 2. |
Latest blog entry: AR6400 guillows Space Shuttle
LI, New York, USA
Joined Mar 2003
Glad to help but understand that your right stick is pitch and roll. On a R/E/T aircraft with high dihedral wings the right stick is still pitch and roll. Roll is induced by yaw/dihedral coupling.
If you are interested in understanding more about this, take a look here. This is the link I posted in my original message to you. You are right in that you are making YAW adjustments when you move the rudder, but that is not why you are making them when you are using the right stick. You are new to this and I don't want you getting wrong ideas and terms stuck in your head. If you read and understand the article it will help you going forward. > WHAT GOES ON WHICH STICK ... and Why? http://www.rcgroups.com/forums/showp...63&postcount=6 From the article: Depending on the design of your plane, the rudder can play different roles so its placement can change. On dihedral or polyhedral winged planes with no ailerons, the rudder is your primary turning surface. It provides both roll and yaw control so it goes on the right stick for roll control, as the primary turning surface. This stick also has pitch/elevator control. If you think of it in this manner, there is no confusion moving back and forth between single stick and dual stick radios. On a single stick radio, pitch and roll are on the single stick, which usually happens to be oriented to the right side of the radio. It doesn't matter if it is a rudder/elevator plane or an aileron/elevator plane. Pitch and roll are on the right stick, or the only stick. . |
Latest blog entry: Big Red Cadillac
Nose heavy is fine... It just needs more up elevator and may fly a little faster than with the Brick back a little.
Really Nose heavy likely won't be able to loop. If it can loop, your CG is good. |
LI, New York, USA
Joined Mar 2003
> Getting planes out of trees
http://www.flyesl.org/forums/topic.asp?TOPIC_ID=239 http://www.rcgroups.com/forums/showthread.php?t=167396 Brutus, We have all done it at one time or another.
| Thread Tools | |
| Discussion Scorpio Albatros DV | oscarlovel | Power Systems | 1 | Oct 17, 2007 12:26 PM |
| Is there an electric Albatros DV out there? | Jeremy Z | Parkflyers | 11 | Dec 15, 2005 11:53 PM |
| Sold NIB Kavan Albatros DV | Tommy D | Aircraft - Electric - Airplanes (FS/W) | 2 | Oct 06, 2005 09:18 AM |
| Great Planes Albatros DV??? | indyrcpilot | Foamies (Kits) | 14 | Apr 10, 2005 11:00 AM |
| Albatros DV | CraigO | Scale Electric Planes | 11 | Jul 28, 2002 11:44 AM |
