Old Nov 26, 2012, 08:37 AM
.Superfly. is offline
Find More Posts by .Superfly.
RC is healthy for your brains!
Italy, Lombardy, Milan
Joined Nov 2012
I am also considering a competitor, since Freewing seems to be more popular:
the eurofighter (with canards).
What do you people say? Who has the upper hand in between the two?
.Superfly. is offline Find More Posts by .Superfly.
Old Nov 26, 2012, 10:50 AM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
I had both. The Euro is pretty good, IMHO better than the LX MiG29. But the difference is not so pronounced as in the Su35. The Euro can be improved a lot by better servos, also, the stock motor/fan combo is okay, but not thaaat exciting. You will also likely end up modding the Euro's battery bay and curse the cockpit, it opens in the front (i.e. it can be opened by the airstream).
I never got much success with the Euro's landing gears, albeit the V3 gears seam a bit better.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Nov 26, 2012, 11:06 AM
Joined Nov 2012
Wow, man, you had all the models! I treat you like a living encyclopaedia on my search
Su35 is keeping on popping up as the ultimate bird... So I am basically pulling back just because of the flaps. I must find a mental workaround for that.
Old Nov 26, 2012, 12:23 PM
MNadMan is offline
Find More Posts by MNadMan
Add Lightness
MNadMan's Avatar
Joined Dec 2011
Hey folks, your thoughts on using these change sun 10 blade impeller on the stock motors but using 4s (instead of the stock 6s) ???
http://edfhobbies.com/index.php?rout...product_id=247
I'd like to run on 4s (most all my other planes use 4s 1800 40c packs) - so hoping to use 2 of them for a 4s 3600 40c. hoping to just swap the impellers on a brand new ARF
MNadMan is offline Find More Posts by MNadMan
Old Nov 26, 2012, 12:29 PM
Joined Nov 2012
Interesting, yes what would the 4s setup do? Do you need to change ESC also? Are you using more current for the same amount of power output? So everything gets hotter I guess...
Maybe you get longer flight times then?
Old Nov 26, 2012, 04:32 PM
Purple Pashin is offline
Find More Posts by Purple Pashin
Gotz tha Jet Feeva!!
Purple Pashin's Avatar
United States, GA, Kennesaw
Joined Dec 2011
CS10 is nice if you have the power to move it. I run it in my Meteor on 5S 40C, and pull approx 85A @ full throttle. 4S was sluggish. I'm doing the Freewing counter-rotating fans in this
bird...
Purple Pashin is offline Find More Posts by Purple Pashin
Old Nov 26, 2012, 08:24 PM
MNadMan is offline
Add Lightness
MNadMan's Avatar
Joined Dec 2011
freewing has counter rotating fans - good to know
Old Nov 27, 2012, 09:16 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Program the ailerons as flaps+ailerons. No problem with the Su-35, the wires are reasonably accessible.
Cheers,
Henrik
Old Nov 27, 2012, 09:30 PM
MNadMan is offline
Add Lightness
MNadMan's Avatar
Joined Dec 2011
spoilerons work even better on a lot of RC models.
my A-10 and Sbach 342 loves them.
Old Nov 28, 2012, 03:10 AM
Joined Nov 2012
Thanks Nad, I read a bit about spoilerons. They are interesting, yet I am keen on practisingwith the normal fundamentals of flying.
When landing, at least in theory, I wish to approach ground slowly on the x direction, and have as much lift as possible (on the y direction).
So flaps should be my best bet...
Old Dec 10, 2012, 09:07 AM
XSTORM is offline
Find More Posts by XSTORM
France, RA, Saint-Cyprien
Joined Nov 2011
This MIG flies very well
I have already made 100 flights
A video the best moments
MIG 29 LX N°1 COMPIL 2012 12 09 100 eme vol youtube (5 min 1 sec)
XSTORM is offline Find More Posts by XSTORM
Old Dec 10, 2012, 09:49 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
http://www.youtube.com/watch?v=Pt7f1uz_g-A
Nice flights!
What happened at 1:03?
My only plane to break the 100th barrier is my FMS Phantom so far.
Tartago is offline Find More Posts by Tartago
Old Dec 10, 2012, 09:54 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Finally completed mine.
But I'm having a really hard time programming.
Right wing aileron and left flap servos are jittering even with the rod disconnected. I think I better change them.
Old Dec 11, 2012, 01:29 AM
XSTORM is offline
Joined Nov 2011
Originally Posted by Tartago View Post
Nice flights!
Thank you for the compliment
The plane in crashed because it had lost a rotor of one of EDF ducted fan
A JET which possesses a vectorial push and which possesses 2 EDF, cannot fly with 1 only turbine,
Because in that case there, ailerons work as if it was the depth
80 in 90 % of the efficiency of ailerons comes from the vectorial push
Old Dec 11, 2012, 05:52 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
A hedge against Asymmetric thrust if an engine is lost is to "toe out" the engine nozzles. In normal operation the two nozzles cancel each other out. If an engine is lost, the toe out of the remaining motor helps cancel some of the yaw from off-center thrust.
fredmdbud is offline Find More Posts by fredmdbud
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
