Old Jan 26, 2013, 04:30 PM
wyldkrd is offline
Find More Posts by wyldkrd
Yeah, I can fly...
wyldkrd's Avatar
Mesa, Arizona
Joined Jun 2005
Well, my first maiden attempt resulted in a long run off the end of the runway even though I cut the power early. Tore the stock gear nose and one main gear out
I think it was still too nose heavy and thus collapsed the nose gear so much it stuck to the ground despite full up at full power after a few second.
So... I am making the following changes:
E-flite 15-25 retracts all the way around. I had a double wheel nose from an F/A-18 using stock tires. Mains will also get bigger tires. This should cover and takeoff/landing issues.
Switching to a 5s 4200 45c setup for power. Running a 2s 4200 45c and a 3s 4200 45c(Hyperion) in series. 3s pack under the hump and 2s laying flat under canopy area. Should put my balance further back.
Remember, I'm not running the stock motors, I have 3000kv 5s capable motors.
Rain has been a factor for the event I finished for so I may make an attempt to fly it tomorrow
wyldkrd is offline Find More Posts by wyldkrd
Old Jan 26, 2013, 05:03 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
You may want to check your AOA while on the ground as well and ensure you have a slight nose up attitude. Also ensure tail is set up right. If I remember correctly they were set with a bit of up in the neutral position. Not sure of your power setup but one thing to remember is that going to a 5s setup will noticeably dercrease power/thrust output. Here is one pic of elevator neutral position
http://www.rcgroups.com/forums/showp...postcount=3347
DamonH is offline Find More Posts by DamonH
Old Jan 26, 2013, 11:54 PM
wyldkrd is offline
Yeah, I can fly...
wyldkrd's Avatar
Mesa, Arizona
Joined Jun 2005
The new nose gear is set for a little more up than before. I have a little up already on the elevator, it was real close the last time so I think I will be good.
This was built from the ground up- i.e. NOT using the 2100kv motors that it usually comes with. I opted for Dynam 3000kv's that usually come with the Meteor. We have run these as 5s in other 70mm airframes with great success and I thought two would be enough for this.
Old Jan 26, 2013, 11:58 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Cool....Good luck on your next try!
Old Jan 27, 2013, 03:24 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Same happened with my F-16 until I raised the front LG 1.5cm.
Tartago is offline Find More Posts by Tartago
Old Feb 11, 2013, 01:17 AM
panteras120 is offline
Find More Posts by panteras120
Joined Jul 2010
Dear Brandon, may you post how you achieve this georgeous louvers on the top side of the inlets?
panteras120 is offline Find More Posts by panteras120
Old Feb 11, 2013, 04:21 AM
brandonmoon is online now
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
I will try and come back here and do that again later this week. Thank you for the compliment.
For now, there are pictures of them on my blog page you can study to see how I did it, plus several modifications
http://www.rcgroups.com/forums/showthread.php?t=1685223
brandonmoon is online now Find More Posts by brandonmoon
Old Feb 11, 2013, 07:58 AM
wyldkrd is offline
Yeah, I can fly...
wyldkrd's Avatar
Mesa, Arizona
Joined Jun 2005
I finally got mine up on the 3rd attempt. Needed a significant amount of up trim. One of the fan covers came off in flight but was recovered. Luckily the fan did not come out! I was amazed how much she wanted to float on landing, I had to go around and greased the landing. She flew quite well, didn't get to try the flaps/slats or drag chute yet. I started a new job so I've been rather busy so have not flown it again yet. I plan to add the gear doors but will probably fly it again soon. Glad to be part of the club flying this awesome bird.
Old Feb 16, 2013, 12:20 PM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
Starting my replacement mig build. Had the green version stock before and liked the flights so went with the gray version this time and the cs12 blade fan system that I am starting to put in most of my planes.
houstonderk is offline Find More Posts by houstonderk
Old Feb 17, 2013, 10:25 PM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Are you going to use the 2855 2100?
Old Feb 18, 2013, 02:21 AM
Joined Oct 2010
Running eflite's bl32 motors.
Old Feb 18, 2013, 08:35 PM
Xflyfun is offline
Find More Posts by Xflyfun
So many planes, So little time
Xflyfun's Avatar
United States, OR, North Plains
Joined Jul 2010
Up Up and Away
I've got my 29 up and running now..
LX Mig-29 flight (2 min 53 sec)
Stock motors/fans on 6S.
I really like how this flys! I may build one with thrust vector some day
Xflyfun is offline Find More Posts by Xflyfun
Old Feb 19, 2013, 06:58 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
http://youtu.be/XCQ8HpZWDFg
Really nice!
Old Feb 20, 2013, 07:34 AM
Xflyfun is offline
Xflyfun's Avatar
Joined Jul 2010
Thank you
It's a fun edf and I see it (in the air) better than my f-18, something about the tail fins. I've only got a 7 channel radio, what are you vectored thrust guys using for radios on this plane?
Old Feb 20, 2013, 08:28 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Futaba 10CAG. Without drag chute and canopy ejection.
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
