Old Jun 12, 2012, 12:30 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I got to work on my MiG a little more last night...As you have read, the variable geometry thrust balls are hollow (don't have the foam insert) and cause a loss of thrust...I wanted to add afterburning LED rings to the exhaust...I installed the AB rings inside of the variable geometry thrust balls using hot glue...I needed to install something inside of the thrust balls to smooth out airflow but not cover up the LED afterburner rings...I found some clear plastic cups that fit GREAT!!!...The tapered cups seal the open thrust ball area promoting smooth airflow and since they are clear the afterburner LED's shine brightly through..In fact, the clear cups act like a light diffuser making the afterburner effect look brighter and even better!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jun 12, 2012, 12:41 PM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
Kevin
Kevin that sounds great....any pics?
mray is offline Find More Posts by mray
Old Jun 12, 2012, 02:50 PM
Joined Mar 2007
No...I may just do a video later on this evening...My son has golf practice so it will be late this evening before I can post the vid...
Kevin
Old Jun 12, 2012, 08:42 PM
Joined Mar 2007
I decided to go ahead and post pics as it's too dark to shoot video...
First is a shot of the plastic cup used...A 16 ounce one from Walmart...Next few shots are of the LED ring inside of the ball of the exhaust nozzle...The LED's are inside of the plastic cup for smooth uninterupted air flow...The cups are just hot glued in place as well as the LED rings...The LED rings are included as part of a twin jet light kit from RC Lander....I did have to make "pie shaped" cuts in the larger opening of the cups for a flush fit within the nozzles...As you can see, the fit/taper of the cups looks almost like the shape was specially made for these nozzles...The variable geometry nozzles work unrestricted...
I'll post better pics/video later with the LED's connected to power...I had to disconnect them to glue the nozzles in place...
Kevin
Old Jun 12, 2012, 09:01 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Nice work Kevin. I may have to use that idea on my mig that sits in a box waiting to be built.
DamonH is offline Find More Posts by DamonH
Old Jun 12, 2012, 09:20 PM
Joined Mar 2007
THANKS!!!...When I make the next post with pics or video I'll show how I cut the cups to give the basic shape and the "pie cuts" needed to get the cup to sit flush on the larger end...
Kevin
Old Jun 16, 2012, 05:51 AM
Wader237 is offline
Find More Posts by Wader237
Joined Jun 2012
Question:
I got the mig and I built it and hooked everything up, but i am not sure how to hook up the thrust vectoring does it go through channels 7-9 or do you link it up through the control surfaces using y harnesses. I ask this because i hooked them up in channel 7-9 and its just making them move in the two positions that the switch has and no movement with the controls.
Wader237 is offline Find More Posts by Wader237
Old Jun 16, 2012, 09:01 AM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
What tx/rx are you using?
Old Jun 16, 2012, 11:06 AM
Wader237 is offline
Joined Jun 2012
The stock tx/rc that came with it a skyflight 12 ch
Old Jun 16, 2012, 01:39 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
[QUOTE=Wader237;21913183]The stock tx/rc that came with it a skyflight 12 ch
I'm pretty sure 7-9 is correct. The tv switch above throttle has to be on. There is also 7-9 switches that allow you to turn each axis on/off so make sure they are right. There is a switch on front of tx near bottom on left. It should be on. Also the switches on the bottom right side need to be in the correct postions. Is the mix switch in the up position? My switches on the bottom right are like this starting from mix switch. Up, Down, Up, Up, Up. I dont use this tx anymore but that is how mine is set up when I did use it and it worked fine. Let me know what you figure out.
Old Jun 16, 2012, 03:25 PM
Wader237 is offline
Joined Jun 2012
Tried it didn't work still. Its weird
Old Jun 16, 2012, 04:15 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
So what exactly is it doing or not doing. Does tv ever work? Does one or two axis work and the rest dont?
Old Jun 17, 2012, 11:17 AM
Wader237 is offline
Joined Jun 2012
its working but not the the tv switch it is moving on the two pos switches that are connected to 7-9
Old Jun 17, 2012, 05:02 PM
Wader237 is offline
Joined Jun 2012
problem solved:
I used the servos an set them so that down on the switch was level pos and up was up pos on the nozzles then set the rudder one to be level in down pos and to a specified direction l or r on direction preference when up.
Old Jun 19, 2012, 03:45 PM
Sockrat is offline
Find More Posts by Sockrat
Canada, AB, Calgary
Joined Oct 2010
Kevin
Make sure you glue these plastic cups very well, especially the leading edge. And with some real glue. Or probably use 2 of them.
Mine lasted for 20 sec of full throttle and flew our shattered in pieces. Ended up with 2 paper cups per nozzle, they are less prone to cracking and last so far.
Sockrat is offline Find More Posts by Sockrat
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
