Old Oct 17, 2010, 04:53 PM
troadus is offline
Find More Posts by troadus
troadus's Avatar
Tacoma, WA
Joined Sep 2006
Originally Posted by rachelwilcock123 View Post
why thank you leon alas my trouble lies in actualy programming the throttle to the esc's ie up down on throttle a few times it will beep and u now have throttle response . I think its the speed controler
Well then put the throttle stick to full throttle before you turn on your radio. Then plug in your lipo pack to your plane, now turn on your radio then move the throttle stick to throttle cut off and turn off your radio. When you turn it back on you should have throttle......
Leon
troadus is offline Find More Posts by troadus
Old Oct 18, 2010, 07:18 AM
rachelwilcock123 is offline
Find More Posts by rachelwilcock123
Joined Oct 2010
the biggest problem i have now..and thank you troadus that worked fine for my transmitter and it now works, my biggest problem is my rudders and my nose wheel wont work no activation from either..is there a particular way to conect them ..as plugging into the ''rudder' part on reciever doesnt work
rachelwilcock123 is offline Find More Posts by rachelwilcock123
Old Oct 18, 2010, 07:30 AM
rccrazee is offline
Find More Posts by rccrazee
Airshow Joe
rccrazee's Avatar
N.W. Detroit Suburbs
Joined Feb 2009
After the repair!
LX Models Mig 29 Twin 70MM EDF Jet (3 min 31 sec)
rccrazee is offline Find More Posts by rccrazee
Old Oct 18, 2010, 08:58 AM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Originally Posted by rccrazee View Post
After the repair!
Bravo!!
hklagges is offline Find More Posts by hklagges
Old Oct 18, 2010, 11:36 AM
Joined Oct 2010
gorgeouse rccrazy great job on the repair. Could i pick someones brain a little. On your jets the rudder..and front steerable nose wheel. on mine i plug the servo marked (direction) into the rudder port in reciever and nothing.. on your jets is the direction lead plugged into a servo cable splitter and maybe links with another somehow as im baffled why the link is dead. is front strut steering linked with the rudder? ide expect so ...
Old Oct 18, 2010, 11:55 AM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
RCCRAZEE did some serious rebuild action.....that plane flies great....even with the CIRCUS IS COMING TO TOWN lighting system.
kydawg1 is offline Find More Posts by kydawg1
Old Oct 18, 2010, 12:08 PM
kydawg1 is offline
kydawg1's Avatar
Joined Mar 2007
Hey did you change all those CLEVISES.....?
And have you had any problems since....even doing STO (Short Take Offs) just exactly like in your crash video? Huh then that was the failure just as we discovered.
Looks awesome and flies great. Time for me to start a Buildin.
Old Oct 18, 2010, 02:05 PM
troadus is offline
troadus's Avatar
Tacoma, WA
Joined Sep 2006
Unplug your servos at the Y-connector and check them both if they work then it's your Y-connector or the extension on the Y-connector that goes to your receiver....
Leon
Old Oct 18, 2010, 02:08 PM
troadus is offline
troadus's Avatar
Tacoma, WA
Joined Sep 2006
[QUOTE=rccrazee;16317947]After the repair!
Nice flying and a beautiful Autumn day for it......
Leon
Old Oct 18, 2010, 03:34 PM
Joined Oct 2010
oh no's it may be back in the plane then ..and ive sealed it all up to i dont fancy carving it up but it may be the only solution then ;(
Old Oct 18, 2010, 04:07 PM
troadus is offline
troadus's Avatar
Tacoma, WA
Joined Sep 2006
WOW I wish you luck, please let me know what you find.
Leon
Old Oct 19, 2010, 07:52 AM
FOX ONE! is offline
Find More Posts by FOX ONE!
Houston. .we have a problem.
FOX ONE!'s Avatar
United Kingdom, England
Joined Aug 2008
Help needed !!
Hi guys,
Help needed please!
I have a receiver ready version, the nosewheel retracts/extends as it should, but the main gear just make a buzzing noise and dont move.
I'm wondering if anyone else has experienced a similar problem? Possibly the mains wired incorrectly through the retract/smoke control box? - maybe they got the positive and negative reversed by putting the plugs in the wrong way around (is this possible, or are the plugs only able to be connected one way, like futaba servo lead plugs?)
Anyone know where that box sits inside the model? I dont really fancy carving it up. But then it will cost me a fortune to send it back. Looks like I'm FUBAR
Any help would be appreciated!
FOX ONE! is offline Find More Posts by FOX ONE!
Old Oct 19, 2010, 10:38 AM
Joined Oct 2010
well ile make u a deal .. u carve it up ..and i will to....
Old Oct 19, 2010, 11:07 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Congrats! Can't wait to see you tumble with it and give a flight report.
Do the flaps and slats help the slow speed handling?
eroeder is offline Find More Posts by eroeder
Old Oct 19, 2010, 11:11 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
Can you open the gear door by hand WHILE the noise is on and then peek in? Do the motors turn the little threaded metal rod? What if you put a screw driver between the gear door and the fuselage and try to lift the gear at the wheel a bit WHILE the noise is on? Can you lift the gear?
If you can open it at least partially, look for gear obstructions and also OIL the threaded rod. If it is bent, you can bend it back straight again (I did this after my MiG-29 crash).
I think that reversing would be no problem (with respect to the gear not moving). Only gear-in and gear-out would be reversed.
You should be able to get the box free and look at it. The cable lengths are so that it sits essentially next to the canopy on one of the side cavities in the fuselage (next to the front wheel). If you carefully sort the servo wires and pull the wire for the gears, you should be able to pull out the control unit for the gears.
It will probably not help you to have it, because, it the motors turn, they turn. I don't know whether there is a sensitivity adjustment in the control unit under the heat shrink tube.
Not fubared yet. Don't give up so early.
Cheers and good luck,
Henrik
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
