Old Nov 06, 2012, 10:35 AM
DontTMACajun's Avatar
United States, LA, Gray
Joined Jul 2011
I've replaced the stock ESCs with Turnigy Plush 60A ESCs (burnt a stock ESC on the bench!), yet I can't seem to be able to use 4-cell packs....any idea why?
I don't imagine that the stock motors are not allowing use of 4-cell packs....it's usually the ESC that limits the number of cells. These Turnigy ESCs are good for 6-cells apiece....I'm baffled! I've plugged 4-cell packs into it, but only get a steady beep, beep from the ESCs and no power.
My perception of the jet is that it flies well but is moderately under-powered, so you must use more power than necessary to maintain normal flight. It really needs 4 cells per motor; the extra thrust would surely allow for lower throttle settings and longer flight times, besides having decent power to perform really nice maneuvers.
DontTMACajun is offline Find More Posts by DontTMACajun
Old Nov 06, 2012, 10:53 AM
USA, AZ, Buckeye
Joined Feb 2010
4 Cell pack? This is a 6 cell plane. I would be surprised if it took off with 4 cells.
mray is offline Find More Posts by mray
Old Nov 06, 2012, 11:24 AM
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Are you only using one 4 cell pack? If your using two, are they hooked in parallel or series? If they are hooked in series they would then be 8 cell which would explain why it doesn't work if esc's are rated to 6s. If they are hooked in parallel you would still have 4s and as mentioned above wont be enough.
DamonH is offline Find More Posts by DamonH
Old Nov 06, 2012, 03:11 PM
Joined Jul 2011
I'm using two 3-cell packs connected in series. So yes, it's flying on 3-cell....that's what the instructions called for. When I tried to 4-cell packs in series, it wouldn't work.
I see that some of you are flying with a 6-cell pack; I'm assuming connected in parallel?
Old Nov 06, 2012, 03:34 PM
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
The Plush ESC cannot go over 6S if I remember correctly. If you want to run your setup on 8S (two 4S in series) you will need an ESC that can handle it such as a Castle ICE 75/100, or any HV ESC that can handle your current. Can your motors and EDF units handle 8S?
Highfly! is offline Find More Posts by Highfly!
Old Nov 06, 2012, 03:42 PM
DamonH's Avatar
Joined Oct 2011
Running two 4 cell in series goes back to my previous post saying that if they were in series it is 8 cell and I dont think the esc's will handle 8 cell.
Old Nov 06, 2012, 05:52 PM
Joined Jul 2011
Wait, that's my mistake. Two three-cell packs in parallel, to create a 6-cell pack. D'oh
Old Nov 06, 2012, 05:54 PM
Joined Jul 2011
Probably not, they're the stock units. I had a brainfart in my prior statement!
Old Nov 06, 2012, 05:59 PM
Joined Jul 2011
Wondering....if the setup utilizes 6-cell power, why not have two independent 6-cell packs? Each on it's own ESC and motor, and y-harnessed into the receiver? Would it work?
Old Nov 06, 2012, 06:52 PM
Highfly!'s Avatar
Joined May 2007
Yes it will.
Old Nov 06, 2012, 08:50 PM
DamonH's Avatar
Joined Oct 2011
I think the issue with actually doing two 6s packs is weight. Two 6s packs would be way heavy.
Old Nov 06, 2012, 09:27 PM
United States, TN, Jackson
Joined Mar 2007
NO!!!...You connect two 3S packs in SERIES to equal 6S...You need 6S to fly this plane....Preferably 5000mAh 35C....
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Nov 07, 2012, 12:56 AM
Germany, RP, Kaiserslautern
Joined Oct 2010
lol, was wondering when someone would start shouting with this series/parallel talk.
I favor the last one though^. Parallel is building more mah with the same volt count.
houstonderk is offline Find More Posts by houstonderk
Old Nov 07, 2012, 04:46 AM
DamonH's Avatar
Joined Oct 2011
Kevin
I think he realized his mistake in this post. It is right below the one he said two 3s in parallel for 6s.
Old Nov 07, 2012, 08:11 PM
Joined Mar 2007
Good deal!!!...The only reason for shouting is that I HATE to see a guy make a mistake that could cost him a plane......Shouting was for emphasis and to get the changes in ASAP...Just trying to help.......
Kevin
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
