Old Aug 23, 2012, 04:19 PM
Sockrat is online now
Find More Posts by Sockrat
Canada, AB, Calgary
Joined Oct 2010
Originally Posted by mray View Post
Does anyone know if the ARF's shipping today are the V2 with new fans and upgraded retracts?
Got red RTF this month:
The only thing that changed in last 9 months were ESC (they are now slightly flatter and ribs are along the airflow). Fans are still standart LX you find even on SU-47. Retracts are servoless but is a nightmare to make work solid (those I got 9 months ago were better)
Sockrat is online now Find More Posts by Sockrat
Old Aug 23, 2012, 05:09 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Thanks for the info, SR!
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Aug 23, 2012, 06:57 PM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
I was hoping they would be shipping with these now.
http://www.rcgroups.com/forums/showp...postcount=4502
mray is offline Find More Posts by mray
Old Aug 25, 2012, 12:44 AM
mray is offline
USA, AZ, Buckeye
Joined Feb 2010
I guess they are still shipping the same V1 plane....just got mine and everything is the same.
Old Aug 28, 2012, 05:13 PM
FOX ONE! is offline
Find More Posts by FOX ONE!
Houston. .we have a problem.
FOX ONE!'s Avatar
United Kingdom, England
Joined Aug 2008
Originally Posted by Tartago View Post
To remove the plastic retracts, just activate them open, then yank them right and left until they detach from the foam.
Hey guys, just to let you know, I removed the plastic retracts from my old bird using denatured alcohol. Pour a small amount in (it wont eat the foam if it's DENATURED alcohol), wait a couple of minues then remove. Clean the area with paper towel, then you're set to put different ones in. No damage to the foam this way!
FOX ONE! is offline Find More Posts by FOX ONE!
Old Aug 29, 2012, 12:23 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Good tip!
Tartago is offline Find More Posts by Tartago
Old Aug 30, 2012, 06:31 AM
Wader237 is offline
Find More Posts by Wader237
Joined Jun 2012
So I'm replacing the escs and I was wondering if you had to rewire the escs and battery connectors in parallel as blitzworks did form the factory or can you just have them as 2 Seperate entities. And link the bec's with a y harness
Wader237 is offline Find More Posts by Wader237
Old Sep 11, 2012, 06:19 AM
brandonmoon is offline
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
Here is a vid remix of LX Mig-29 I was playing arround with tonight
My Customised LX Mig 29 done in East German Scheme 3 MI2 (4 min 59 sec)
brandonmoon is offline Find More Posts by brandonmoon
Old Sep 11, 2012, 11:05 PM
Canada, AB, Calgary
Joined Oct 2010
Brandon, 2 questions since you probably had more Migs then the rest of us here together:
1) HK sells a copy of retracts you ordered. The nose one has a very weak spring and fully folds at 400g. Not surprising, because spring diameter is too small for trailing link I think. Was it the same with yours?
2) Do you use aileron-elevator mix? I'm not comfortable with small ailerons but even less comfortable about mixing them with huge elevators.
Old Sep 12, 2012, 01:24 AM
Joined Mar 2009
Yes I fly it with a delta wing mix, but I also can disengage that via the TX and fly it it normal wing if I choose to, but I prefer the Delta wing mix.
I don't know about the retracts at HK?...mine are from RCLanders and work great and hold up pretty well...even the nose gear...though I did beef up the strut pint to a 4mm pin
Old Sep 12, 2012, 03:58 AM
husel is offline
Find More Posts by husel
Deutschland
Joined Oct 2008
Have RCLanders as well: retracts have a spring 43mm x 5.6mm with wire diamater 0.7mm and a 3mm strut pint. Both do not work with a 3.2kg MIG, replaced strut with 4mm and spring with wire diameter of 1mm.
Tim Wan should change that...
husel is offline Find More Posts by husel
Old Sep 12, 2012, 04:11 AM
Joined Mar 2009
I agree. and I told him that when he did the first set for me. Also recomended it be 5mm on all 3 retracts
Old Sep 13, 2012, 04:58 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
FYI for the latest version of the Su-47, they now have 80A ESCs and metal-shroud fans.
Cheers,
Henrik
Old Sep 13, 2012, 03:43 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Mine just came in. It seems much lighter and delicate compared to my SU-35.
SU-35 flat spin (1 min 22 sec)
I have some spare SU-35 fans and motors and will use those, as it is a kit and not RTF.
Will the MIG hold a single 6S battery? Up to what size?
urrl is offline Find More Posts by urrl
Old Sep 14, 2012, 02:06 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
Both wing landing gear were malfunctioning till I adjusted these screws.
I have a bad feeling about these landing gear but I'll give 'em a try.
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
