This thread is privately moderated by ShoGinn, who may elect to delete unwanted replies.
Old Apr 09, 2010, 07:33 PM
ShoGinn is offline
Find More Posts by ShoGinn
Trader Rating: 90
Space Cowboy
ShoGinn's Avatar
United States, CA, Vandenberg Air Force Base
Joined Jan 2007
Trader Rating: 90
Sold
Electrifly C-35 Brushed ESC - 2x gear drive brushed motors - $25
STOCK# - GPMM2035 New and unused. In the original manufacturer packaging.
This is the C-35 Mini High Frequency Electronic Speed Control w/BEC.
For medium sized performance aircraft with 400 500 or 600-size
Brushed Motors requiring 35A or less.
FEATURES: Compact size to minimize weight and simplify installation
Programmable battery types
Automatic temperature protection reduces max throttle to 70 when max
temperature is reached
Safe-Start system prevents accidental motor starts by disabling the
motor circuitry until the throttle stick is moved to full throttle
then to the OFF position
Factory installed radio motor and battery connectors
Fully proportional forward with brake
Battery Eliminator Circuitry provides sufficient power for the
receiver and three standard servos. The motor battery powers the
receiver and servos. When voltage is reduced to the appropriate
voltage the Low Voltage cut-off circuitry stops the motor while
continuing to supply power to the receiver and servos.
Solid-state current overload limiter
Built-in thermal protection drops throttle to 70 if
transistors overheat
Reverse-polarity protection
High Frequency to optimize battery run-time and cool operation.
ON/OFF radio switch and set-up LED light
180 day limited warranty
INCLUDES: One C-35 Mini Electronic Speed Control with Universal receiver plug
installed installed motor wires with 3.5mm gold plated Female
Bullet Connectors Deans Ultra Male Battery Connectors
and an ON/OFF switch
Three ceramic capacitors to reduce motor noise
One Schottky SR506 diode for added efficiency.
(Silver stripe indicates Positive unless using with gearbox)
One 2.75 piece of shrink tubing
One instruction sheet
REQUIRES: Attaching to motor and setting up speed control
Battery pack
Plug Universal plug into the throttle channel on the receiver
SPECS: Length: 1.30 (33mm)
Width: .71 (18mm)
Height: .43 (11mm)
Weight: 1.08 ounce (30.5g) with wires
Input: 6-12 NiCd/NiMH cells; 2-4 LiPo cells
Max Rated Current: 35A continuous
BEC Voltage: 5V/1.5A
Low Voltage Cutoff: 0.80V per cell for NiCd/NiMH
2.75V per cell for LiPo
Connectors: Universal radio connector Deans Ultra Male battery
connector 3.5mm gold plated Female Bullet Connectors
Switching Frequency: 1.3kHz
Motor Size: Speed 400 500 and 600-Brushed only
COMMENTS: Motor wires are White (Positive) and Blue (Ground)
Do not use with Brushless motors
The motors are unknown in size but are the 300-350 size and run pretty good, I have tested both and they run strong and smooth!
$25 + Shipping
ShoGinn is offline Find More Posts by ShoGinn
Old Apr 09, 2010, 08:14 PM
flyhigh8 is offline
Find More Posts by flyhigh8
Trader Rating: 23
Boston, MA
Joined Oct 2008
Trader Rating: 23
PM sent
flyhigh8 is offline Find More Posts by flyhigh8
Old Apr 10, 2010, 01:48 PM
flyhigh8 is offline
Trader Rating: 23
Boston, MA
Joined Oct 2008
Trader Rating: 23
PM sent
Old Apr 11, 2010, 03:49 PM
ShoGinn is offline
Trader Rating: 90
Space Cowboy
ShoGinn's Avatar
Joined Jan 2007
Trader Rating: 90
Still not sold. $30 gets it shipped priority mail to anywhere in the CONUS
Old May 12, 2010, 01:09 AM
kwjw3 is offline
Find More Posts by kwjw3
Trader Rating: 0
Joined Apr 2005
Trader Rating: 0
Still Available?
Please let me know if this iem is still available.
kwjw3 is offline Find More Posts by kwjw3
Discussion Question about brushed Electrifly C-25 ESC servo capacity h2oman Electric Plane Talk 2 Mar 31, 2010 05:29 PM
Sold Electrifly C-35 Brushed ESC/BEC NIB!! $25 shipped ShoGinn Aircraft - Electric - Power Systems (FS/W) 2 Jan 14, 2010 06:43 PM
Sold ELECTRIFLY C-35 Lipo NiMH brushed motor ESC mattyhawk Aircraft - Electric - Power Systems (FS/W) 2 Oct 08, 2009 10:10 AM
For Sale ElectriFly C-25 ESC for Brushed Motors NIB wright42 Aircraft - Electric - Power Systems (FS/W) 0 Feb 05, 2008 12:15 AM
Found WTB: Electrifly C-25 or C-35 brushed esc or similar crashnburned Aircraft - Electric - Power Systems (FS/W) 0 Oct 24, 2007 07:45 PM
