UK
Joined Dec 2008
Just seen this maiden on Youtube.
Sorry to read there is that much damage Henrik, you must be considering a new airframe or is it a 50/50 call? The one in video doesn't look underpowered. But I'm only guessing its a standard setup. Cheers Bobster |
The really big remaining issue is to glue the one wing on again. I wonder whether the bond between the wing and the main fuselage will be strong enough. I also wonder how much of the intake tubes to remove for good. Quote:
.Cheers, Henrik PS: Where the hell do I get a good runway? The Autobahns here are all busy with brand-new BMW's and Audis... |
The damage looks even worse than I first imagined. I really hope you can repair her! |
Corpus Christi Texas
Joined Jul 2008
Yes something must have gone wrong with the electronics because in your post you said it had almost 1:1 thrust... so it should have climbed out with authority unless an electronic failure got you.
Your post about thrust calculations follows.............. "Hello there, here two new data points about the MiG-29 from the test bench. Measurements were taken inside the airframe with a Jeti MUI-150 capacity / voltage / current combined sensor. The battery used was a SLS 4.000mAh 25C 6s freshly charged. Plugs where 4mm gold plugs which have slightly better resistance than Dean's plugs (<0.2 mOhm instead of <0.3). Maximum current drawn at WOT: 78 Ampere (1,9 kW at 24 Volts) Maximum thrust: Less than 1:1 an AUW approximately 2.430 grams. I am a bit sad we didn't get 1:1. Cheers, Henrik " Also IMHO probably not a good idea to fly this one off grass.......... |
TEXAS
Joined Sep 2005
That what was trying to imply maybe a fan quite working if you hit a bump or something, wire issue, grass should not be a problem except maybe for gear to pull apart from foam housing. I wish they would of made a 90mm instead, they are easier to diagnos, yes I know 2 are more realistic, but they seem to never sound in sink.
| Thread Tools | |
| Discussion Flyfly mig 29 OVT ak MIG 35 | amigob | Electric Ducted Fan Jet Talk | 11 | Oct 28, 2010 12:22 PM |
| Sold HET-RC Mig 29 Twin Fans Grey | 3DTRYER | Aircraft - Electric - Jets (FS/W) | 0 | Dec 07, 2009 10:15 PM |
| For Sale Mig-29 twin fan (including 2 X Het 6904mm fans | 3DTRYER | Aircraft - Electric - Jets (FS/W) | 0 | Jun 17, 2009 04:58 PM |
| Discussion new mig-29 twin fans to be out soon | gazza2003au | Foamy EDFs | 11 | Feb 24, 2009 05:08 PM |
| Discussion HET Mig-29 Vs FlyFly Mig 29 | skydve76 | Electric Ducted Fan Jet Talk | 2 | Oct 06, 2008 12:32 PM |
