Old Sep 21, 2011, 07:41 PM
brandonmoon is offline
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
Yea I heard about it last week ....and there is a guy here that already has one, went and saw it today...it's a HET clone except it's very heavy!!!!...tooooo Much RESIN
brandonmoon is offline Find More Posts by brandonmoon
Old Sep 21, 2011, 07:48 PM
daddyrabbit1954 is offline
Find More Posts by daddyrabbit1954
A posse ad esse
United States, FL, Tampa
Joined Feb 2011
Originally Posted by jcdfrd View Post
HK is doing it again
have you guys seen this one
http://www.hobbyking.com/hobbyking/s...dproduct=15526
Just the basic airframe with no retracts and it weighs almost 6 lbs? By the time this gets all dressed up, won't it be on the heavy side? Usually, the stated weight is less than actual, so it may be more than advertised.
daddyrabbit1954 is offline Find More Posts by daddyrabbit1954
Old Sep 21, 2011, 07:56 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Sure makes a purty static model!
fredmdbud is offline Find More Posts by fredmdbud
Old Sep 21, 2011, 09:17 PM
Joined Mar 2009
Well guys I just did some static testing Of the New Counter rotating 68mm EDF units from RCLanders in the new LX Mig-29 and here is what I got
using Turnigy Nano-Tech 5000 Mah batteries (2X3s) 45-90c
RCLander New 68mm Counter rotating EDF fan set (Motors are 2550 KV) and weight 276 grams each
using CC Ice lite 100A esc's
@ WOT got 6.7 to 6.9 Lbs thrust sustained @ 119 Amps peak draw (so about 1.5 to 1.6 KG each) ( ??? not quite getting the rated spec on the rated KG out) this is probably due to the long ducting of the LX Mig, even though I do have a set of cheater vents right in front of the fans and the louvers as well....but may still not be enough for them to breath properly? in any case...that is what I got so far.
Very quiet and well balanced fans, Here are the rated specs from the RCLander web site on both fan sizes:
EDF - 68mm
Power - 4S (4000kv) & 6S version (2600kv)
Thrust - up to 1.7kg (63A) 4S/ per one
up to 2.1kg (56A) 6S / per one
Weight - 238g (4S) with motor /per one
276g (6S) with motor /per one
Old Sep 21, 2011, 11:56 PM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Thanks for the information Brandon. I'm afraid at that cell count, the thrust is VERY underwhelming. It would be difficult to get the aircraft light enough for hovering which IMO is the only real benefit the counter rotating fans would provide. I suppose it could be done but I was expecting MUCH better when you consider the amp range, heavy fans, big batteries, etc etc. Unless you are aiming directly for a 3D bird, and even then the weight is going to be a problem, I don't know if there is nearly enough benefit to justify that much loss in power.
So what's your thoughts on it?
Pepperpete is offline Find More Posts by Pepperpete
Old Sep 22, 2011, 12:13 AM
evo101 is online now
Find More Posts by evo101
evo101's Avatar
Australia, QLD, Brisbane
Joined Jun 2009
im not to interested in hovering my mig,
i just need to upgrade the motors so i can get more performance and will try and fit a 6s 5000 pack in to the plane
evo101 is online now Find More Posts by evo101
Old Sep 22, 2011, 05:10 AM
Joined Mar 2009
I agree. But those are just the initial first test and run ups. I know the fans are capable of a little more than that for thrust. right now they are putting out about the same as the HET 2w-25's with the Wemo fans, but with a weight penalty.
Question for you? how big are the cheater holes you did on your Mig? Demensions? and can you post some more pictures of those?...I think yours may be better than mine, Simplier and more effective. I may need to enlarge mine some more and simplify them in order to feed the fans (all of the different setups I've been testing) the air properly. I'm not getting bad or unusable readings by any means....I just feel it could be better....for instance the Hets and the RCL's are almost Identical in KV and recomended specs (Minus thier weights) and I should be seeing about 2 more LBS of thrust on each one of those setups. the RCL fans are heavier the the ARC 28-58-1 setup, but the RCL's draw considerably less amps....so there are pro's and con's to each of them. But right now I think from what I'm seeing.... the HET 2w25/Wemo is the better option, but still have a few things I haven't tried yet?
Old Sep 22, 2011, 10:00 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
anyone see the twin 70mm, HK Mig 29 yet? looks pretty sweet for 190 bucks.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Sep 22, 2011, 10:11 AM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
See above, #3962
Old Sep 22, 2011, 10:14 AM
Joined Jan 2009
HAH!!!! sure pays to read. hahahahahaha.
Old Sep 22, 2011, 09:36 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I'm still up in the oil patch so no pictures but I can tell you that the cheaters I added right on the bottom of the nacell are directly in front of the fans and a good size. They are square in formation and I think a few inches across? Don't quote me on that. I think if you scroll back I did post a few pictures. I get tons of thrust with them and they also help me rotate on takeoff. The amount of "suck" factor when I go WOT in static tests is amazing if you stick your hand near the bigger cheaters on the bottom (covered with mesh of course). Much more than the inside nacelle cheaters I have as they are twice the size of those. The fact that the inlets AND the cheaters are pulling in such a drastic amount of air shows how hungry these little fans are.
Old Sep 22, 2011, 09:38 PM
Joined Mar 2009
Thanks Glen ...I found them.....studdying them right now. What are the 2 diagnal slots just behind your canopy? are those vent hole you added? those look pretty slick and wickedly cool...even if they're not scale....I like them
Old Sep 22, 2011, 09:49 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
That's exactly what they are. I know they are not scale but I really wanted a closer zone for hot battery air to be able to escape. There is also another larger slot just behind the nose cone (on the underside) so that the air can come in from that direction and leave through the two other slots. The one on the nose you can hardly even notice unless you are looking for it.
So far everyones reaction has been "they look cool and obviously work" which is why I did it.
Old Sep 22, 2011, 09:54 PM
Joined Mar 2009
the one on the nose must be on the bottom of it I'm assuming? I really like that idea....Hmmm? may have to do those? the fan cheaters look like they are about 2 inches by 2 inches.
I'm going to move the RCL fans over to the first mig and add those cheaters and see if it produces better results than the ones I did on the German mig. If it does then I'm going to modify the german migs cheater holes
Old Sep 22, 2011, 09:56 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I'm going to move the RCL fans over to the first mig and add those cheaters and see if it produces better results than the ones I did on the German mig. If it does then I;m going to modify the german migs cheater holes
Sounds like a smart plan. Don't forget I've got both the cheaters on the bottom and on the inside of the nacelle.
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
