Old Oct 10, 2012, 07:06 PM
swps is offline
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
The spark is actually pretty normal on high volt systems and you can create or buy an anti spark jumper but on this plane I wouldn't bother. Just to check you are using 2 3s packs right?
swps is offline Find More Posts by swps
Old Oct 10, 2012, 07:37 PM
ebelling1 is offline
Find More Posts by ebelling1
United States, SC, Columbia
Joined Jun 2012
Yes I am using 2 3s packs .
ebelling1 is offline Find More Posts by ebelling1
Old Oct 10, 2012, 08:42 PM
Joined Jun 2012
Got it working, thanks for the help.
Old Oct 11, 2012, 04:29 PM
Aviator750 is offline
Find More Posts by Aviator750
Aviator750
United States, IN, Indianapolis
Joined Sep 2011
Ok,
I need help with wiring up the the thrust vectoring. I have a Spektrum DX8 and a 8 channel reciver. I have set up delta wing and have the elevators and ailerons doing the same thing same direction. As far as setting up the thrust vectoring. I guess I use Aux2 and Aux3 as Aux1 is flaps. Anybody have experience setting this plane up on DX8?
Help appreciated.
Brad
Aviator750 is offline Find More Posts by Aviator750
Old Oct 17, 2012, 05:22 PM
texbird is offline
Find More Posts by texbird
texbird's Avatar
USA, TX, Austin
Joined Jan 2011
i have done some searching in this big thread.
Right now the kit and the arf are only $90 difference.
So whats the advice kit or arf?
Not looking for a hotrod, stock perf would prob be OK.
I can do the minor mods i see listed & seems LG are no good?
So stock everything else is OK ? In that case get the arf?
texbird is offline Find More Posts by texbird
Old Oct 17, 2012, 08:25 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
That is not much and therefore makes it very tempting to go the ARF route.
It depends. I lost a stock ESC already on the work bench, before it flew once. Also, the stock motor/fan combination is a bit lame, or at least was so before Lanxiang switched to a new version with metal fans (I don't know how good they are, but as far as I can tell hardly any supplier should have that new version yet).
The landing gears are probably going to fail you soon, especially if you don't have a good runway. In that case you are looking at less than 10 flights before the first gear failure, IMHO.
Nonetheless the ARF is tempting. I bought one and ended up - after some time - replacing ESCs, motors and gears. I kept the original servos so far. So I would probably buy the ARF today and try it out. Just be prepared to rework it once parts fail, and if the fail, go upmarket. Don't bother with the original spare parts.
Just my 0.02 cents, ofc.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Oct 18, 2012, 11:22 AM
texbird is offline
texbird's Avatar
USA, TX, Austin
Joined Jan 2011
Cheers,
Henrik
Thanks Henrik
Old Oct 19, 2012, 01:52 PM
washab is offline
Find More Posts by washab
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
Subscribed
Haven't read through the entire thread yet but have been eye-balling this jet for a long time. I really love the look if this jet.
Couple of questions if anyone doesn't mind answering:
1. has anyone dealt with/purchased from these folks???
http://www.rcwarbirds.co.uk/edf-jets...ufacturer_id=2
2. Airframe only or ARF??? I'm thinking airframe only...
Thanks in advance for any replies.
washab is offline Find More Posts by washab
Old Oct 19, 2012, 02:23 PM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Hi there,
I bought one MiG29 there. The service was good, no complaints. Also, they were one of the very first in Europe to have the MiG in stock. They seemed a bit pricey, though.
If you are looking for a European source, you can also try trade4me.de, which have both the grey and the red (!) MiG in stock as airframe-only versions for 179 and 159 Euros, respectively.
It really is a matter of taste and inclination. If you go the airframe-only route, you will end up with a pretty damn good airplane if you do the right mods and add the right parts. It will cost you an arm and a leg and a lot of time. If you buy the ARF, you will get an airplane that looks good, but has some lame components, but which will be in the air in no time :-).
One thing to consider is that the ARF-Lanxiang-MiGs currently for sale are probably the older versions without the new fans and motors. So they had better be cheap.
Cheers,
Henrik
Old Oct 19, 2012, 04:30 PM
Wader237 is offline
Find More Posts by Wader237
Joined Jun 2012
i have a question i got a new receiver for the mig and ive been trying my damndest to bind the stupid thing but whenever i plug in the batteries the damn light just blinks and dosent let me bind any one else have this issue
Wader237 is offline Find More Posts by Wader237
Old Oct 19, 2012, 04:31 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
What tx/rx are you using?
DamonH is offline Find More Posts by DamonH
Old Oct 19, 2012, 04:33 PM
Wader237 is offline
Joined Jun 2012
the stock 12 ch
Old Oct 19, 2012, 04:49 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Not too familiar with the stock setup. Is there a bind button on rx or does it have a bind plug? When you attempt to bind is throttle at lowest setting?
Old Oct 19, 2012, 04:51 PM
Wader237 is offline
Joined Jun 2012
bind button. it almost seems like i have to unbind the radio to bind the new reciever
Old Oct 19, 2012, 06:23 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
What brand tx/rx is it? I know you said stock but there are a few stock...i.e. blitz rc or LX. The process is different for each.
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
