Old Apr 08, 2010, 04:17 PM
bri6672 is online now
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Yak 54 Landing Issue?
Hey Guys need a bit of direction! I have a Modeltech Yak 54 with a 26cc gasser in it. Not quite a giant but figured you guys would be the ones to ask on this. The plane flyes great and is slightly nose heavy ( tried moving the CG back slightly and it seemed to become pretty unstable) So everything is great till I try to land, I will set up the approach like the rest of my planes but when I drop the throttle to let it glide and flair in the plane wants to climb! If I add some throttle it levels back out. So what would make it climb with no throttle/ at idle. Because of this I am having some really fast landings which are sketchy! Any advise would be great!
bri6672 is online now Find More Posts by bri6672
Old Apr 08, 2010, 09:02 PM
2robinhood is offline
Find More Posts by 2robinhood
2robinhood's Avatar
Egg Harbor City, New Jersey
Joined Apr 2006
Too much engine down thrust could cause it.
With power on it is pulling the plane slightly down, when chopping the throttle it balloons.
Your trim to fly level with power on is fighting down thrust ( some up trim ).
When at idle the engine isn't pulling down and the trim makes the plane rise.
I would check down thrust and / or your CG.
2robinhood is offline Find More Posts by 2robinhood
Old Apr 08, 2010, 09:06 PM
bri6672's Avatar
San Diego
Joined Jul 2009
Thanks for th reply, I will check the downthrust, if it was the CG is it a nose or tail heavy characteristic?
Old Apr 08, 2010, 09:08 PM
bri6672's Avatar
San Diego
Joined Jul 2009
Thanks for the reply, I will check the downthrust, if it is a CG issue is it a nose or tail heavy characteristic?
Old Apr 08, 2010, 09:37 PM
2robinhood's Avatar
Joined Apr 2006
Tail heavy.
A nose heavy CG you would have a hard time slowing it down it would want to land hot.
A nose heavy CG you would have a hard making it flare for touchdown.
Old Apr 08, 2010, 09:48 PM
bri6672's Avatar
San Diego
Joined Jul 2009
Originally Posted by 2robinhood View Post
Tail heavy.
Well thats the issue I am having It is coming in real hot! I cant get it to slow down for landing so I am guessing Nose Heavy which would also explain the up elevator at normal flight, but the nose wanting to come up when I let off the throttle has me baffled!
Old Apr 08, 2010, 10:04 PM
2robinhood's Avatar
Joined Apr 2006
Engine down trust.
Try shimming a little less down thrust and see what happens.
Old Apr 11, 2010, 09:02 PM
bri6672's Avatar
San Diego
Joined Jul 2009
You Nailed it!!!! I took out the down thrust (putting the motor at dead center) and the issue is gone! landings are back to normal! Thanks so much for the help! For others that have this issue it basically came down to this: The engine down thrust (factory spec) was forcing me to have to trim about 4-5 clicks of up elevator for level flight under power, when I removed power to flair in for a landing the up elevator trim was making the plane rise and I had to give it down elevator to get it to drop, this also created some fast sketchy landings. With the engine at zero down thrust I no longer needed the up trim for level flight (about 2 clicks) and now she flairs in nice and slow and no issues!
Old Apr 11, 2010, 10:03 PM
2robinhood's Avatar
Joined Apr 2006
Glad to hear, good luck, and good flying.
Discussion goldberg yak 54 77" vs great planes yak 54 81" aci-bt Giant Scale Airplanes 3 Oct 01, 2007 12:11 PM
Discussion Ultrafly Yak 54 vs QQ Yak 54 49" netdudeuk 3D Flying 5 Aug 04, 2007 04:02 PM
Found Hyperion Yak-54 40 E Landing Gear Yardbee Aircraft - General - Miscellaneous (FS/W) 0 Jan 11, 2007 04:11 AM
Question YAK 54 landing gear Air-Gar Sport Planes 1 Jul 18, 2006 12:12 PM
Quique's E-Yak-54 and his foamy Yak-54 flierbk 3D Flying 0 Aug 25, 2005 09:55 AM
