Newark, DE USA
Joined May 2001
Hi pure,
I don't mean to horn in on Dan, but it's not "tonight" anymore and I figured you might want to get started. They're made out of some kind of flexible plastic. Many reinforce them with balsa. You might make yours out of balsa from the beginning. Someone on another thread suggested laminating 2 sheets of, I believe, 1/16" balsa with white glue. Sounds good to me. Probably better than the plastic and easier to cut. I'd suggest laminating cross grain. Here's a picture of the cut outs. cut outs Here's a picture of my plane so you can see how they fit. my plane RB |
Newark, DE USA
Joined May 2001
Thanks Dan,
The wheels are from Hobby Lobby, top of page: http://www.hobby-lobby.com/wheels.htm I measured mine at 1 5/8" by looking at a ruler. I guess they're the 1 11/16" ones. They say 0.19 oz/pair. I weighed mine on a scale that's accurate to 0.10 grain and got 0.18 oz. The wheels that come with the TM weigh 0.08 oz/pair, so you only gain 0.10 oz. The HL ones do have a bigger hole so you'll also gain a little weight with a fatter axle or bushing. RB |
Newark, DE USA
Joined May 2001
Thanks Mario,
I use 10 pound test Cabelas Rip Cord rip cord It's similar to Spiderwire that others use, but it has a silicone coating and is very slippery. I like that feature because I use it in my pull/pull control applications. Don't need to worry about keeping tension. It doesn't stretch and there's a little "give" in the other components. I strengthened the vertical struts with 1/8" balsa strips. I believe the flying wires would bend the stock plastic. Just pull them to the point of having no slack, not too tight. Also be careful to keep the prescribed dihedral. I pulled mine unevenly the first time and decreased the dihedral and it didn't turn well. I epoxied the eye and part of the shank of a No. 10 fish hook in the wing to attach the wires to it's front.I drilled 0.030" holes in the struts and ran the line through them. They're held with a dab of epoxy. I copied the flying wire configuration of a full sized TM moth RB |
| Thread Tools | |
| Tiger Moth Wing Struts? | foofinator | Parkflyers | 17 | Aug 06, 2003 05:23 AM |
| Tiger Moth Wing Struts | Phildozer | Parkflyers | 2 | Jul 10, 2002 09:32 PM |
| Tiger Moth Wing Struts | kansascloud | Parkflyers | 1 | Mar 06, 2002 05:22 PM |
| Tiger Moth wing struts | cruzomatic | Parkflyers | 11 | Feb 20, 2002 12:20 PM |
| Tiger Moth Wing Hold Down Mods | Ben Lanterman | Parkflyers | 11 | Oct 01, 2001 09:49 PM |
